Software Tuning Discuss all software tuning topics. |
01-21-2019, 12:44 PM | #1 |
Drives: 14 BRZ SWP
OFT Stage 1 Cold Start Stall
Hey Everyone,
I recently flashed to OFT Stage 1 V4.0. This morning the car stalled a few seconds after starting. The temp was about 10-20F. The stall happened when in was in neutral and let off the clutch, I assume the added load of the clutch disc, input shaft etc was a bit too much load for the engine a few seconds after startup. I noticed that the rpms immediately after startup are much lower than the OEM tune. Can I just adjust the cold startup rpms in RomRaider? |
01-21-2019, 01:59 PM | #2 |
Drives: brz 2017 hksv2
petrol or e85?
i don t think the clutch disc is too heavy for. the engine, the moment you leave the clutch the ecu "uses" a table that essentually pulls ignition timing, that causes the rpm at idle to dance around maf scaling is for a stock airbox, do you have something different? in romraider you can open the 2 maf compensation after start tables and raise the value on the 2 first rows they force the throttle to open a bit more |
01-21-2019, 04:34 PM | #3 | |
Drives: 14 BRZ SWP
93 Octane Gasoline (petrol) I'm not saying the clutch is too heavy for the engine. I think the idle speed is just too low for very cold weather. I'm on the stock air box. Would it be easiest to edit the Idle Speed Target (A-F) tables? |
01-22-2019, 04:23 AM | #4 |
you can raise a bit yes
but i think you ll be just fine increasing the 2 i told you |
Similar Threads | ||||
need help to lower cold start w/OFT stage 1 | vietspride70 | Software Tuning | 1 | 06-02-2021 03:17 AM |
re-enable cold start on OTS stage 2 plus | Laz84 | Software Tuning | 21 | 08-16-2020 05:04 PM |
ECU reset + warm start = stall | phrosty | Issues | Warranty | Recalls / TSB | 3 | 04-08-2018 06:31 AM |
E85 cold start | Turdinator | Software Tuning | 8 | 08-29-2014 11:12 AM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
