07-10-2013, 07:40 AM | #85 |
I searched gates web site could not find a double sided belt in our length.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
07-10-2013, 01:05 PM | #86 | |
Did you look at the green belts with kevlar? Thats what I wanted but does not look like they exist.
07-10-2013, 05:21 PM | #87 | |
http://www.gates.com/oreilly/PDFs/SizeListings.pdf I found green stripped v-belts but no 6 rib green
07-10-2013, 05:45 PM | #88 | |
07-10-2013, 05:48 PM | #89 |
hahaha we have a gates 2 inch wide cog belt operation our wire forming machine at work. super hard plastic. cant wait to see your blue rb belt I have one on my 1.8t
07-10-2013, 06:02 PM | #90 |
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
does anybody know what could be the issue if my belt is just getting tore up? when I looked inside a lot of the belt shreds were caught up in the back centerish of my compressor. it's only getting tore up on one side of the belt, towards the rear of the car and my friend suggested it could just be the compressor sitting not close enough?
Obviously I need to change the belt so I might as well change the pulley too. does anybody have alternatives? I'm open for smaller pulleys too. |
07-10-2013, 06:25 PM | #91 | |
Turbowski and I will be dying in the heat doing a belt swap video.
The Following User Says Thank You to Dezoris For This Useful Post: | charged86 (07-10-2013) |
07-10-2013, 06:27 PM | #92 | |
The Following User Says Thank You to charged86 For This Useful Post: | Dezoris (07-10-2013) |
07-10-2013, 06:27 PM | #93 | |
07-10-2013, 07:15 PM | #94 | |
Thupercharged
Verify that the pulley below the discharge pipe that goes directly into the throttle body is good, and from there I would doublecheck the supercharger/bracket assembly mounting to make sure it is mounted properly
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
07-10-2013, 11:21 PM | #95 | |
Drives: 2013 BRZ DMG manual Limited
07-11-2013, 12:17 AM | #97 |
Winter Is Coming
this is what I pulled out, and the damage of the belt. I didn't get a picture of where it was collecting, I'll try to get that later.
07-11-2013, 12:18 AM | #98 |
Winter Is Coming
Similar Threads | ||||
Kartboy Crank Pulleys 95.00 | tom@kartboy | Engine, Exhaust, Bolt-Ons | 16 | 06-11-2013 01:06 PM |
Crank,Alternator,Waterpump Pulleys etc..? | fareastbrz | Engine, Exhaust, Transmission | 6 | 05-28-2013 08:46 PM |
Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 09:57 PM |
