Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-11-2023, 08:49 PM | #29 | |
Weight Weenie
Drives: 15 FR-S
Day 1 |
The Following 2 Users Say Thank You to new2subaru For This Useful Post: | Racecomp Engineering (09-12-2023), Spuds (09-12-2023) |
09-12-2023, 05:40 PM | #30 |
Drives: 2016 Scion FRS Release Series 2#439
Take Toyota’s service manual requirements with a ‘grain of salt’. They play it safe and replace many items which may not be at end of life. That’s why dealer serviced Toyotas last forever.
Regarding pads, consider Stoptech Sports for a great DD and occasional track day solution. I cannot comment on there autocross capabilities but do use them for DD-Lapping and am very satisfied. They last, don’t destroy rotors and they’re cheap!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
The Following User Says Thank You to Muskoka800 For This Useful Post: | Spuds (09-12-2023) |
09-12-2023, 09:52 PM | #31 |
Drives: BRZ 2023
I use ferodo DS 2500 on track, I got mine on Amazon for pretty cheap. They do the job and have lasted 20 mins sessions for me. I am new to the track, first year, so my needs were not demanding, I am also on factory PS4 tires. I am not getting 200tw any soon though, may be 4S (or S5).
I am planning to get CSG CP pads next though, to compare the life, road and track performance etc. As per as I ahve heard they last longer (twice) even if they cost double and also perform better. So seems like it saves the job of changing them once. For fluid I use Castrol SRF, it lasts longer (2x) and costs more (3-4x). I hate the bleeding job more than pad changes. |
09-13-2023, 03:45 PM | #32 |
The Dictater
Drives: '13 Red Scion FRS
Ordering OEM brake parts is a PITA apparently because all the sites seem to think there are 3 different parts that will fit unless you have a Subaru VIN and even then my guess is they are confused. Nobody seems to have mapped out what part numbers go to the US spec rotors, and the descriptions don't say anything about size, so I decided to order Centric instead.
As for the brake lines, there are apparently 3 options for 2013. Knowing build date seems to help, but then there are 2 options for rear lines on the same date. Took a chance on what seemed most likely based on similarity to the front PN. Idk it's $30. I'll report on the PNs if it works I guess.
Also: "Build Thread" |
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (09-13-2023) |
09-13-2023, 07:06 PM | #33 | |
¯\_(ツ)_/¯
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | Spuds (09-13-2023) |
09-13-2023, 07:09 PM | #34 |
義理チョコ
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
09-13-2023, 07:35 PM | #35 |
The Dictater
That is something I did not try. I didn't think AutoZone or NAPA would stock or order OEM Subaru/Toyota parts, it was my understanding that they would get an "equivalent" part, but usually at much greater cost than online distributors. Is my understanding incorrect?
This is specifically a problem with the Subaru/Toyota parts because they do not have good descriptions in some cases. If I wanted something "equivalent" I'd just hit up Rockauto or Amazon, which I did with the rotors. MSRP at a local dealership parts counter is way higher than what it costs online so I'd rather not go there if I don't need the part right away.
09-14-2023, 05:37 AM | #36 |
Drives: Toyota GT86
The oem pads kinda suck anyway. I found them to be pretty difficult to remove when pad swapping at the track and they can be noises at times. I did see others having the same issue on a Facebook thread awhile back.
I will be switching to a oem + pad for street usage at some stage
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
09-15-2023, 03:39 PM | #37 | |
Drives: '13 FRS - STX
Ordering oem online and picking up at the dealer on the way home from work or over to work on the car has been aces. Prices have been completely in-line with buying non-oem parts online + shipping. Like, I might spend less then 5% more vs. say exedy or bosch or ngk. I hate interacting with people too, but dealership parts counter people aren't working on commission, they've got access to a regional warehouse and whatever profit the owner targets and that's that. They're geeks too, guy was excited to hand truck out my shortblock lol. I learned this about 10 years ago buying Nissan parts when they had weird stuff in stock nobody else could get and were cheaper too. A couple dealers slap insane markups on their parts and I had one or two Subaru dealers require a Subaru VIN which I didn't have so I just went down the block to Toyota. |
The Following User Says Thank You to strat61caster For This Useful Post: | Spuds (09-15-2023) |
09-16-2023, 03:17 PM | #38 |
Here in Ontario Canada I have found Toyota parts are about 60% of what the Subaru dealers ask, for the same part. That said, the Subi dealer has some items in inventory (likely due to parts crossing between Subi models) while Toyota dealers rely on overnight supply from the Toronto Parts Distribution Ctr.
09-16-2023, 09:09 PM | #39 |
Weight Weenie
Drives: 15 FR-S
I've had the Toyota dealership have to fly stuff in from CA more than once.
09-16-2023, 10:02 PM | #40 |
義理チョコ
My Toyota dealership always has everything I need.
09-17-2023, 10:25 AM | #41 |
Yes, over the past year or so Toyota Canada had a major parts inventory issue and many parts had to come from Cali. I’m told they were changing computer programs/system which led to stock shortfalls. I imagine those who required urgent repairs were pissed at the wait for parts.
09-18-2023, 05:50 AM | #42 | |
Weight Weenie
Drives: 15 FR-S
Is your car ready for track yet? The break it done? |
Similar Threads | ||||
Spring shopping list | Ignore Your Doctor | Want-To-Buy Requests | 0 | 04-07-2019 11:56 AM |
FRS Engine Upgrade Shopping List | PapaJ | Engine, Exhaust, Transmission | 19 | 02-07-2019 10:35 PM |
Christmas shopping list | Ignore Your Doctor | Want-To-Buy Requests | 1 | 01-01-2019 09:11 PM |
Forged internals - shopping list help | ChrisD | Engine, Exhaust, Transmission | 22 | 07-19-2015 10:12 PM |
Shopping List : building a faster car! | Philly | CANADA | 8 | 06-28-2012 07:58 PM |
