10-12-2016, 12:24 AM | #29 | |
After any flash or ecu reset all learned parameters erased. always let car idle for a minute or so for initial cam vvt calibration. Throttle can also be a bit laggy for first couple of drive cycles. which tune did you flash ? |
10-12-2016, 12:25 AM | #30 | |
what was problem? which file did you flash ? |
10-12-2016, 04:44 AM | #31 | |
Drives: UK GT86
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | thambu19 (10-15-2016) |
10-12-2016, 07:09 AM | #32 |
Drives: 17 86
I sent Shiv the stock ROM from the 17 86. He sent back a test file, flashed OK. Cranked, but no start. Reflashed the stock ROM with errors. OFT reported (IIRC, pics on another PC) VIN mismatch. No crank, but the ECU was showing data on the OFT. The dealer said they had never seen that failure before. The anti-theft(?) system killed the engine. They eventually did the reset listed in your brick guide.
Shiv has all the logs and debugs. All should have been well according to those. Well above my pay grade, but I put it down to shit happens. I'll try again when someone else has a good flash. E85 should be impressive in the MT. |
10-12-2016, 07:15 AM | #33 | |
Weird oft does not alter vin it just checks it to see it match's vin in oft when you married car and oft. can you send me the test file ? that caused the issue via pm if you like |
10-12-2016, 12:53 PM | #34 |
btr.life
Drives: 2022 GR86
Gets around the torque dip? The torque dip is still there.
10-12-2016, 06:21 PM | #35 |
Drives: 2017 BRZ
I flashed my car last night with Shiv's TEST K001 file.
Starts, everything seems ok. Waiting for tune file tonight~ |
The Following User Says Thank You to gskv For This Useful Post: | justinco (10-12-2016) |
10-13-2016, 07:47 PM | #36 |
Drives: 2017 BRZ
Just want to add that on 2017. The air filter is different. No aftermarket replacement filters currently fit the 2017.
And still awaiting tune! |
10-13-2016, 08:37 PM | #37 |
Drives: Toyota 86 GTS
In the meantime it would be interesting to see logs of the stock car with stock tune.
10-13-2016, 10:01 PM | #38 |
Drives: 2017 BRZ
Not a bad idea. I shall post it up after driving to and from my bball game.
10-13-2016, 10:05 PM | #39 |
3rd gear WOT por favor
10-14-2016, 03:03 AM | #40 |
Drives: 2013 Scion Frs 6mt
Any updates? lol
10-14-2016, 11:47 AM | #41 |
Drives: 2017 BRZ
had a lot of snow fall and went to swap out my stock for winters instead D:
didn't have a chance to log anything hahaha. But still no tune! |
10-15-2016, 10:16 AM | #42 | |
Drives: Scion FRS
Similar Threads | ||||
openflash tablet vs ecutek tune | brz23 | Software Tuning | 104 | 07-28-2020 04:36 PM |
Openflash tune problem with brz | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 6 | 02-09-2016 01:13 PM |
fi and openflash tune | Hachi6 | Forced Induction | 59 | 11-20-2015 01:28 PM |
OpenFlash-- header tune | mtimney | Forced Induction | 3 | 08-07-2014 03:51 PM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
