Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
10-30-2018, 07:59 PM | #15 |
Drives: 2017 brz
I’m 47, 6’1” and 230 lbs. I sit in the car with my legs out side of it then swing my legs in one at a time. Pretty much the same process getting out just backwards. If I try getting in any other way it hurts my hip. When I drive my seat is two notches away from being all the way back and I drive with the back almost straight up and down.
10-31-2018, 05:25 AM | #16 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Lower weight is higher performance. Always have been, always will be.
Math is like Love, simple idea at first that quickly gets complicated
10-31-2018, 08:26 AM | #17 |
Only happy when it rains.
Drives: series.blue
I'm 6'2" and 320, and If I put the seat straight up my hair is also in the headliner. If your seat is all the way lowered, you might want to try and remove the slider mechanism etc and just bolt it to the floor, or get an aftermarket seat.
And I agree hip first is the best way to get in the car. I use the car as my dd and I love it. At the moment my commute is slightly above an hour both ways and the car is great. Leaning the seat back helps with the comfort for me. |
The Following User Says Thank You to why? For This Useful Post: | LoXodonte (11-02-2018) |
10-31-2018, 01:25 PM | #18 |
63 and amply proportioned here. Moderate arthritis in right hip flared up... enough to cause me to modify ingress and egress moves.
I prefer seat on almost the lowest setting. I raise the steering wheel, pivot in the seat so feet on ground and stand up. It helps to wear smooth sole shoes. Some of my textured ones would create just enough drag to get a yelp out of me. You need door completely open so a wide parking spot to do this. Either park in the boonies or get a handicap sticker. I have some scuffs by speaker but not much to do about it. Not ready for a Buick yet, although the previous gen Regal GT wouldn't be too bad. ... would it? |
10-31-2018, 04:05 PM | #19 |
Hypnocratic Missionary
57 5'11" 215lbs...I stick my right foot in...lower my bum to the seat and use my hand to help raise-pull my left knee-foot into the car...
Commute is 45 minutes...I find the car comfortable even on long trips. Issues: I would like the seat bolsters to squeeze me a bit less (yeah getting 15-20 lbs off would help I know) and getting my right leg comfortable. My right knee tires of resting against the console. Is there an aftermarket pad that I could mount on that side of the console? If I have my work boots on (in addition to safety glasses, gloves, bump hat, kevlar cut resistant arm sleeves, hearing protection and hair nets while actually at work...PPE's safety first you know...UGH) there is not much room for the clod hoppers down there in the foot-well to maneuver my foot and leg for comfort. |
10-31-2018, 04:08 PM | #20 |
friendly
Drives: 17' 86
Start squatting ass to the grass.
Solution to every problem. |
10-31-2018, 07:34 PM | #22 | |
humfrz |
11-01-2018, 12:05 PM | #23 | |
I have the opposite problem getting in and out due to a leg length under 30". I need to keep the seat pretty close to operate the clutch pedal properly so when I get in I have to pretty much go in backwards putting my right leg in as I plop down then bring my left leg in. Sometimes I rub the steering wheel hard but more often I squish the lower and side bolster and the fabric is starting to wear thin. Sometimes I'll think of it and move the seat back before I get out but I usually forget |
11-01-2018, 12:13 PM | #24 |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | alphasaur (11-01-2018), gravitylover (11-01-2018) |
11-01-2018, 12:30 PM | #25 | |
humfrz |
11-01-2018, 05:11 PM | #26 |
Drives: 2014 BRZ Limited
With regard to getting out of the car when fucking assholes park too close to your door, I can usually solve that problem by parking where the fucking assholes can't or just don't want to block me. That means parking in an end space with my driver's side door facing an island or just parking way out at the other end of the parking lot and walking a little further. When I lived in Louisiana, shitheads would intentionally park next to me way out in the back 40. However, I saw less of that when I moved to Texas and hardly any of it at all in Florida because Texas and Florida dimwits are simply too fucking lazy to walk another 20 yards to be an asshole.
Usually it works. Every now and then some piece of human excrement will block me in anyway. I carry bottles of water with me, and here in Florida there's usually sand nearby for their wet windshields. I've been thinking of maybe carrying Silly String for that instead. Or condiments. |
The Following User Says Thank You to extrashaky For This Useful Post: | g e (11-03-2018) |
11-01-2018, 08:32 PM | #27 | |
I wish I could get a swivel bucket, those things used to kick ass. My buddy had a 75 Cutlass with them and I loved cruising in that car.
The Following User Says Thank You to gravitylover For This Useful Post: | humfrz (11-01-2018) |
11-01-2018, 11:50 PM | #28 |
Drives: 2015 Scion FR-S
Is your seat all of the way down? If you look at the side of the seat there should be 2 handles: the rear most one is for angling the backrest and front one is for raising the entire seat up/down.
The Following User Says Thank You to Face_Plant For This Useful Post: | LoXodonte (11-02-2018) |
Tags |
back, commute, ergonomics, knee, seats |
Similar Threads | ||||
Additional considerations when boosting | 86 South Africa | Forced Induction | 10 | 12-28-2015 06:54 PM |
Considerations for a new car addition! | frX50z | Other Vehicles & General Automotive Discussions | 19 | 11-03-2015 11:17 PM |
Any ROM tuning dudes in PDX? | Tromatic | Northwest | 1 | 05-18-2014 01:29 AM |
calling all big dudes! | rthaanum | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-25-2013 04:06 PM |
