Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-01-2017, 08:51 PM | #15 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
08-01-2017, 11:21 PM | #16 |
I have a Cosworth drop-in filter in my 2013 FR-S and, unlike others previously posting in this thread, I definitely felt like my car revved more freely than with the OEM filter. Cosworth has a fitment for 2017 cars, so I highly recommend giving it a shot.
08-02-2017, 01:53 AM | #17 |
Drives: 2014 GT86
Aaand again. Why bring up pre-MY2017 car as a supportive argument, if it's already been mentioned that one of MY2017 OEM improvements over those older ones is stock airfilter of less pressure drop?
The Following User Says Thank You to churchx For This Useful Post: | Dexter (02-12-2018) |
08-02-2017, 03:04 AM | #18 |
Understood and fair point - I sure hope the original poster reads this clarification, because it would be terrible if my misleading comments steered him wrong...
08-07-2017, 12:35 AM | #19 |
Drives: '14 BRZ
I have a '14 model and was planning to get a K&N drop in filter. But I read that it will run my engine run lean(er)?
https://www.reddit.com/r/ft86/commen...begin/dkzwzrf/ Can someone give me more insight on this? If he is right or not? |
08-07-2017, 03:36 AM | #20 |
Drives: 2014 GT86
Blue Bird: Drop-in filter shouldn't affect AFR.
What were mentioned in your linked post as doing that, were intakes, that has such shape/size/MAF sensor placement, that allows passing more air while making MAF sensor by it's stock calibration misdetect as lesser air volume, thus when ECU tune adds in fuel amount matching those mis-readings, result is leaner air-to-fuel ratio. More power, but also less knock safe. Better doing proper ecu tuning, not hacking-around. It happens though, that after proper tuning for new bolt-ons, taking into account changes to MAF sensor readings, large share of these "hackish gains" by artificial leaning ARR are diminishing, making those parts to add way less power, by price/performancy. There are also such intakes kits, that had goal when designed, to not change stock MAF sensor readings (IIRC Grimspeed & TRD ones should be such), but of course they have less "gains" with stock tune, thus may look less competitive. Changing filter to less pressure-drop/less resistive - leaves everything else stock. Airbox/inlet tube/MAF sensor placement. Even if air with everything rest being same can flow through easier, MAF sensor will detect that larger volume of air, and ECU tune will know to add more fuel in to reach targeted AFR. Last edited by churchx; 08-07-2017 at 03:48 AM. |
The Following User Says Thank You to churchx For This Useful Post: | Blue Bird (08-07-2017) |
12-24-2017, 04:13 PM | #21 |
Drives: Moped
It's a long shot, but does anyone have before/after dyno comparisons of stock 2017 mt car with stock filter vs. same car with any aftermarket filter? I know that 1-3 hp variations could be chalked up to a host of factors...just curious if anyone has any data
12-24-2017, 04:53 PM | #22 | |
btr.life
Drives: 2022 GR86
[ame]http://www.youtube.com/watch?v=2qY6YKnH8jI[/ame] [ame]http://www.youtube.com/watch?v=iWcGW-wlOEg[/ame]
The Following User Says Thank You to justinco For This Useful Post: | Lonewolf (12-25-2017) |
12-24-2017, 05:27 PM | #23 |
Drives: 2017 manual BRZ
I've done high flow drop in filters in a few cars and honestly one in the 2017 made absolutely no noticable difference compared to others. Wasn't surprised at all though considering the huge surface area increase over previous years for the stock filter.
Sent from my Pixel XL using Tapatalk |
01-01-2018, 12:09 PM | #24 | |
Drives: 2017 Toyota 86
01-01-2018, 12:37 PM | #25 |
I don’t get why we have dinky little air boxes any way on this car. The stock air box on the s2k was huge on top of that it was a massive cone filter. They should have adapted that or at least built off of it or improved it it could really help. O and no need for a stupid sound tube if you wanted louder sound you just take off the top cover to the air box now open ram intake
01-01-2018, 01:40 PM | #26 | |
Drives: frs
01-01-2018, 02:23 PM | #27 | |
Drives: Subaru BRZ
I had the HKS drop in filter until a few weeks back when I had the car tuned and replaced the HKS with a Takeda CAI. A tune and CAI is the way to go as the difference is amazing. |
Tags |
2017, air, filter |
Similar Threads | ||||
2017 BRZ MT Drop-In Filter | Drambeenie | Engine, Exhaust, Transmission | 23 | 03-03-2017 12:17 AM |
Need Help With Drop-In Filter | Ammunition | Engine, Exhaust, Transmission | 5 | 01-01-2014 03:29 PM |
Which dry drop in air filter? | DarkestBuddha | Engine, Exhaust, Transmission | 17 | 09-10-2013 12:41 PM |
DIY drop-in filter? | aceangel | Engine, Exhaust, Transmission | 18 | 04-25-2013 10:42 AM |
Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
