Software Tuning Discuss all software tuning topics. |
09-30-2016, 07:35 PM | #1 |
Drives: 2013 Scion FRS, 1985 Toyota Supra
OFT Stage 1, Newb Questions
Just installed a stage one OFT for 93octane fuel. I may be noticing more engine noise, not intake noise, badddd engine noise. Or maybe I'm just listening to it more carefully since I've installed a tune. Is this tune safe? My LTFT is around - 7%, isn't that a little low? I've got an Injen cold air intake that claims to be tuned and has a little tube bypassing the MAF sensor, could that be messing up my fuel trim? Also, I noticed on the data log on WOT the parameter only reads 97% and there's about 1/8in of dead spot at the beginning of the pedal, is there a fix for that? Already went through ignition cycles to hopefully re-learn it, but to no avail. This is my first time tuning and I have no idea what to look for.
The Following User Says Thank You to wyatt263 For This Useful Post: | aagun (10-03-2016) |
09-30-2016, 07:48 PM | #2 |
Drives: frs
Dead pedal will gone soon, let the ecu learn parameters.
Noise can be valvetrain |
09-30-2016, 08:07 PM | #3 |
Drives: 10 Series #974 6m/t
When I first tuned my car with the OFT I also noticed an increase in sound as well. Vtec just kick in yo..
The Following User Says Thank You to NyC Zn6 For This Useful Post: | tinma (10-05-2016) |
09-30-2016, 08:12 PM | #4 |
Drives: SWP BRZ
You're hearing the more aggressive valve timing from 3-5k RPM.
10-01-2016, 09:36 AM | #5 |
Huge E85 fan!
Drives: 2016 Scion FRS
-7% at idle is nothing to worry about. But check LTFT after a couple hundred miles when ECU has learned the new trims. It sounds like you haven't put that many miles on so what's your total fuel trims (LTFT + STFT) at idle and at 2500 RPM? At stage 1 at idle mine were around -5 or -6, less negative at 2500 RPM
The extra noise I heard at stage 1 seemed to be in the torque valley RPMs. I figured the tune was changing the cam timing to compensate for the torque hole. I'm not sure though, I have no way to verify. But when you tune, sounds change. When you have an intake, you hear the new sounds louder. Don't sweat it. At stage 2, there's a whole different set of noises to fret over! |
10-01-2016, 09:51 AM | #6 | |
The Following User Says Thank You to D_Thissen For This Useful Post: | tinma (10-05-2016) |
10-01-2016, 10:19 AM | #7 | ||
Use this procedure to get rid of the dead spot after re-tuning. Always works for me. Quote:
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | aagun (10-03-2016) |
10-02-2016, 10:01 PM | #8 |
Drives: 2015 86 GTS
Less than 100% throttle at WOT is completely normal for these cars.
You need to read some of the OFT tips and tricks posts. All will become clear . |
11-01-2016, 01:50 PM | #9 |
Drives: 2013 Silver BRZ
I just tuned my car with the OFT to stage 1. I have a perrin CAI, and a perrin catback. I noticed what sounded like a terrible engine noise right around 4000 RPM. It sounded bad like the original poster said. I thought it was related to the intake perhaps. Flashed back to stock and it is gone. So this raspy, almost grinding loud noise is normal??? Will the stock airbox continue to produce this sound if I put it back on?
11-01-2016, 02:35 PM | #10 | |
11-01-2016, 02:57 PM | #11 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
slap a header on it and flash stage 2 tune....that noise will go away!
11-03-2016, 04:36 PM | #12 |
Dragon King of Jupiter
Drives: 2016 BRZ Hyperblue
Noise is still there with stage 2. Can confirm. Just not as loud.
Similar Threads | ||||
Exedy Stage 1 Failure: Advice + Stage 2 Questions | Pneub | Engine, Exhaust, Transmission | 4 | 07-18-2016 09:24 PM |
A Newb to shifting and did a MTEC install questions | YamahaR86 | Engine, Exhaust, Transmission | 7 | 09-10-2015 06:29 AM |
newb questions about 2015 frs touch screen HU | red05five | Electronics | Audio | NAV | Infotainment | 3 | 06-08-2015 10:58 PM |
A couple of newb questions sorry.. | tzbang | Forced Induction | 14 | 11-02-2014 09:33 PM |
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 | Astroboy | Forced Induction | 4 | 03-01-2014 07:29 PM |
