Tracking / Autocross / HPDE / Drifting What these cars were built for! |
06-13-2012, 01:08 PM | #43 |
Drives: 2013 Subaru BRZ
I autocrossed with a full tank this past weekend. tire pressure at 38psi in the front and 35psi in the rear. dry pavement with all trac off this time haha.
Managed 5th place PAX and 13th place Raw. Not to bad considering I was only 2 seconds off the fastest time of the day and 7 of those ahead of me were about .005 between them.
2013 SWP Subaru BRZ. First in Alaska
06-13-2012, 08:32 PM | #44 |
Drives: Hydra EMS Powered FRS Raven Black
I'm pretty sure the rev limiter is a throttle cut which is what most of the DBW cars do and not a fuel cut. When we finish the Hydra EMS computer we'll use a tradition ignition cut cycling through the cylinders so you can stay on the rev limiter. This was also killing me when road racing.
Even on slick tires I never experienced fuel starvation even when the fuel line came on so I'm very happy about that. The grip level is so high I'm really worried about oil pickup starvation but it seems without a boosted motor the oil is just not collecting in the heads as badly as the STis do. I noticed no oil loss from all of the racing sessions where even a stock STi would have drank a quart of oil. |
The Following User Says Thank You to Element Tuning For This Useful Post: | Scooby South (06-13-2012) |
06-13-2012, 08:51 PM | #45 |
Conedancer
Drives: 2013 Subaru BRZ SWP
I wasn't on the rev limiter..but I understand what your saying... What kind of gains are you targeting for the Hydra..for our cars.... Very interested..
-needs to be able to raise the Rev-limit -needs to tune out the AVCS Crossover point. -make the throttle response 'Snappy'...not flat -hopefully have some HP gains and esp. notable Torque gains -Selectable maps for different fuel conditions... E85??? Thanks Phil..
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
06-13-2012, 09:10 PM | #46 | |
For NA: Need to raise the rev limiter. The engine is still pulling when the throttle shuts down. I would say on the base maps I'll raise it +500 RPM for the soft rev limiter and a littler higher for the hard cut rev limiter. The intake and exhaust cam cross over is terrible on Subaru engines and it's tough to tune out but I have had good luck along with finding some high rpm power with the STi motor. Hopefully I'll have the same success here. The latest Hydra 2.7s have a much faster throttle than the OEM ECU. You can punch the throttle and it does nothing but when it does go it's exaggerated OEM. The throttle plate will move faster with the Hydra and the throttle will be linear. If you put in 30% you get 30%...very important on a race car. I'm thinking the hot lick is going to be an E85 kit (injectors, fuel pump, flex fuel sensor) along with the Hydra's Flex Fuel Sensor support. This way map switching between fuel and E85 or any combination will be automatic. Also I'll tweak our Hydramist water/meth injection system (integrates fully into Hydra, automatic map switching when on or when a fault is detected). Typically on the boosted cars when boost is kept the same we can pick up 20-25 whp with the water/meth injection and I've even gotten gains on top of E85 using it. I'm shooting for +35 whp with Hydra, E85 (or race gas) and Hydramist. |
Similar Threads | ||||
Bored to death, give me some movie names! | 82mm 4g63 | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 03-07-2013 03:02 PM |
Autocrossed FR-S at Scion FR-S First Drive Event in Baltimore! | jackoskate | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 05-08-2012 07:45 AM |
Which would you give up? | ant08 | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-31-2012 04:32 AM |
Let's give $1 to the first total'd FRS owner | miata | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 01-06-2012 11:00 AM |
Give Sabine Schmitz the FT86 for some Nürburgring action | Andy | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-21-2011 02:51 PM |
