Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-15-2017, 04:27 PM | #15 |
Drives: 15 BRZ LTD, 05 FXT
I'm trying to capitalize. If I go hard on a 'sure thing' maybe I can get my RCG4's back, and a set of Electras.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
11-15-2017, 04:32 PM | #16 |
Drives: 2017 Series Yellow BRZ
I put the original post into google translate, than I tried several different languages, though I could not find Floridian.
Results: I installed KW coils and by doing this it lowered the car substantially which put in excessive negative camber. Since there is no rear camber adjustment on the BRZ I had to buy LCA's to correct the rear camber. When trying to find LCA's only 1 was listed for use on the 2017 PP cars on the websites Brembo brakes and LCA could not be translated in the same sentence. |
The Following 4 Users Say Thank You to Azzudien For This Useful Post: | arkanist (11-15-2017), Captain Snooze (11-16-2017), JazzleSAURUS (11-16-2017), soundman98 (01-09-2021) |
11-15-2017, 04:38 PM | #17 | |
Drives: 2005 Toyota Camry
The Following 4 Users Say Thank You to mav1178 For This Useful Post: |
11-15-2017, 04:58 PM | #18 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
11-15-2017, 06:28 PM | #19 |
I lowered mine an inch and was only out of limits -.4 deg on one side. Just bought the whiteline bushings, problem solved? Not going to track mine daily and need to adjust it all the time. Find one setting that works good and be done with it.
11-15-2017, 07:17 PM | #20 | |
Proud of BOXER
Drives: Subaru Boxer
The Following User Says Thank You to Clipdat For This Useful Post: | finch1750 (11-15-2017) |
11-16-2017, 05:26 AM | #21 |
Because compromise ®
Drives: Red Herring
I lowered myself 2 inches so I get those 6 inch stilettos to handle properly.
The Following User Says Thank You to Captain Snooze For This Useful Post: | x808drifter (11-16-2017) |
11-17-2017, 10:11 PM | #22 | |
11-22-2017, 04:24 PM | #23 | |
Drives: 2017 BRZ Yellow Spec Ed 1of500
Light Sensor Bracket
Well, I guess I was too technical in what I wrote. I will take that bet! If the rear camber arms you buy DO NOT have a bracket for the headlight sensor, You all have a problem in Houston. That's why my comment on the Verus arms ( See pictures) |
11-22-2017, 04:28 PM | #24 | |
What LCA did you use? Did they have the sensor bracket for the headlight sensor?? |
11-22-2017, 05:16 PM | #25 | |
LMGTFY
Drives: 13 FRS, 91 Miata
How your OP should have been worded then....
The Following 7 Users Say Thank You to x808drifter For This Useful Post: | Cole (11-22-2017), JazzleSAURUS (11-23-2017), JohnJuan (11-28-2017), soundman98 (01-09-2021), TofuJoe (11-23-2017), Tor (11-25-2017), wparsons (11-23-2017) |
11-22-2017, 10:25 PM | #26 |
Drives: BRZ 2017 Pure Red, MT
Not just the PP, but the BRZ limited (at least the 2017) also have the auto headlight sensor (don't know about the base version).
The Following User Says Thank You to nico_rsx For This Useful Post: | wparsons (11-23-2017) |
11-22-2017, 11:48 PM | #27 |
Drives: 2014 GT86
Stock alike like spc (and probably very similar whiteline & eibach) have attachment points for leveling sensor just like stock rear lca-s.
11-23-2017, 11:01 PM | #28 |
While we are on the subject, how can the level sensor continue to work with coil-overs? I mean even with aftermarket LCA, if you change the height of the car doesn't it change the angle of the LCA? If yes, then do you have a way to adjust the angle of the sensor according to the height you adjust the coilovers?
Similar Threads | ||||
2017 BRZ Performance Package DD Build | mjanmohammad | Member's Car Journals | 230 | 11-01-2023 12:31 PM |
2017 BRZ Performance Package C&D Lightning Lap | lynk26 | FR-S / BRZ vs.... | 27 | 10-04-2017 05:49 PM |
1slowbrz's 2017 wrb performance package | 1slowbrz | Member's Car Journals | 3 | 05-20-2017 05:03 PM |
WTB: OEM 2017 Performance package wheels | mjanmohammad | Want-To-Buy Requests | 1 | 03-03-2017 02:35 PM |
