10-28-2015, 01:27 PM | #2465 |
Drives: Ultramarine FR-S
Could someone help me out? Looking for the Instruction/Installation guide. Full Blown Turbo kit Stage 1.
10-29-2015, 01:44 PM | #2466 |
Boosted
Drives: Not a supra....yet
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Kengo (10-29-2015) |
10-29-2015, 02:04 PM | #2467 | |
Drives: Scion FRS
The Following User Says Thank You to FullBlown For This Useful Post: | Kengo (10-29-2015) |
10-29-2015, 04:32 PM | #2468 |
Turbo E85
Drives: 13 wrb brz
driven 3K+ miles on my turbo kit so far so good
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post: | SoCal80six (10-29-2015) |
10-29-2015, 04:35 PM | #2469 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
http://www.ft86club.com/forums/showthread.php?t=96932 |
10-29-2015, 11:05 PM | #2470 |
Drives: RX-7 / BRZ
Hey guys!
Could the lack of torque increase between 5.5k-redline have a similar feeling to clutch slippage? Car feels 'dead' or 'lacking push' in 1st, 2nd, and 3rd gear just before shifting during WOT pulls. Can't comment in 4th, 5th and 6th gear as top speed it a big high to get away with on the freeway :P I can't smell any clutch slipping and my rpms's aren't shooting up/spiking. I'm guessing it is time for a turbo upgrade to get the last bit of the top end to feel as good as the bottom end?
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
10-30-2015, 07:09 AM | #2471 | |
Drives: Late 2014 Subaru BRZ
I like to think of the factory clutch as a toilet paper clutch. I wasn't impressed with it as a factory car and I'm sure as hell wasnt impressed when I took it off for the turbo kit install at 10k miles. Please don't use factory clutches on FI setups. You'll see alot of people on this forum trying to cut corners and we'll it's not worth it.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
10-30-2015, 11:48 PM | #2472 | |
Drives: RX-7 / BRZ
10-31-2015, 03:48 PM | #2473 |
Question: My car has a built 9.5:1 engine with FBM base kit. The light weight competition stage 4 clutch was put in the same time engine was built. My problem now is that the car occasionally stall out once a day or every other day when clutch in, similar to what other have experience with the bov issue. My tuner had gone high on the correction for lightweight flywheel, but it is still happening.
I had my car checked for small vacuum leak, the bov turned out was stuck closed by the powder coat. the shop cleaned the bov and mentioned that my bov spring was quite stiff. It took him 25 inch of vacuum to open it. I was under the impression that the spring was pre-installed in the BOV so I did not touch during the kit installation. Anyone have any insight? I picked the car up yesterday and it ran fine, almost had an instance that it nearly stalled and lights came on, but it revived itself. log didnt do much to help solving the problem when this happened. Thing is I had never had this problem before the motor was built. I was running stock clutch prior to building the motor. Is this the clutch's fault? or bov. or both. Please help . |
11-01-2015, 09:45 AM | #2474 |
Did you install a prolite flywheel or streetlite? Puck clutch or disc?
2014 Subaru BRZ
11-02-2015, 11:41 AM | #2475 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | Kiske (11-02-2015) |
11-03-2015, 09:33 PM | #2476 |
Drives: 2013 Scion FRS
I was wondering youre supposed to connect up the pte 39mm wastegate on the base kit with the gt2871r. I know the top port is vent to atmosphere.
Where exactly should the bottom barb on the wastegate connect to? Im trying to run direct spring pressure and the pte instructions say to connect it to the compressor hose barb on the turbo but there isnt one on the 2871r... Unless im blind Last edited by yo.dur; 11-03-2015 at 09:45 PM. |
11-03-2015, 10:41 PM | #2477 |
I used the recommended spot fbm said and that's the intake vacuum which your bov also shares.
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post: | yo.dur (11-05-2015) |
11-04-2015, 11:36 AM | #2478 | |
NASA SpecE30 Racer
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | Kengo (09-01-2016) |
Tags |
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
Similar Threads | ||||
AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
