Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 09-10-2019, 07:00 PM   #43
rikixass
rikixass's Avatar
45K miles on e85
Well, I have an issue from e85. It's a simple fix, but something did come up from using it. My downpipe gasket and manifold gaskets were compromised. I replaced, but will happen again? I run 60%+ E85. WIll reduce to 40-50% here forth.
END OF LINE
rikixass is offline   Reply With Quote
Old 09-11-2019, 12:16 PM   #44
Breadman
Drives: 2017 BRZ w/PP
END OF LINE
what does this have to do with running e85? ethanol will never touch this. also got my last blackstone with 5k + autocrosses and it was super clean.
The Following 2 Users Say Thank You to Breadman For This Useful Post:
Clutch Dog (09-11-2019), DaBoBo21 (09-11-2019)
Old 09-11-2019, 07:24 PM   #45
Clutch Dog
Drives: 2015 Scion FRS Halo white, Saab 97X
The only downside I heard of was possibly needing more frequent oil changes
but chances are most you hot shoes are already swapping oil every 10k, or once every three months or if you get bored.
I did hear about one of our drivers blowing out his cat but im also positive that normal 91 oct or e85 woulda done that...(dude races in the 86 cup and his high flow catted header became a hi flow uncatted)
Clutch Dog is offline   Reply With Quote
Old 09-11-2019, 10:21 PM   #46
Lantanafrs2
Drives: 2013 frs red
I try to do my oil changes every 4k or so. Been on e85 tune for about 2 years give or take.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 09-11-2019, 11:36 PM   #47
DAEMANO
Time Traveller
40,000+ miles on e85.
zero issues.
DAEMANO's RAVEN FR-S
Phantom Electric Supercharged & Open Flash Tuned
Showa Evolution Spring/Shocks | WedsSport SA-10R | e85
Old 09-12-2019, 08:32 PM   #48
rikixass
rikixass's Avatar
Hahahah. SMH Nothing at all, mOve along.
... I found a Lucas product for e85 stablization. Recommended for every fill-up (i'm going every other) and safe for all mixtures. Green bottle #10576, I believe. I don't have it with me, it's in the whip. Anyhow, looking at thicker (Grimspeed) gaskets made of steal to arrive.
Old 09-13-2019, 07:11 AM   #49
Breadman
i toss in a squirt of injector cleaner every tank since i fill up almost weekly
Old 09-13-2019, 07:16 AM   #50
new2subaru
Drives: 15 FR-S
What about 100% Ethanol. Does anyone have experience with this?
Long term E85 use redrocket89 Engine, Exhaust, Transmission 83 01-13-2019 11:03 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 07:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
