go_a_way1
Old 10-18-2013, 02:25 PM   #2283
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Bu-Tang View Post
I would really also question the mid pipe, that second CAT I would say is more of the cause than the over pipe.
I think if there are any changes in store for my car (updates to the ESC or maybe a header), I will ask Moto-Mike to put my car on his dyno so I can see the results. Being that I have exhaust mods (and light weight wheels) I think my car will dyno well.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
fenton (10-18-2013)
Old 10-18-2013, 02:56 PM   #2284
fenton
I looking forward to @jpit result with Bob @Drift-Office. Maybe just maybe he can share some insight as to how to get some leaner AFR's between 2000 and 4000
fenton is offline   Reply With Quote
Old 10-18-2013, 03:12 PM   #2285
jamesm
Originally Posted by fenton View Post
Tune is unlocked.... For sure with brzedit, not 100 percent sure if you use a different program...he wasn't sure either.
Sent from my HTC One using Tapatalk
are you sure about this? i've opened a brzedit tune (saved 'for personal edition') in other software (tunerpro and romraider) and they're encrypted, just a bunch of junk data. actually won't even open in romraider because they change the value/location/both of the calid. this is with an 'unlocked' brzedit file, not a regular one.
now of course if you pull your existing brzedit tune off of your car with another tool that's all well and good i guess, as it's obviously not encrypted when written to the ecu. but if someone just sends you an 'unlocked' brzedit file you won't be able to edit it with anything other than brzedit personal edition (for $250). at least i wasn't able to.
Old 10-18-2013, 03:36 PM   #2286
Gary in NJ
Gary in NJ's Avatar
The lowest I've seen my AFR go (from my ECU) while under boost is 11.8:1. This is around 4000 rpm. Otherwise I'm 12.0 to 12.5:1. It's fairly stable too. I really need to get something that works with my ELM327 that I can do some data logging with so I can provide print outs.
Old 10-18-2013, 03:43 PM   #2287
fenton
Thats probably as low as it reads....certainly if it doesnt change from 11.8 you are lower than that.
Our car does not have a wideband. If you pin it at 2500rpm and you get a bunch of 11.8's you are running richer for what its worth
Old 10-18-2013, 03:51 PM   #2288
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Sojhinn View Post
Sure explain it all technically and make me seem like an idiot. If the smiley face didn't make it obvious I was joking around.
Well, you know what they say, "those who can, do. Those who can't, teach."
Of course the final line is, "those who can't teach, critique."
Old 10-18-2013, 03:52 PM   #2289
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Thats like a double whammy for me.
Installed Mods:
Old 10-18-2013, 04:08 PM   #2290
mid_life_crisis
I'm thinking there should be a fourth for the internet, "those who can't critique, troll."
That is not a shot at you, by the way. I'm looking forward to hearing how the whole Physics/Voc Tech thing works out.
Old 10-18-2013, 04:19 PM   #2291
Sojhinn
Sojhinn's Avatar
Yeah i know. I just loved the quote.
Installed Mods:
Old 10-18-2013, 04:30 PM   #2292
fenton
Updated post one at the end with yesterdays dyno session with the TQ300 compressor.
Old 10-18-2013, 04:40 PM   #2293
mid_life_crisis
@Robftss
MAF update plans? Seems to be a real weak link, especially with the larger compressor.
I'm bouncing in and out of the thread so I might have missed something. Anything in the works?
Old 10-18-2013, 04:46 PM   #2294
fenton
@Robftss
Problem is tuning the flow down low is hard... At least with brz edit. Bob seems to have it figured out with ecu tek. Toma didn't have enough time to play with it and figure out what worked.
Old 10-18-2013, 05:09 PM   #2295
Gary in NJ
Gary in NJ's Avatar
It does go lower. The AFR I gave before was where I engaged the ESC at 3000 to 3500 rpm.
I had to run some errands, and with this on my mind I thought I'd take a closer look at my AFR's.
Engaged the ESC @ 2000 rpm and the AFR went to 11.2. As I passed 4000 I saw it climb to 11.8. At 5000 it was at 12.2 and it stayed there until redline. I did several similar runs and got the same result.
I don't consider these too rich. It is my understanding that the target AFR at WOT (boosted) is ~12.0.
Under normal load my AFR's are running 14.5 to 14.7.
The Following 2 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (10-18-2013), fenton (10-19-2013)
Old 10-18-2013, 05:14 PM   #2296
bfrank1972
Drives: 2013 FR-S Argento
Once again impressive results! I'm not 100% a fan of actual whp numbers from dynos, especially with significant atmospheric correction, but I did some % diff numbers according to your baseline - were all those runs done at the same time/dyno?
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
