09-20-2015, 08:53 PM | #309 |
Im thinking of pairing this with the 2.5" JDL ultra quiet front pipe, would i have any fitment issues? And for the Rear Flange should OEM Style Donut Gasket or the flat flanged??? the rest of the exhaust is STI axleback and OEM midpipe.
https://jdlautodesign.net/shop/ft86-...et-front-pipe/ |
09-20-2015, 09:14 PM | #310 |
Drives: GTS 86
OK, after I did some driving I can say that this header sounds and performs fantastic.
1. Installation - easy to install and despite my concerns regarding the overpipe fitment, it just goes in there perfectly. I dare to say that it was the easiest over pipe I have ever fitted.- note: fit the over pipe first from the front of the car towards the back and then fit the header. 2. Sound - at first it sounded like any brand new header - shit and like something is broken inside, but after about 100km with it on it started to tame a little and sound is quite nice...more "mature" yet race like. Hard to describe it but I like it. I have evo3 cat back and it sounds really growly when you put your foot down. 3. Performance - I cannot express my amazement with how this header performs. From 1500-2000 up it just picks up like nothing else. I have OFT tune on them tweaked by master Wayno and it is fantastic. (I will upload the new map soon). I need to replace my clutch soon hence I didn't give it hell, but once I do...I am going to give it a good run and provide you with a video and dyno! Up until then...I am happy. |
09-21-2015, 12:22 AM | #312 | |
Drives: GTS 86
09-21-2015, 12:31 AM | #313 | |
Drives: SWP BRZ
I think he might be asking if you had the 150, 250 or 350 over pipe.
The Following User Says Thank You to PandaBRZ For This Useful Post: | Hawk77FT (09-21-2015) |
09-21-2015, 12:31 AM | #314 |
Drives: '13 SSM BRZ Limited 6MT
I was wondering if you got the 150,250 or 350. Your description of increased torque at 1500rpm is quite enticing !
09-21-2015, 12:34 AM | #315 |
Drives: GTS 86
09-21-2015, 12:57 AM | #316 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
09-21-2015, 12:51 PM | #318 | |
Senior Misanthrope
If you plan to keep the STi axleback and stock midpipe, then you need the JDL FP to be set up for a donut gasket. If you later switch the midpipe or get a different catback that requires a flat flange, it's easy to convert the donut gasket fitting from the JDL FP to a flat flange. |
09-24-2015, 03:57 PM | #319 |
Drives: 2013 FRS
Wow that sounds great! Need to start saving the pennies for this
09-24-2015, 04:03 PM | #320 |
Drives: Subaru BRZ / Toyota 86 Experts
Some heads up. Type-A 4-2-1 is exclusive to us and we have a limited number set now.
Type-B is a great option with a slightly different converging angle and slip joint welded setup. The first Type-B we had shipped over got sold within minutes. |
09-24-2015, 04:06 PM | #321 |
Drives: 2013 FRS
If I rock your sticker again do I get a complimentary Ace header?
09-24-2015, 04:08 PM | #322 |
義理チョコ
Which one's better?
Similar Threads | ||||
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
