Software Tuning Discuss all software tuning topics. |
11-28-2018, 12:52 PM | #1 |
Drives: turbo frs
EcuTek pops tune (sport mode)
Dear
How can to tune stock ecuTek rom for pops and backfire ?? I have 2013brz has ecuTek license It was turbo But now he revers to stock Just he need pops and back fire I have stock ecuTek rom and cable + USB dongle I need to activate pops just at sport mode Thnx to all |
11-28-2018, 02:37 PM | #2 |
Drives: brz 2017 hksv2
Do you have racerom license? (350$ more or less)
without it you can t modify stock roms, neither use custom maps |
11-28-2018, 02:52 PM | #3 |
Drives: turbo frs
Yes there is racerom
11-29-2018, 01:00 PM | #4 |
Drives: turbo frs
any update
11-29-2018, 01:53 PM | #5 |
Can t make screenshots in these days,
You need to create a custom map, make its X-axis and Y-axis identical to your Ignition advance map VVt on (X is engine load, Y engine rpm), and then on the first column (usually 0.15 load) fill the table from 3k rpm to redline with , for example,a value of -40 On the custom map "enable" table, put a tick on the map you want it to work on, AND on "enable map in Vsc Sport mode" only Custom map "output definition" table: Ignition Base timing, Add map output to channel value Last edited by tomm.brz; 11-29-2018 at 06:15 PM. |
The Following User Says Thank You to tomm.brz For This Useful Post: | gt7877 (11-29-2018) |
11-29-2018, 02:02 PM | #6 | |
Drives: turbo frs
thnx alot right now ecutek cable not with me to open proecu can u plz send some images for reverance ill try too do it 2morrow thnx again |
11-30-2018, 03:49 AM | #7 |
i m few days away from my car and computer, follow my post and you shouldn t go wrong, in case post screenshots
12-20-2018, 01:19 PM | #8 | |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
12-20-2018, 02:29 PM | #9 |
Yes to have it. With vsc sport, it s good also to have it on command like that instead of dedicate one entire map to it
Similar Threads | ||||
Pops/Crackle Tune do damage to your brz? | Jcas | Software Tuning | 79 | 01-26-2022 10:29 AM |
Sport Mode pops | gt7877 | Software Tuning | 3 | 11-20-2018 04:37 AM |
OFT Pops and Crackle Tune problem V4 | niceman | Software Tuning | 8 | 09-16-2018 09:27 PM |
Ok to drive sport mode on OFT tune? | timmydatooth | Software Tuning | 4 | 04-14-2017 05:08 PM |
