05-16-2017, 08:35 PM | #2185 |
@rayhere
The Following 9 Users Say Thank You to rt For This Useful Post: | brandonblt2 (09-15-2017), DrifterD (09-17-2017), icybrzzz (05-17-2017), Jive Turkey (06-01-2017), keb86 (05-23-2017), Lynxis (05-17-2017), PandaSPUR (05-16-2017), strat61caster (05-17-2017), VMRamos (08-11-2017) |
05-17-2017, 11:29 AM | #2186 |
Drives: DGM BRZ
@rt you make me wish I would have gone for 255 instead of 245 on those wheels. The 245 has a bit of stretch but yours is so pretty and square.
The Following User Says Thank You to jubella2 For This Useful Post: | strat61caster (05-17-2017) |
05-20-2017, 03:20 PM | #2187 | |
@rayhere
Btw just noticed my rear is rubbing slightly after some spirited driving so I'll have to roll the quarters. Not that bad though since I didn't even feel it, just happened to look at the tires after and it was barely there in the pic I posted earlier. |
The Following User Says Thank You to rt For This Useful Post: | jubella2 (05-20-2017) |
05-20-2017, 07:12 PM | #2188 | |
Drives: DGM BRZ
05-21-2017, 02:35 AM | #2189 | |
With 17x9+45 and 245 tires the dampers run out of travel before the wheel/tire hits anything, and plenty of clearance to stuff a 255 under there, maybe even a 265. I run a 5mm spacer to prevent rubbing at full lock. But then again I guess a lot of this thread is about looks and "flushness" so that solution probably isn't too welcome. |
The Following User Says Thank You to strat61caster For This Useful Post: | Spankopotomous (05-31-2021) |
06-01-2017, 09:31 PM | #2191 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
The Following User Says Thank You to Jive Turkey For This Useful Post: | rt (06-01-2017) |
06-01-2017, 11:05 PM | #2192 |
@rayhere
You're right actually. I took a closer look a few days after and it's just rubbing the bumper tab so no need to roll! Forgot to follow up here.
06-02-2017, 07:36 PM | #2193 |
Drives: Scion FR-S
I don't drive fast, I fly low
The Following User Says Thank You to ericwudi0830 For This Useful Post: | rt (06-02-2017) |
06-06-2017, 01:55 PM | #2194 |
Drives: Toyota 86
06-06-2017, 02:11 PM | #2195 |
Driver
Drives: 2013 Whiteout FRS
06-07-2017, 08:08 PM | #2196 |
Drives: FRS
'14 Scion FRS
Tein Flex TE37 |
The Following User Says Thank You to PeterFRS For This Useful Post: | Guff (06-07-2017) |
06-13-2017, 09:31 PM | #2197 |
@rayhere
06-13-2017, 09:34 PM | #2198 |
265/35's..
IG @jordonallison
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
