Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
05-12-2016, 06:51 AM | #29 | |
Drives: 2017 Cayman S
Considering the car's environment (noisy), is the OEM system that bad, or is the problem the source? Does DSP actually "color" the recordings? In home audio we look for components (speakers, amps etc.) that are as neutral as possible. Is DSP a good thing, or just necessary in the car? In my Home Theater, I simply run Audyssey then maybe tweak the subs or speaker distances a bit and a great sound experience happens. Processing Good!!! I'm rambling now. I created a really short playlist for the car that includes only the music that sound best in my car. I would love to see a list of music that you think sound's good in your car. I'm always looking for great music. I'm not a music snob. As I mentioned, I love good sounding music from across the music spectrum. List what you like. Here are some of my favorites. #41 (Live) - Dave Matthews Band Up on the Roof - The Drifters Hurt So Bad - Little Anthony & The Imperials Safe and Sound Dub - Rebelution Stolen Moments - Oliver Nelson The Hunter Gets Captured By the Game - The Marvelettes Aja - Steely Dan Time After Time - Tuck & Patti Early Bird - Billy Taylor She's Not There (Stereo Mix) - The Zombies
… and loving it! Maxwell Smart
. Gone but not forgotten 2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT |
05-12-2016, 07:34 AM | #30 | |
Drives: FRS
05-12-2016, 09:06 AM | #31 | |
Drives: Specialized Hardrock
So in the car, those of us who are really into it still look for equipment that is as neutral as possible, knowing that it gives us the best starting point. Many of us go to great lengths even to modify the car for sound, although that's not nessasary to get better sound than most people think can come in a car. In my home system, I also ran Audyssey, and tweaked a couple of things. I'm running 7.1 in the bedroom, and 2.2 in the living room. In the bedroom, Audyssey works pretty well. In the living room, it works well for everything but the subwoofers. I really need more processing power to control a large resonant mode right at 43hz. So in home, there are some cases where you don't need processing, but some where you do. If you could build a room from scratch, you could avoid any processing, but in a car, you'll always need it unless you sit in the center of the car. (And on that note Google Chris Pate civic). I'll get a list together when I get home today. I must warn you, I'm a metal head, but I listen to wide variety as well, including a good amount of orchestral music. |
05-12-2016, 10:21 AM | #32 |
Drives: 2017 BRZ
Note to the silly: you could fix things with a passive circuit if that makes you feel like you no longer have signal processing... But you'll have signal processing. huge time delay can be tough without some active control.
I only use DSP in my home theater for the bass... It's a treated room and custom 7.2 setup that had flat response to 16Hz +/-2dB but it started with over 30dB peaks. There was a bad null resolved with adding the second sub and room treatments. The physics is weird if you don't know it, and youth can do some crazy things with just good stereo speakers. Happy tuning |
05-12-2016, 10:49 AM | #33 |
I wish I was able to treat the room my 2 channel is in, but no go. That said, I'm glad I have a peak instead of a null, a little easier to deal with using peq vs having to add additional subs to fill in to nulls.
05-12-2016, 03:38 PM | #34 |
Drives: 2014 Porsche Cayman S
I have noticed that modern compressed music sounds much better with the OEM Audio Plus system than older music with a high dynamic range. I discussed this with the manufacturer. This is the complete opposite to my home system.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
05-12-2016, 03:56 PM | #35 |
Could be a couple things, either tuning related, or simply not enough headroom.
Headroom is a big deal when listening to dynamic material. I have one song in my library that has 48db of dynamic range, from the very quietest part, to the very loudest part. That very song has been the death of many, many systems since that song came out. In fact, the cd case it comes in warns to be careful with the volume. Telarc - 1812 Overture - Directed by Erich Kunzel |
The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post: | paiceyfan (05-12-2016) |
05-21-2016, 01:34 AM | #36 |
I just wanted to add this, as I just found out.
At the Relaxing in Socal Meca sound quality competition, an infinity suv with a premium bose system was entered in street class. Street class allows sound deadening, replacing speakers as long as they are in the stock locations, aftermarket amps, aftermarket processing, and additional subwoofers to be added. This infinity had the dead stock bose speakers and sub, dead stock bose amp. He took the signal from the head unit and ran it to an alpine H800, and ran the outputs from that to the stock amplifier. And he tuned it. He scored 82 points. That is almost as high as the extreme class cars score, which have no limitations on their modifications. Just a little reminder of the power of proper processing. |
The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post: | DAEMANO (06-03-2016) |
05-23-2016, 06:10 AM | #37 | |
Drives: 2013 BRZ (MT, WRB), 2005 Legacy B4
06-03-2016, 01:12 PM | #38 |
My old Alpine head unit, from my Integra, included DSP functions like spatial delay for each speaker, sub phase correction, eqs for each channel, fully adjustable crossovers for front / back / sub. Not sure if the newer units still include those functions but they were very intuitive.
06-03-2016, 03:17 PM | #39 |
They didn't for a long time, but they are slowly starting to again. Then again for serious builds, stand alone processors are the way to go now. Some of them can even do fir correction filters, which in layman's terms means no phase shifts from eq and crossovers.
Similar Threads | ||||
Help with Sound Quality | otterpop | Electronics | Audio | NAV | Infotainment | 5 | 02-01-2015 01:43 PM |
HD Radio - sound quality? ('14 BRZ) | MysteryMachine | Electronics | Audio | NAV | Infotainment | 21 | 02-13-2014 02:34 PM |
RD Audio And PHD Amps! High Quality Sound!!! | kmbkk | Audio/Visual, Electronics, Infotainment, NAV | 3 | 12-31-2013 09:44 AM |
Bluetooth sound quality with Nexus 4 | CheesusCrust | Electronics | Audio | NAV | Infotainment | 1 | 02-09-2013 01:12 AM |
The quality of the stock sound system?? | Jruex22 | Electronics | Audio | NAV | Infotainment | 15 | 08-13-2012 04:59 AM |
