Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-02-2014, 06:57 AM | #15 |
Drives: '23 BRZ
Do a track event where they have scales and corner balance it yourself. It's not hard if you know how much weight you're jacking per turn. Which isn't hard to calculate from the motion ratios, spring rates, and thread pitch.
06-02-2014, 08:33 AM | #16 |
Sometimes, and only sometimes, when corner balancing, the car ends up with the ride height uneven, so all corners might not be at exactly the same height.
If the car is straight, it usually isn't noticeable. |
06-02-2014, 09:19 AM | #17 | |
Drives: '23 BRZ
It's not hard to corner-balance AND have the front/rear ride heights you want, taking into account that if there's some twist in the chassis you'll have to live with *average* ride heights between the left and right at the front and rear of the car. If you're paying someone to do it and they say they can't do that for you, go elsewhere or do it yourself. |
The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (06-02-2014) |
06-02-2014, 10:36 AM | #18 |
If you have the car corner balanced properly (with you in the drivers seat) it'll sit slightly funny with no one in it, but that's the price you pay for proper balance.
The Following 4 Users Say Thank You to wparsons For This Useful Post: | CSG Mike (06-02-2014), ExxelDistributions (06-03-2014), SkAsphalt (06-02-2014), tahdizzle (08-29-2014) |
06-02-2014, 11:27 AM | #19 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
You deserve it
Do it You will not regret it
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi |
The Following 3 Users Say Thank You to kiichiro For This Useful Post: |
06-02-2014, 01:24 PM | #21 |
Drives: '23 BRZ
Honestly, I wouldn't bother until/unless I *knew* the corner weights were off. I installed Ohlins DFV on the RX-7 last year, was going to corner-balance at the track. As installed, with me in the car and 15 gallons (3/4 of 20 gallon tank, should check again at , corner weights were only off by 4 pounds (1555/1559). Done!
You'll never feel the difference between dead even 50.0/50.0 corner weights and 48/52 on the street, and even at the track it's going to be somewhat subtle (*slightly* different under/oversteer balance in left-handers vs. right-handers). It's not like anything magical happens at 50.0/50.0, I wouldn't knock myself out over doing any better than ~51/49. A lot of shops like to work on it for hours to get within a tenth of a percent, but IMO it's not worth the additional $$$ spent. |
06-02-2014, 01:33 PM | #22 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | SkAsphalt (06-02-2014) |
06-02-2014, 02:35 PM | #23 |
Drives: '23 BRZ
Corner balancing doesn't have to affect your desired ride heights, front/rear rake, or any L/R ride height difference. You can have a car corner-balanced at any attitude you want. Agree that it's best to aim for left/right level with driver in place.
The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (06-03-2014) |
06-02-2014, 03:38 PM | #24 |
100% agreed... I was just clarifying that if the car is totally level/balanced with the driver in the car, it'll be slightly off with no one in it. No different from stock, except that it'll be level empty and slightly off with the driver in it.
The Following User Says Thank You to wparsons For This Useful Post: | ZDan (06-02-2014) |
06-03-2014, 01:59 PM | #25 |
Drives: 2014 FR-S 6MT Monogram Series
Thanks for all the info and help. I will be contacting West End Alignment to get it Corner Balanced and Aligned. I spent this much into getting the parts. Might as well get that done also. You never know I might end up doing some track events.Then I'll hit up @CSG Mike for damper adjustment
The Following User Says Thank You to ExxelDistributions For This Useful Post: | CSG Mike (06-03-2014) |
06-03-2014, 02:05 PM | #26 | |
As we both know, weights and spring rates are directly related... a competent shop should be able to hit the numbers within 2 adjustments, the second being a "fine tune to get it perfect". |
06-03-2014, 04:47 PM | #27 | |
It could all be in my head
SOLD THEM BOTH
08-29-2014, 09:14 AM | #28 | |
Drives: JDM86
Secondly, you are all talking about corner balancing like its a massive improvement and a must do. The truth is, it has a high cost:performance ratio and there's a tonne of mods/adjustments that you can do to your car that would significantly improve its balance prior to corner weighting. |
Similar Threads | ||||
Free wheel mounting and balancing at R/T Tuning! | R/T Tuning | Wheels and Tires | 1 | 01-07-2014 01:33 PM |
Question about balancing/alignment on new wheels | The_Societan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-23-2013 10:42 PM |
Wheel Balancing Weights | Black Tire | Tracking / Autocross / HPDE / Drifting | 4 | 06-13-2013 05:51 PM |
Corner Balancing | Gen | Southern California | 5 | 11-13-2012 06:42 PM |
Where to find black wheel balancing weights?? | 86_ZN6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-09-2012 11:48 PM |
