Old 05-12-2013, 11:35 PM   #71
Spidey
Spidey's Avatar
Drives: 2013 FR-S, '85 Corolla GT-S Hatch
It would still be nice to have the option...and with enough volume I think they can offer them around the $215 price range.
I emailed Beat Sonic and hopefully enough people will let them know that there is a market for something like this...
They could also make a cover as they offer now, but it won't sit as low as the G37's, due to the FR-S antenna being just over an inch high. Also, I think part of the design of the fin cover is so that coiled cable inside sits as high as possible.
Spidey is offline   Reply With Quote
Old 05-14-2013, 01:19 PM   #72
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
4" Perrin antenna. Looks great.
USMC is offline   Reply With Quote
Old 05-15-2013, 09:32 AM   #73
bobpuffer
bobpuffer's Avatar
Drives: FR-S Hotlava 6-speed
WE NEED
bobpuffer is offline   Reply With Quote
The Following User Says Thank You to bobpuffer For This Useful Post:
OICU812 (03-03-2014)
Old 07-20-2013, 03:26 AM   #74
drtepper
drtepper's Avatar
Drives: WRB BRZ Limited 6MT + 96 Camry LE
Update: So I was able to find a used FRS antenna on ebay and gut it. The connectors are the same, it's just missing one of the pins on the harness (leading to the XM antenna). Leaving the XM off, FM works alright, obviously way worse reception with such a tiny antenna nub (I only made a simple wire antenna that was about 2 or 3 inches long). I'll revisit the antenna I soldered into the circuit board when I actually need to. Basically, I get all of the radio broadcast in my hometown -- in HD, but not very much from SF (~50 miles away and over a hill or two).
I plasti dip sprayed the G37 shell flat black since I didn't have time to color match to WRB. I'll take care of that at a later time. It looks a little dusty, and that's probably because I need to rinse it off.
tl;dr: it can be done to a USDM BRZ, it's just a little more complicated.
drtepper is offline   Reply With Quote
The Following 3 Users Say Thank You to drtepper For This Useful Post:
FTEIGHTSIX (07-21-2013), M-17 (03-05-2014), unsurety (06-18-2014)
Old 07-21-2013, 10:37 PM   #75
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
[pic]
[pic]
[pic]
So you put the BRZ antenna chip and what not inside the FR-S one?
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 07-23-2013, 11:58 PM   #76
drtepper
drtepper's Avatar
No, the BRZ one for USDM can't fit in the g37 housing at all. I took the FR-S board and inserted it like the instructions from @Spidey. The FR-S radio plug fits in the BRZ terminal, you just lose SAT radio. You can always rip that out of the BRZ antenna and plop it in since only one of the two wires is actually connected in the FR-S wiring see:
This is the FR-S plug, the BRZ one is identical, but it has both ports filled; one for SAT and one for terrestrial radio.
The Following 2 Users Say Thank You to drtepper For This Useful Post:
FTEIGHTSIX (07-25-2013), J-W (04-04-2014)
Old 07-24-2013, 09:52 AM   #77
DIM
How come that fr-s antenna base has no hole to screw in the antenna?
DIM is offline   Reply With Quote
Old 07-24-2013, 10:08 AM   #78
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'll save @drtepper the time by saying it's not the FRS base, as he mentioned in the post just above yours. Only the guts of the antenna are from the FRS, the base is from the G37, and it's installed on his BRZ.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-26-2013, 01:51 AM   #79
drtepper
drtepper's Avatar
Yeah, as stated by @civicdrivr , this thread has boiled down to "How to migrate the insides of an FR-S antenna into a G37 base" . Unfortunately, there was no way to get a USDM BRZ radio board into a G37 base, so I had to get a FR-S antenna an use its smaller innards. -- That's all I was posting about.
Old 10-11-2013, 11:43 PM   #80
Cridland
Cridland's Avatar
Drives: 2013 Whiteout FRS
dont know if a toyota avalon antenna would fit but i walked past my moms car and its virtually flat, and it comes color matched to some vehicles
Cridland is offline   Reply With Quote
Old 10-12-2013, 01:13 PM   #81
Lonewolf
Lonewolf's Avatar
Drives: Moped
I still can't believe that no company has made this happen yet...
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
civicdrivr (12-03-2013), tbrocato (03-03-2014)
Old 12-02-2013, 01:02 AM   #82
636
636's Avatar
Drives: '23 CWP BRZ
Gonna bump this in hopes that it happens one day..
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
Lonewolf (12-11-2013)
Old 12-02-2013, 05:08 PM   #83
Marusich
Marusich's Avatar
Originally Posted by jedichimp View Post
Look at a new Corolla antenna
I wonder if this would be an easier swap.
Marusich is offline   Reply With Quote
Old 12-25-2013, 01:41 PM   #84
Lonewolf
Lonewolf's Avatar
Drives: Moped
@beatsonic @VisualGarage....anybody-make this happen!
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 03:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) -- General Topics 4 06-20-2012 12:25 AM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-04-2012 11:44 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 07:46 PM
