Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
03-24-2015, 10:18 AM | #15 |
Drives: 2014 FRS JRSC'd
Mine did too!
03-24-2015, 10:36 AM | #16 | |
Sweeper
03-24-2015, 10:42 AM | #17 |
1st86 Driver!
Good to know, but same cause. A lot of folks think that its a weight sensor and it isn't, which is the real point in the end.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
03-26-2015, 02:48 PM | #18 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Just to add some closure to this..
I picked up a spare FR-S passenger seat base from a wrecker and removed the occupant sensor from it. Being much more careful with the ribbon cables and also when separating the grey foam off of the seat foam, i was able successfully transfer it over to my Edirb 023 without issue. I must have damaged something during the removal of my original one, so if anyone else attempts this, be very careful.
Top Tier Imports - Check out my build journal HERE
06-24-2016, 08:17 AM | #19 |
Drives: FBRZS
Just wanted to revive the thread to ask these questions
Questions to follow: 1 - In order to swap my FRS to BRZ heated leather seats, I only need to swap the occupancy module from my stock seats to remove the chime? 2 - will the BRZ seats still deploy without the occupancy module swap? (Leaving in BRZ Occ module and living with the annoying chime. 3 - Leaving the occupancy seat alone and living with he chime could I use techstream to disable the chime or simply add a seatbelt on? Will the airbag still deploy? 4 - with the occupancy module stock FRS or BRZ - will either scenarios cause an airbag light? |
06-24-2016, 01:19 PM | #20 |
Drives: Fr-s
Emulators exist for other markets, surely it can't be rocket surgery to make one.
Maybe @Beastronix could produce something? Hell, if someone sends me a sensor I'll figure it out, if I get stuck I have an EE on staff that I could lean on.
06-30-2016, 11:18 AM | #21 | |
I can currently disable the airbag lamps, but I only do this for race prepped cars. I have no data at the moment that proves certain steps in this process actually switch the airbag deployment sensors. Also note this is all over CAN. Defeating everything over the network is my go to, but I'm not opposed to alternatives if they are needed.
09-23-2018, 02:10 AM | #22 |
demariners
Drives: 2015 Blue Subaru BRZ
Did anyone get anything working here. I am having the same exact issue. I have taken the occupancy sensor out and I can not for the life of my get the airbag light off and the Passenger Airbag enabled. Any suggestions would be greatly appreciated. I can not place these inside the seats I have so I need some way to bypass this or somewhere to "wrap it up" and make it work and think someone is sitting there.
Similar Threads | ||||
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
Defeating Occupant Detection Sensor | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-16-2012 12:48 AM |
Understanding the BRZ/FR-S/86 Occupant Detection Sensor | Turbowned | Issues | Warranty | Recalls / TSB | 13 | 08-27-2012 10:58 PM |
