02-24-2015, 02:29 PM | #155 |
Drives: Scion frs
This might be a stupid question but how to you torque the filter to spec? In the past with other cars I have just gotten it hand tight and that was fine.
02-24-2015, 03:43 PM | #156 |
Sweeper
hand tight is fine..
02-24-2015, 04:29 PM | #157 |
Drives: Honda Fit
^As Koa said, usually hand tight is fine. My Honda filters have instructions on them as to how far to turn the filter beyond hand tight. In any case, we are not talking about a lot of torque here.
EDIT: You can always use a torque wrench on it if that makes you feel more comfortable about things. Last edited by Marrk; 02-24-2015 at 04:41 PM. |
05-26-2015, 04:53 AM | #158 |
Drives: GT86
I have a noob question, can someone post a photo of a dipstick and marked levels where should oil be?
05-26-2015, 06:46 AM | #159 | |
Drives: 2013 BRZ Limited
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
The Following User Says Thank You to CoupedUpSubie For This Useful Post: | Chaetagnath (05-26-2015) |
05-26-2015, 07:34 AM | #160 | |
Drives: GT86
Photo would be awesome. So I suppose oil has to be between those two holes, close to the upper one? |
05-26-2015, 10:34 AM | #161 |
Yes, between the two holes.
The Following User Says Thank You to CoupedUpSubie For This Useful Post: | GT86_PRAGUE (05-26-2015) |
05-30-2015, 02:06 PM | #162 |
Mentat
Drives: 2013 Scion FRS 6MT
Even though it has been a while since Toyota updated their part number for the FRS oil filter. I do not see the part number being post here. The part number is 90915-YZZS1 and it is only used by the FRS.
The Following User Says Thank You to Muaddib For This Useful Post: | Marrk (05-30-2015) |
07-30-2015, 02:57 PM | #163 |
Drives: Vortech Supercharged FR-S
Will the Dimple Magnetic Drain Plug work with factory crush washer?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
12-11-2015, 11:32 AM | #164 |
Native Texan
I tried to change my oil this morning and for the life of me I can't get the drain plug out. I'm using a 14mm socket wrench, it seems to fit fine, but I can pull on the nut so hard that the rest of my body moves and it still won't budge. Any advice on how to get this thing out?
Also, I'm putting in 5W-30 motor oil instead of OW-20. The manual says this is fine and so do other people I've heard from. Anyone ever have any bad experiences with this? |
04-09-2016, 09:09 AM | #165 |
Drives: 2019 Toyota 86 GT Manual Halo
I'm posting just to bump. Someone with knowledge please help this member out.
Sent from my SAMSUNG-SM-N910A using Tapatalk |
02-23-2017, 11:39 AM | #166 | ||
Sent from my SM-G920P using Tapatalk |
07-21-2017, 01:22 PM | #167 |
Senior gif poster
Drives: 2013 Asphalt FRS
Stupid noob question but what is the factory oil drain plug torque specs? For some reason I'm having a hard time finding it. I'm pretty sure it's 33ftp but I'd like to make sure. Thanks in advance.
07-21-2017, 01:28 PM | #168 | |
Senior gif poster
Similar Threads | ||||
Oil Change Questions | #87 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 06-28-2012 11:06 PM |
Color Change | Dark_Angle | Mid-Atlantic | 10 | 05-30-2012 02:00 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
I was able to change my pre-order. | nkrein22 | BRZ First-Gen (2012+) -- General Topics | 23 | 04-10-2012 04:16 PM |
Can SOA change my preorder? | Zaneman | BRZ First-Gen (2012+) -- General Topics | 8 | 04-08-2012 02:06 PM |
