Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-20-2018, 03:59 PM | #15 | |
Drives: 2005 Toyota Camry
Those same plugs have the same thread pitch and bolt size as newer cars (aka ours), so the drain plug is interchangeable. If you notice, most of these will just have a thread and "types of vehicles" it fits to. -alex |
07-20-2018, 11:21 PM | #16 |
07-20-2018, 11:27 PM | #17 | |
The Gunshine State
Drives: '14 BRZ Limited
You misunderstood me. I’m saying aftermarket magnetic plugs are gimmicks since the stock ones are already magnetic.
Current DD: M235i |
07-20-2018, 11:31 PM | #18 |
Panda Trueno
Drives: No twin now.
That diff plug is definitely magnetic. You can see it on your first couple changes, lol.
07-20-2018, 11:35 PM | #19 |
Drives: Spyder, MR2, FRS, Tundra
The drain plugs in my 2013 are not magnetic.
07-20-2018, 11:58 PM | #20 |
Drives: 2014 Scion FR-S
The Following User Says Thank You to MCTeeJ For This Useful Post: | 8RZ (07-23-2018) |
07-21-2018, 12:49 AM | #21 |
07-21-2018, 12:53 AM | #22 | |
hmmm... |
07-25-2018, 07:55 AM | #23 |
Drives: 2017_86 2016_frs 2007_335i
they r both magnetic drain plug. the diff plug with very large magnetic on the top of the plug. and the transs plug was mounting in side of plug
i just change those fluid one month ago on my 2017 Toyota 86 |
Similar Threads | ||||
Changing Differential and Transmission fluid | Seabass47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-20-2017 12:21 AM |
Changing Automatic Transmission Fluid | euthqt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 06-01-2016 03:16 AM |
Different brand rear fluid changing torque bias? | zooki | Engine, Exhaust, Transmission | 1 | 09-06-2015 10:13 PM |
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ | JPxM0Dz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 05-05-2013 05:12 PM |
Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
