08-27-2012, 05:19 PM | #43 |
Drives: BRZ, Exige, Boxster
Boyo makes a couple nice HD cameras that use a single thing cable to go up to the head unit so that you can draw power there. Not cheap, but nice. Those might work well here.
I'm looking forward to a custom kit for this. Picking up my BRZ on Sat. |
08-28-2012, 02:20 PM | #44 | |
Drives: 2013 Subaru BRZ
I ended up running the power wire to the radio and tapped pin #3 which was radio ACC wire. I believe it was red but I dont remember for sure. This worked great and now the camera works perfectly with no issues.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
The Following 2 Users Say Thank You to Flat Black VW For This Useful Post: | Floggin Tires (09-01-2012), sparks (08-29-2012) |
08-28-2012, 02:31 PM | #45 |
Grip>Slip
HD cameras? Not that our head unit's display is capable of outputting HD resolution anyway, but what sort of medium is this HD video transmitted? Not sure we have component or HDMI inputs
08-28-2012, 02:42 PM | #46 |
Drives: Subaru BRZ
I hooked mine up to the remote wire which was going to my subwoofer anyway.
08-28-2012, 04:40 PM | #47 |
It's just a single RCA. They output an NTSC 680(H) x 512(V) picture and have a high quality CCD. Most of the cheap backup cameras use very low res cameras with crap contrast.
08-28-2012, 04:41 PM | #48 |
Grip>Slip
08-28-2012, 04:44 PM | #49 |
08-28-2012, 04:48 PM | #50 |
Grip>Slip
08-29-2012, 12:22 AM | #51 |
Drives: Subaru BRZ
Flat Black VW - I got into the settings menu but don't see an option to adjust the lines. What option is it under? Thanks.
08-29-2012, 08:11 AM | #52 |
Top of the screen should say Line Diag and lower left should have camera settings.
2013 BRZ Preimum #452 - Sterling Silver
08-29-2012, 12:15 PM | #53 |
Drives: Subaru BRZ
I wonder if I have a different software. When I go into the hidden menu I see three choices: Failure Diagnosis, Function Check/Setting and Service Information. None of the sub-menus mention the camera. Under the Function Check it gives an OK for rear camera but that's it.
08-29-2012, 12:25 PM | #54 | |
The Following User Says Thank You to sparks For This Useful Post: | BRZranger (10-13-2012) |
08-29-2012, 12:58 PM | #55 |
1337
Drives: 2013 BRZ WRB S/C
When someone gets to doing a DIY, can you word it extremely simply and show lots and lots of pictures? I always feel uneasy when tackling electrical projects, because I have very little experience with them.
Lots of pictures would be excellent, and say "plug this pin here, solder this here, cut this exact wire here etc". |
The Following User Says Thank You to djdnz For This Useful Post: | Vlad (10-02-2012) |
08-29-2012, 03:10 PM | #56 | |
I'll try to remember to "keep is simple stupid" when the write up comes
The Following 3 Users Say Thank You to sparks For This Useful Post: |
Similar Threads | ||||
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders | Nitro | DIY (Do-It-Yourself) Guides | 42 | 07-02-2016 11:10 AM |
Name that spoiler! (SOLVED) | WingsofWar | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 12-06-2014 01:22 PM |
BRZ NAV/DVD bypass | Scooby South | Electronics | Audio | NAV | Infotainment | 88 | 02-24-2014 03:41 PM |
how I solved my gilrfriend's problem with headrest angle | alexmotrix | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-08-2012 08:00 AM |
Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
