Old 12-15-2015, 03:52 AM   #2493
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Originally Posted by mashal View Post
The FBM design is vta too, but I thought the bottom end would be plugged
If I remember correctly, it just basically points and vents to anywhere lol. I didn't really look at the instructions much. I would just connect it to a catch can, but make sure the catch can vents to atm
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 12-15-2015, 03:53 AM   #2494
FRS Johnny
FRS Johnny's Avatar
Originally Posted by BRZtoni View Post
took it to willow springs yesturday
thanks for the reliable turbo!
How was it! What psi did you use? I'm surprised the axles didn't break! You are pretty low!
Old 12-15-2015, 09:37 AM   #2495
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
it was really nice
i used 7psi to be safe, but holy moly i had so much fun.
being low at willow springs isnt an issue but i think i would of gotten a better track time if my suspension was more track ready lol.
the drive to the track but bumpy but worth it!
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 12-15-2015, 04:03 PM   #2496
FRS Johnny
FRS Johnny's Avatar
it was really nice
Nice!! Lets go when I get my clutch and tune!
Old 12-16-2015, 04:16 AM   #2497
FRS Johnny
FRS Johnny's Avatar
Is the fbm base tune safe to drive on? I'm still waiting on my clutch to arrive and install it. So I might not be able to get a tune until later.. I'm not pushing it hard, or wot at all. Most I've gone is 1/4 to 1/2 throttle. Just daily driving, with a few rolling into it here and there.
I logged a bit of driving and it recorded some knock like 1-3 degrees? Just wanted some input on people's thoughts on it.
Old 12-16-2015, 06:13 PM   #2498
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
the stock tune is only to get your car moving to get it properly tuned
you should be fine if your staying off boost but still get a tune ASAP
Flex Fuel Turbo BRZ
Old 12-16-2015, 09:08 PM   #2499
ftc~brz
Done
Drives: WRB BRZ
^what he said. it's a base tune, play it safe and fight the urge.
ftc~brz is offline   Reply With Quote
Old 12-17-2015, 11:29 AM   #2500
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The fact that you are logging it means you at least know what you are doing. As long as you realize it is meant to be a 7 psi basemap and as long as the AFRs are good, then I would have no issues with you going out and making some third and fourth gear boost pulls to test your installation and make sure everything is working properly prior to getting a proper tune, but you better have a boost/wideband gauge to monitor things during the pulls and stop if things go wrong.
Old 12-17-2015, 03:11 PM   #2501
FRS Johnny
FRS Johnny's Avatar
I've watched my boost psi and the highest its been is 5 because I'm not going wot. I watch all the numbers through the open flash tablet I had from before. So far boost and afr look good and normal.
Just waiting on the clutch to get here to install it before going to get a tune. The wait is killing me!
Old 12-19-2015, 12:00 PM   #2502
Tomahawk
Drives: 13 FRS
I'm new to the board but I'm also running a FBM kit �� Pleasure to meet you guys and I'm stationed in CA and frequently visit LA
Tomahawk is offline   Reply With Quote
Old 12-21-2015, 06:09 PM   #2503
zussypoo
Drives:
Hi guys. I had a local shop order the stage 1 kit from FBM, and there are numerous unevenness/warping at the flanges on the downpipe and manifold. I'm no expert, but the local shop, PSI in Tucson, AZ, absolutely refused to install the kit onto my car in its current state. What do you guys think? Does everyone's look the same when theirs arrived?
Link to the picture album: http://imgur.com/a/M3rPz
zussypoo is offline   Reply With Quote
Old 12-21-2015, 07:06 PM   #2504
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
No gooda! @FullBlown
Old 12-22-2015, 07:22 AM   #2505
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Did that come from FBM directly or someone else?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-22-2015, 11:31 AM   #2506
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We resurface them to seal on the sealing surface. It would not be a problem with sealing. We explained that some flanges are sometimes are not taken all the way down on the edges otherwise it would be extremely thin. We will be in contact with the shop who is doing the install.
FullBlown is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
