Old 05-28-2013, 12:54 PM   #15
DIM
Has anyone with a FR-S tried this yet?
DIM is offline   Reply With Quote
Old 05-28-2013, 12:59 PM   #16
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
mezdup is offline   Reply With Quote
The Following 2 Users Say Thank You to mezdup For This Useful Post:
Prog (10-30-2013), switchlanez (05-30-2013)
Old 05-28-2013, 02:06 PM   #17
Xdragonxb0i
Drives: ex500r
Its a great post. Thank you for sharing
I have a OEM license plate mount for sale if anyone interest pm me.
Xdragonxb0i is offline   Reply With Quote
The Following User Says Thank You to Xdragonxb0i For This Useful Post:
shiumai (05-28-2013)
Old 05-28-2013, 05:21 PM   #18
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I threw mine in the trash and am going to use the grimmspeed license plate relocation kit once my vanity plates come in. 9th week now =/
CamryDS is offline   Reply With Quote
Old 05-28-2013, 06:33 PM   #19
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
I just did this. Turned out great! Thanks!
Perihelion is offline   Reply With Quote
The Following 2 Users Say Thank You to Perihelion For This Useful Post:
shiumai (05-28-2013), Sisko's_Baseball (12-30-2019)
Old 05-30-2013, 04:56 AM   #20
shirker
Drives: '13 Limited BRZ
Just ordered the magnets, thanks for the writeup @shiumai! Was looking for a relatively inexpensive, non-offset, and non-drill to mount my required front plates. This fits the bill perfectly.
shirker is offline   Reply With Quote
Old 05-30-2013, 07:50 AM   #21
smellslikecurry
Magnets ordered! Thanks for the innovative write-up. We're going to try this on our shop car and let you know how it holds up against the horrid New York streets.
smellslikecurry is offline   Reply With Quote
Old 05-30-2013, 09:42 AM   #22
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
hope it works out for you guys as well. as mentioned in my edited writeup above, the front bumper plastic mars at the slightest touch it seems. even it's just felt (which can eventually get dust or dirt caught in it). as you can see, i've taken the extra step to protect the bumper with vinyl and swapped out the felt pads to rubber/foam.
do post updates, pic and tips/improvements if you have any to add!
shiumai is offline   Reply With Quote
Old 05-31-2013, 08:43 AM   #23
soulstice
Drives: SWP BRZ LTD
I intend to try this out as well with a few modifications. Thanks for the great write up. Will post my results to this thread when I'm done.
soulstice is offline   Reply With Quote
Old 05-31-2013, 08:48 PM   #24
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Magnets Finally came in last night. I plan on having the BRZ stach' painted to match the body so hopefully I can get some body shop time in the next week or two ( along with some silver bits in the interior). I'll post some pics up when I have the time to get to it. BTW I did the through the hand test then went even further. They held through my wrist. These magnets are no joke.
Grymm86 is offline   Reply With Quote
Old 06-01-2013, 01:01 AM   #25
soulstice
Drives: SWP BRZ LTD
Originally Posted by shiumai View Post
2. Two DX04 1" x 1/4" magnets http://www.kjmagnetics.com/proddetail.asp?prod=DX04 Cost $5.83 each. These fit behind the bumper and are larger for more magnetic force.
3. Two DEH@ 7/8" x .2" magnets http://www.kjmagnetics.com/proddetail.asp?prod=DEH2 Cost $3.78 each. These fit into the OEM bracket mounting holes.
Is there any real need to use the DX04? The DEH still has over 20lbs of pull force and are cheaper. I think i'll just order 4x DEH since they are cheaper unless there is a reason I'm missing to get the larger more expensive one. If the magnets are as strong as you say they are I don't think looking a few pounds of pull force will make much difference.
Old 06-01-2013, 10:54 AM   #26
shiumai
shiumai's Avatar
if you look at the pull force, the 20 lbs is 'case 1', which is the pull force between the magnet and a steel plate. pull force is inversely proportional to distance, and it rapidly drops off the further the magnets are away from each other, so you're not getting the same pull force that you would if the magnets were touching each other. i estimated that the 20 lbs becomes about 8 lbs after compensating for the thickness of the bumper, the bracket, and the foam in between, based on the magnetic force charts. from what i understand, having the larger magnet does increase the pull force on the smaller magnet, vs. having both smaller, so that's why i went with a larger one behind the bumper and felt it was worth the extra $4.
The Following 2 Users Say Thank You to shiumai For This Useful Post:
Sisko's_Baseball (12-30-2019), soulstice (06-01-2013)
Old 06-01-2013, 04:20 PM   #27
soulstice
Drives: SWP BRZ LTD
Awesome, thanks for the physics lesson, that was helpful information. I'm ordering what you ordered right now.
Old 06-01-2013, 06:19 PM   #28
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by mezdup View Post
I just saw that episode last weekend.
[ame="http://www.youtube.com/watch?v=LOEaBpBRtcY"]Breaking Bad season 5 premiere: Jesse Pinkman explaining magnet - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=JDQOvzFetxs"]Beaking Bad - YEAH BITCH! MAGNETS! OH! - YouTube[/ame]
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
