Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-18-2016, 05:25 PM | #15 |
Drives: BRZ. R34 GT-T
Pshhh get that responsible financial advice out of here. :p
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
01-18-2016, 05:28 PM | #16 | |
Torque dip gone, some extra get-up in the engine, OFT is a lot of fun to tinker with, lowered will make your car feel like its on rails, and alignment cause duh. All that for 1400 is a steal.
01-18-2016, 05:29 PM | #17 |
It totally depends on what your use of your car will be and what kind of build your going for, street, track, drift? Most guys go for a CAI or drop-in filter and header and tune for your biggest bang for your buck.
01-18-2016, 05:43 PM | #18 | |
Drives: Scion FR-S
Instagram: @racecar_4life
01-18-2016, 05:51 PM | #19 |
Drives: Scion FR-S
Haha yup. So much unnecessary engine knock cuz I didnt RTFM. Thank god for this site cuz I saw the topic come up about 91 vs 93 octane and that's when I started to search the manual
The recommended 93 octane should be part of the "I want more power FAQ" sticky for other bad car owners like me lol
The Following User Says Thank You to VTEC For This Useful Post: | go_a_way1 (01-18-2016) |
01-18-2016, 05:56 PM | #20 | |
I guess he could live where all the pumps look like this, but there's only so much coddling you can reasonably request imo, at least it says it in the manual. |
01-18-2016, 06:49 PM | #21 | |
Drives: 2013 Whiteout FRS
01-18-2016, 07:07 PM | #22 |
Drives: 2015 Ultramarine FR-S AT
Lol @ $4 premium! Ouch.
01-18-2016, 07:23 PM | #23 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Buy a used supercharger by lowballing someone.
The Following User Says Thank You to weederr33 For This Useful Post: | 86kahl (01-19-2016) |
01-18-2016, 07:26 PM | #24 |
Drives: 2015 Silver BRZ
I bought 2015 BRZ a couple months ago. I plan on mostly DD, hopefully a couple of track days or autox, but only occasionally.
What i have done so far is Motul 300 trans/diff $75 Adjusted clutch pedal $0 Apexi drop in filter $50 Mishimoti intake tube $130 Moddiction Anvil 2 shift knob $70 Plan for alignment and camber bolts next to get good baseline numbers and whatever negative camber I can get up front. $150 ish That will put me right around $500 total. Will replace tires and brake pads when they wear out. Car shifts better with clutch pedal, Motul and new shift knob. Intake tube and drop in might give a bit more power, but mostly did it to get rid of sound generator and clean up engine bay. It sounds a bit different than stock. It is really easy to get caught up in mods, but realistically, this will be perfect for my real use of the car. |
01-18-2016, 07:31 PM | #25 |
Mentat
Drives: 2013 Scion FRS 6MT
Tires + SS brake lines.
01-18-2016, 07:38 PM | #26 |
Raceseng due to their modularity, definitely on the expensive end but I bought them for OE suspension with no idea what coilovers I was going to end up with. My changeover should only run me about $130, more for different setup changes.
Arguably it would be cheaper to buy a different set and then sell and buy new camber plates that match my chosen coilover (which I'm not positive I'd beat my $130 cost to change above, even if I could find what I wanted as my setup will be on the rare side) but I liked how Raceseng offers diagrams of how it goes together (some vendors barely show pictures from two angles, let alone the whole stackup) which parts fit which kits and I can visualize what I need and anticipate future changes. I'm happy with them, contrary to consensus I didn't notice an increase in NVH that usually seem to go with changing the rubber top hats to solid chunks of metal, they're as well mannered as the rest of the car for DD imo aside from a few quirky noises after a year of daily use that I think can be remedied. I wouldn't try to dissuade anyone from buying from a different manufacturer (could easily save $100-$400) and a bunch of coilover kits come with plates anyway, all depends on what you want. Cheaper kits may have compromised adjustability, adaptability, and may not be as good when it comes to NVH but I can't speak to that. Had to alter my post after I realized that the first ~$1.2k went to tires (~$600), brake pads/fluid (~$500) and camber bolts/alignment ($150-$250), then I spent >$600 on the cascams... |
01-18-2016, 07:42 PM | #27 |
Drives: brz
CNT headers $350
OFT (used) $400ish intake (used) $150ish coilovers (used) $700ish |
01-18-2016, 08:10 PM | #28 |
Drives: MY11 Maxima 350st, MY15 BRZ
Aluminium drive shaft ($450) - http://www.driveshaftshop.com/2012-s...ece-driveshaft
Final drive gear upgrade ($250~$385) - http://www.weirperformance.com/finaldrivegears.html Drop in air filter element ($50?) Labour to install it all (shop round, but should only be a few hundred from a transition shop). I put Cusco 4.556 gears in and an aluminium drive shaft in mine. Still going through initial break in, but to be honest it now feels like a higher capacity engine ie like a 2.2L. More power everywhere as it made every gear 11% faster. Throttle response has been improved. The only draw back is each gear sits about 300rpm higher at the same given road speed so it may mildly impact fuel economy, but I experienced the reverse with it improving my own simply down to the speed zones I usually drive in and the mod making 4th more usable more of the time. Our cars use the ABS sensors in the front to measure speed so I didn't even need to touch the ECU to have the speedo adjusted. Its also a stealth sort of a mod. Though a really solid mod you would only really do this one if its a long term keeper. You do also have the choice of going to more aggressive gears, at greater degree's of trade offs ie even higher rpms per gear and needing to upgrade to another LSD etc. Here's a nice read - http://www.ft86club.com/forums/showthread.php?t=27647 Figured FD gears have not been mentioned by anyone yet so thought I'd bring an interesting mod to the table for you that fits within your budget.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Similar Threads | ||||
Bang for the buck - upgrades | BAE | Engine, Exhaust, Transmission | 101 | 03-09-2015 08:23 AM |
Best bang for my buck? | ric342 | Southern California | 12 | 02-14-2015 07:09 PM |
best bang for the buck HFC | BlackyRose | Engine, Exhaust, Transmission | 11 | 08-25-2014 10:19 AM |
What is the best bang for the buck strut bar | BlackyRose | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-18-2013 10:32 AM |
Most bang for the buck? | GIMMICK | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 05-07-2013 07:10 PM |
