Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
01-22-2014, 04:51 PM | #1 |
Less than pleased...
Drives: '13 BRZ Ltd SSM 6MT
Aftermarket rear deck shelf
Looking for replacement rear decks, but so far the only one I've found was Password: JDM's carbon fiber ones ( http://passwordjdm.com/PasswordJDM-D...8647C2559.aspx ) Anybody else make these? I'm planning on moving the third brake light so I'm looking for the ones with the delete.
01-24-2014, 12:34 AM | #3 |
Drives: 2013 subaru limited wrb brz
I have the passwordjdm carbon fiber one and it fits like a glove.
Portland 86ers |
The Following 3 Users Say Thank You to wrohdejr For This Useful Post: |
01-25-2014, 01:26 AM | #4 |
Drives: '13 Firestorm Base AT
I've considered doing my own recover of the rear deck. Moving the 3rd BL up to the top of the window, and sealing off that annoying reflection/light leak, and then filling the deck with foam, sanding as desired, and recovering with whatever material is suitable. Half considered putting some speakers back there, which I may still do, since I'm planning on using the QP spots for some small 8" subs. (Have them in, but not powered. too much rattlyness until I have $ and time to completely build a proper box and dynamat.) Just speculating some ideas if you are going to take it out, might as well just recover it and move that PITA light
11-28-2015, 09:07 PM | #5 | |
DrivinginDreams...Cloud86
Drives: Toyota GT86
Did you get the Optional Clear Coated Finish? Also wondering if this is pointless if I decide to tint the back window.
11-28-2015, 10:25 PM | #6 | |
If you tint it black it would be kind of pointless, but then again you would know it's there and if you want it get it. Yeah i had it clear coated because i knew it would have direct sunlight on it all the time.
Portland 86ers |
The Following User Says Thank You to wrohdejr For This Useful Post: | Chad86 (11-29-2015) |
12-22-2015, 02:07 PM | #7 |
Panda Trueno
Drives: No twin now.
Mine was reupholstered by a professional shop. Matching carpet and holes filled in. Looks factory and it was pretty reasonable for price.
Love not having the brake light in the window when I look in the mirror. |
12-22-2015, 02:42 PM | #8 |
Memphis
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Pics, or it didn't happen
"It's ok... It's not structural."- Mikey
12-22-2015, 02:43 PM | #9 |
Panda Trueno
Ok, it didn't happen. lol.
12-22-2015, 08:27 PM | #10 |
Drives: Scion FR-S Ultramarine
12-23-2015, 11:48 AM | #11 |
Memphis
03-05-2016, 11:16 PM | #12 |
Drives: Toyota GT86
I received my amazing product from PasswordJDM, but there is a minor dent in the carbon. I have e-mailed them twice with no response and the damage is near impossible to photograph due to the glossy finish. All I want is at least a discount. Should I just forget about it? I'm sure once it is installed I won't even notice it.
03-06-2016, 09:32 AM | #13 | |
Drives: 10 Series #974 6m/t
The Following User Says Thank You to NyC Zn6 For This Useful Post: | Chad86 (03-06-2016) |
05-02-2017, 11:38 PM | #14 | |
Drives: Toyota GT86
I have figured out how to remove the OEM shelf from the forums. Do I need to remove the OEM LED bar from the plastic housing and attach manually?
Similar Threads | ||||
Password:JDM Dry Carbon Fiber Rear Deck Shelf Subaru BRZ / Scion FR-S (Type I/ II) | password:jdm | Interior Parts (Incl. Lighting) | 124 | 01-28-2015 03:17 PM |
WTB: REAR window top Brake Light (just top half with leds) or full rear deck | Kayzer Soze | Exterior Parts (Aero, Lighting, Etc.) | 1 | 08-31-2013 02:23 PM |
eliminate rear deck popping with rear strut bar? | chenshuo | Issues | Warranty | Recalls / TSB | 11 | 07-03-2013 06:44 PM |
Good aftermarket Deck Unit with Navi?? | taimysho0 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-17-2013 07:55 AM |
P8400 Aftermarket deck HELP NEEDED WITH WIRING | iamkyle | Electronics | Audio | NAV | Infotainment | 1 | 01-13-2013 03:41 AM |
