Old 12-19-2014, 08:15 PM   #1
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Inexpensive DIY Big Brake Kit
So i was inspired by Swift996's wrx brakes to research Wilwood brakes, and I realized i could build a similar kit at maybe a reduced price. As stated in the linked thread, I do not intend for it to be a track monster. I just want a comparatively inexpensive, featherweight setup that would work well on the street.
I began by taking measurements of the wheel carrier and the stock rotors, which gave me a template for brackets that would mount Wilwood calipers at the appropriate location for the 2 piece rotor.
Some CAD:
Some FEA:
Applying 20000N force where caliper mounts to bracket. This corresponds to approximately 1.6g of braking decceleration, assuming 70% weight transfer to the front axle and a coefficient of friction of 1 between the road and tires.
Stress profile looks good, Al 6061 has a yeild strength of roughly 275 MPa, so we have a factor of safety of above 3, which is also great...
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following 8 Users Say Thank You to 200hp/tonne For This Useful Post:
CSG Mike (12-19-2014), DAEMANO (12-20-2014), fstlane (12-20-2014), hmong337 (12-21-2014), Jaden (12-20-2014), Joe-G (12-19-2014), SportInjected (12-20-2014), swarb (12-20-2014)
Old 12-19-2014, 08:23 PM   #2
200hp/tonne
Drives: Raven Fr-S
Wilwood forged dynalite calipers :
The Following User Says Thank You to 200hp/tonne For This Useful Post:
Old 12-19-2014, 08:41 PM   #3
200hp/tonne
Drives: Raven Fr-S
Failed prototypes:
These had wrong hole placements. The caliper was in such a position that the brake pads ended up 1mm outside the outer edge of the rotor.
Lasercut prototypes in wood:
Perfect. Revised the design a little to go back to the original shape.
Final brackets would be cut on a waterjet.
The Following 2 Users Say Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-20-2014), Joe-G (12-19-2014)
Old 12-19-2014, 08:44 PM   #4
200hp/tonne
Drives: Raven Fr-S
Final Product:
I will install these on the FRS tomorrow, Should be an interesting day...
The Following 7 Users Say Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-20-2014), DustinS (12-21-2014), fstlane (12-19-2014), hmong337 (12-21-2014), Jaden (12-20-2014), Joe-G (12-19-2014), Pat (12-21-2014)
Old 12-19-2014, 09:10 PM   #5
CSG Mike
CSG Mike's Avatar
I love projects like this!
Jaden (12-20-2014)
Old 12-19-2014, 09:26 PM   #6
200hp/tonne
Drives: Raven Fr-S
Forgot to add prices:
Caliper : WIL-120-6811 $125 X2 = $250
Rotor Hats : WIL-170-9206 $125 X2 = $250
Rotor Discs : WIL-160-0277 $33 X2 = $66
Brake pads BP10 : WIL-150-8850K $42
Brake lines : WIL-220-9288 $60
Brackets : $100
TOTAL : $768
The Following 4 Users Say Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-20-2014), hmong337 (12-21-2014), Joe-G (12-19-2014), shiro (12-22-2014)
Old 12-19-2014, 10:58 PM   #7
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Brackets : $100
TOTAL : $768
Cool project! Willing to share your design? I could probably get a bracket like yours cut up at work...
Unless you're in the business of selling the bracket/making kits?? Works for me too.
Joe-G is offline   Reply With Quote
Old 12-19-2014, 11:26 PM   #8
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I have an ESAB plasma / water jet CNC cutter at work and have been thinking about this for awhile now.
This and license plate relocation kits.
Cool Project. If willing to share design I could get literally hundreds of these made next week. Because of the holidays we have a production shutdown and are only doing projects at work.
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
Old 12-19-2014, 11:45 PM   #9
200hp/tonne
Drives: Raven Fr-S
Here is a snapshot of my design. Just replace the 8mm holes by 10mm and the 10mm holes by 12mm and you shall have a perfect part.
I am not in the business of making these brackets, not by any means.
I had a shop near work make them for me, so i can get them made again for anyone who wants a pair.
The Following 6 Users Say Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-20-2014), hmong337 (12-21-2014), Kiske (12-20-2014), Manji (12-20-2014), SomeoneWhoIsntMe (12-20-2014), Sportsguy83 (12-20-2014)
Old 12-19-2014, 11:56 PM   #10
200hp/tonne
Drives: Raven Fr-S
If you end up making money on these hundreds, could you send me a couple? The taper on the water jet cut screwed up the holes on one of my pieces (the guy stacked my 2 work pieces and made 1 cut), so my 10mm holes have to be 11mm on that one piece for everything to line up properly. I haven't done GD&T at all on this thing...
By the way, the piece is 3/4" thick.
Old 12-20-2014, 01:41 AM   #11
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
subbed.
Would be interested in some brackets.
Pooverdam is offline   Reply With Quote
Old 12-20-2014, 02:32 AM   #12
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Cool! I've always been meaning to get into the garage and start taking measurements, but these base measurements are SO helpful if one even wanted to make brackets for other calipers.
Should be pretty quick and easy to convert and fire off a DXF to the shop. I just wish it wasnt winter around here, otherwise I'd be so much more productive with the car lol...
Thanks again!
Old 12-20-2014, 02:43 AM   #13
DAEMANO
Time Traveller
Subbed and definitely in for a couple pair of brackets.
Old 12-20-2014, 06:20 AM   #14
Panman
Panman's Avatar
Drives: 86 GTS
Stopping performance vs Std Brakes?
Panman is offline   Reply With Quote
Inexpensive Exhaust! Squido3J Engine, Exhaust, Transmission 26 12-29-2014 12:39 AM
Inexpensive shocks dyno'd... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-09-2014 06:59 PM
Inexpensive wheel to fit Sprint Kit. Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 05-30-2013 10:04 AM
Inexpensive spare wheel Captain Snooze Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-05-2012 06:36 AM
Inexpensive NA power increase; how much? rice_classic Engine, Exhaust, Transmission 4 06-18-2012 07:19 PM
