Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 09-11-2019, 01:52 PM   #15
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by Butterman View Post
I don't think the base model shock has changed after 2017. FRS and BRZ have different shocks.
FRS has more compression in the front and less rebound in the rear.
The PDFs are from TEIN but I'm not sure who the data in the image is from. I haven't compared the two so I don't know how well the two datasets correlate. Which would be interesting to know if both datasets are from high quality machines.
The shocks definitely changed. Suspension over all is much more compliant and better damped, plus a thicker rear ARB. Hence the curiosity about the specific kouki dampers.
RayRay88 is offline   Reply With Quote
Old 09-11-2019, 02:16 PM   #16
strat61caster
Thread Killer
strat61caster's Avatar
Drives: '13 FRS
FRS, BRZ, and 86 base model shocks are the same given the same model year, they did change over the years
ineedyourdiddly
Old 09-11-2019, 02:32 PM   #17
scoobydrew
Drives: 2001 Subaru Impreza
Per the 2017 changes PDF, the standard (i.e. non-Sachs) dampers have been changed in the following ways:
- Optimized friction of front struts and rear dampers
- Changed damping force of front struts and rear dampers
- Changed structure of front struts and rear dampers
For front/rear shock internals:
- Changed rod guide bushing
- Changed piston
scoobydrew is offline   Reply With Quote
The Following 2 Users Say Thank You to scoobydrew For This Useful Post:
strat61caster (09-11-2019), Tokay444 (09-11-2019)
Old 09-11-2019, 03:19 PM   #18
FeRS
FeRS's Avatar
Drives: Raven 2015 FRS
- Changed piston
The stocks are already a little digressive, I wonder how/if they played with how it digresses.
FeRS is offline   Reply With Quote
Old 09-11-2019, 03:32 PM   #19
gtpvette
Drives: 2015 FRS - FFR GTM
Speedway Motors offers Shock Dyno Services,,, I had a set of Konis for the GTM done there.
https://www.speedwaymotors.com/Info/Shock
GTM - Still under construction - 2015 FR-S - 2016 Vette Z51
gtpvette is offline   Reply With Quote
Old 09-12-2019, 09:51 AM   #20
Butterman
Drives: 84 944 and 2015 brz
- Changed piston
can you provide a source? *edited because I mistakenly thought shocks were the same*
Butterman is offline   Reply With Quote
Old 09-12-2019, 09:56 AM   #21
RayRay88
can you provide a source? The part numbers for base model shocks haven't changed over the years.
https://www.ft86club.com/forums/show...&postcount=302
The Following User Says Thank You to RayRay88 For This Useful Post:
scoobydrew (09-12-2019)
Old 09-12-2019, 10:00 AM   #22
RayRay88
Directly from Toyota Parts:
FL Shock 2016: SU00305257
https://parts.toyota.com/p/Scion_201...U00305257.html
FL Shock 2017: SU00306793
https://parts.toyota.com/p/Toyota_20...U00306793.html
strat61caster (09-12-2019)
Old 09-12-2019, 10:14 AM   #23
Butterman
Deleted because mistaken.
Old 09-12-2019, 02:18 PM   #24
RayRay88
I should have clarified, the base model BRZ shocks have the same part number 2013+
That's a very interesting PDF. PDF you're referring to clearly states that the ARBhas changed size. I can see why they wouldn't make a new PN for the revised shocks but they would have to for a different rear ARB. According to the subaru parts catalog the ARBs are the same PN across all years though.
Front: 20101
Rear: 20451
I wonder if the toyota started using brz shocks...
No, even Subaru has different part numbers for the shocks from 2016 to 2017.
FL 2016: 20310CA130
https://parts.subaru.com/p/Subaru_20...0310CA130.html
FL 2017: 20310CA170
https://parts.subaru.com/p/Subaru_20...0310CA170.html
Rear ARB 2016: 20451CA010
https://parts.subaru.com/p/Subaru_20...0451CA010.html
Rear ARB 2017: 20451FG002
https://parts.subaru.com/p/Subaru_20...0451FG002.html
The numbers you posted are call out numbers in an assembly drawing, they're not the actual part numbers. The call outs are the same for all years because in terms of BOM/P there are no extra parts in that assembly. The parts department can do nothing with those numbers.
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
Butterman (09-12-2019), scoobydrew (09-12-2019)
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 08:40 AM
Shock dyno? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-30-2014 02:43 PM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
The 2nd Official Shock Dyno Thread Shankenstein Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 08-05-2014 02:57 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
