go_a_way1
Old 09-08-2016, 10:45 AM   #10137
pancake
Drives: 2015 BRZ Limited MT
Originally Posted by Urmyson View Post
I don't know, even if it came out to be 3k I would still be in because the install and removal is so easy. I've really been thinking about going SBD kit but it's a lot more work to install or remove. Really hoping there is a upgrade rather then an entire new kit though.
Yea, I understand that - I've looked into SBD install, and it looks like an 8 hour+ process; probably more for me because i've never done anything like that.
A 2 hour 'easy' process to install ESC is a big draw - i get that.
I'm excited for my name to hit the top - even if it is 5 years out...
pancake is offline   Reply With Quote
Old 09-12-2016, 11:07 AM   #10138
j_Zer0
Drives: Asphalt FRS 2014
After more than a year of flawless ESC operation my car wouldn't start this morning. Typical dead battery experience. The batteries don't seem to be totally dead because accessories are getting power... Not quite enough juice to fire up maybe? I'm guessing I should just replace the PC680 starter battery? I wouldn't have expected battery issues after only 15 months.
Sent from my Nexus 5X using Tapatalk
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 09-12-2016, 11:39 AM   #10139
fenton
The starter battery just isn't that strong. Any thing that is drawing power will kill the battery quite quickly, if you dont start your car every day or two then the smaller battery typically has trouble especially when it gets colder out.
I have had a dead battery 2 or three times this year and its always because i accidentally pop the truck some time during the evening. By morning it wont start simply because of the tiny light that is in the trunk.
fenton is offline   Reply With Quote
Old 09-12-2016, 11:41 AM   #10140
j_Zer0
Gotcha. Thanks Fenton. Do we have a current Battery Mart priority code? Looks like the one we used last year is expired.
Old 09-12-2016, 11:47 AM   #10141
donthaveoneyet
Drives: i don't own one yet, but i will...
put an LED in the trunk, will draw a lot less power
donthaveoneyet is offline   Reply With Quote
Old 09-12-2016, 12:25 PM   #10142
DAEMANO
Time Traveller
Anecdotally, I've had to change my starter battery once at about 18 months from Powersonic PSH-12180 to Odyssey PC-680. As a precaution, I started carrying a portable jump starter (like this one, but any brand will do, the more mAH the better) a few years back. They're compact work exceedingly well and make sure you can get things going in a pinch.
https://www.amazon.com/dp/B017CMMRAE?psc=1
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
j_Zer0 (09-12-2016), l0aded (11-16-2016)
Old 09-12-2016, 01:14 PM   #10143
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Do you have a metal jacket on the pc 680?
Installed Mods:
Old 09-12-2016, 01:49 PM   #10144
j_Zer0
Not that I'm aware of (although I'm not entirely sure what that means :o).
Old 09-12-2016, 02:01 PM   #10145
Sojhinn
Sojhinn's Avatar
When ordering the starter battery I recommend purchasing the pc-680mj. The difference between the pc680 and the pc680mj is literally a metal jacket around the battery.
The reason I recommend the metal jacket is that the over pipe is right below the starter battery. The pc 680s can be prone to heat issues. Anything that can help mitigate any heat issues is a smart move.
Installed Mods:
Old 09-12-2016, 02:05 PM   #10146
j_Zer0
Makes sense. The PC680MJ is only a few bucks more so definitely seems worth it. Thanks for the tip.
The Following User Says Thank You to j_Zer0 For This Useful Post:
Sojhinn (09-12-2016)
Old 09-14-2016, 02:46 AM   #10147
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I learned that the phantom frs from a stop sign will flat out walk away from a strange dark SUV that follows you through 3 random turns in back roads.. at least until he turns on his flashing blue lights, then I learned the brakes work pretty good too.
Apparently my OFT tune is running too rich and 1/4 throttle in 2nd gear after a turn is all it takes to puff out enough smoke to attract attention and look like im going 60 mph, when I never went over 35 (the posted limit). After telling him he scared the hell out of me, him checking my ID for warrants, and me informing him that I can't just call 911 if someone is following me because my work doesn't allow me to carry my cellphone or gun on the property, He kinda thought it was pretty funny and told me to slow down in neighborhoods. Oh and he liked my car; so I got that going for me, which is nice.
and just to get back on topic, I am going on 2 years now with the phantom and my starter battery hasn't died once.
The Following 2 Users Say Thank You to Target70 For This Useful Post:
Gums (09-14-2016), Sojhinn (09-14-2016)
Old 09-14-2016, 12:53 PM   #10148
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Hey all, long time no post.
Been more than happy with the FR-S and the ESC, love it!
The procede and OFT have been great to me as well, any new Procede maps and OFT tunes for CA 91 Octane gas and Automatic Transmission?
Also, last week or so I started noticing I wasn't getting much from pulls, if at all. Like I'll hit the activation RPM / throttle positions for the Procede and I'll get maybe a few seconds of boost and the readout will go from 28.5 to 18.0 and then it won't activate for a minute or so, even with the readout going back to 28.5 before then.
Any ideas on what I can look into / troubleshoot? I'm thinking either something with the Procede is off (unlikely, haven't had any issues with it since install and the wiring is in a spot where it's not going to get moved or anything) or the batteries are worn out / drained (possible, I have had a dead battery on a few occasions, due to not starting the car while working on it and my battery charger is old - any recommendations for a new one?), or the new android head unit I installed is too much of a strain on the alternator. (no clue, I doubt it though as everything else with the sound system is stock and I don't think my head unit would affect the alternator outside of startup)
Anyone have this problem where a setup that's worked fine for a year stops being as responsive / powerful as it once was?
Also what's the typical battery setup nowadays? I'm thinking just getting 3 PC 680s, is that still the recommended way of building your dump and starter battery setup? With two of them in series as dumps and then the third as the starter, correct?
Old 09-14-2016, 01:14 PM   #10149
Sojhinn
Sojhinn's Avatar
Most likely one of the dump batteries is out. Snag 3 pc680s (1 mj for the starter) and you should be good to go.
Installed Mods:
Old 09-14-2016, 01:27 PM   #10150
LucidMomentum
Good to know! Amazon Prime has them all available, I want the ones without the SAE Brass Terminals for the dump pack right?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
