Old 08-15-2017, 12:42 AM   #1
sw20kosh
Drives: 2013 Black FR-S
Camshaft angles going crazy
I have a built engine that runs great other than camshaft timing. The stock ecu would not control the cams even after changing all sensors, oil control valves, and ecu.
Decided to try a motec m150 and the m150 is able to control the cams partially... Most of the time the cam angles follow the commanded angle but when under moderate/high load bank 1 intake cam loses angle. Sometimes bank 2 intake cam loses angle shortly after bank 1. As for exhaust cams... bank 2 exhaust cam angle signal is also very noisy/erratic but it doesn't lose angle like the intake cams. I see weird noisy/erratic behavior during warm idle sometimes too.
The cam actuators/sprockets are from a 2013. I am just trying to figure out if this looks like a hardware or electrical issue. I am leaning towards replacing all cam actuators with brand new ones.
Have you seen any thing like this before?
Under load:
Regular driving:
Idle: (lambda goes erratic when cam does)
@nelsmar @Kodename47 @jamesm @Shiv@Openflash @steve99
Old 08-15-2017, 08:51 AM   #2
steve99
Drives: FT86
Yeah those cam issues are a real bummer.
looks like you have already replaced ECU so that pretty well rules that out
unfortunately that leaves
Oil control valves
CAM sensors or cam sensor clearance
Sprokets/actuators
Have you seen this TSB re checking clearance on CAM sensors.
Be worth doing/checking as its fairly simple and low cost
http://www.ft86club.com/forums/attac...1&d=1375302652
Then the other TSB for cam sprocket/actuator,oil control valves
Bummer its doing it on both banks else you could probably swap ocv from bank 1 to 2.
and as your motec the DTC wont be much help.
Obly other thing I could suggest would be check your earth connections to chassis and motor since you have had motor out. Bad earths can cause weird stuff.
Maybe check batt/alternator volts to see its regulating correctly alternator is controlled via ecu, fluctuating batt volts could cause weird issues, should be pretty stably around 14 during normal operation.
Old 08-15-2017, 01:36 PM   #3
sw20kosh
Oil control valves
Sprokets/actuators
I have changed all OCV's, cam position sensors, crankshaft position sensor, and ecu. Batt volts are stable. I will double check grounds and cam sensor clearance.
How much advance should the intake cam's be capable of? I am seeing both intake cams do not want to go above 38-40 deg.
Old 08-15-2017, 03:36 PM   #4
steve99
Drives: FT86
Not sure on the limits
The cam phasors may be capable a certain amount of advance but it may be limited in ecu not sure
some info here
http://www.ft86club.com/forums/showthread.php?p=1514207
http://www.ft86club.com/forums/attac...9&d=1391829861
Old 08-15-2017, 06:57 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's around 40deg advance for the intake cams and similar retard for the exhaust.
.: Stealth 86 :.
Kodename 47 DJ:
sw20kosh (08-17-2017)
GDI Angles and DI:PI ratios discussion OFT Nah Software Tuning 22 10-14-2016 12:41 AM
Crazy Good Deal or just Crazy MJones_RB BRZ First-Gen (2012+) -- General Topics 31 05-06-2016 03:22 PM
Buffing Difficult Angles on the Side of A Vehicle Junkman2008 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 04-22-2015 12:15 PM
Bad angles of this car. tzhu07 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 44 06-04-2014 02:12 PM
