Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-09-2016, 09:47 PM | #15 |
Drives: 2013 Black FR-S
ACE
02-11-2016, 11:56 AM | #16 |
Drives: 2015 Ultramarine FR-S AT
02-11-2016, 04:16 PM | #17 |
02-11-2016, 04:30 PM | #18 |
03-18-2016, 03:14 PM | #19 | |
Drives: 2005 Toyota Camry
One problem so far is the lack of a decent front pipe setup that allows for complete freedom in choosing catless header w/ any exhaust of your choice. If you don't care about sound, that's fine, but many (young) people nowadays live in apartment or condo complexes that ban loud noises that a catless header may bring. I am trying to help find solutions. http://www.ft86club.com/forums/showthread.php?t=103125 -alex |
The Following User Says Thank You to mav1178 For This Useful Post: | Mr.Impreza (03-18-2016) |
03-18-2016, 03:21 PM | #20 | |
Not a troll
Good for you that you're trying to find out sound levels and shit. I don't really care to be honest. The way to go about that is get whatever you want from the header to FP, then get a quiet catback. |
The Following User Says Thank You to Cole For This Useful Post: | go_a_way1 (03-18-2016) |
03-18-2016, 03:22 PM | #21 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
^ this!
03-18-2016, 03:26 PM | #22 | |
His original question was why there was so little information. The cost is one reason... but again, absolute power gains is not everything. As for your point on quiet catbacks, I'll be testing some combinations of quiet catbacks that would sound horrible w/ catless headers. Source: I used to have a quiet catback until I put the Berk front pipe on the car. With a stock header. -alex |
03-18-2016, 03:33 PM | #23 | |
Not a troll
All I said was going with a known quantity is probably better than something unknown. Sure, we aren't building all out track cars, or chasing every last HP/Tq. But, if you're spending the same kind of money as the "best" header on the market, why the hell wouldn't you go with that? I truly do not give a flying fuck about the point you're making. Coming up with a "counter argument" about something that wasn't even mentioned in the first place. By all means, carry on with your sound testing. Myself, and many others will continue to buy the parts that we want to, and make sacrifices to have them. |
03-18-2016, 03:45 PM | #24 | ||
The entire header is certified as street legal in Japan. By that, I mean they have subjected both the ZC6 and ZN6 chassis for emissions testing. Each kit comes with the certificate as tested for both cars. Just spent 10 minutes carefully reading the instructions that it is supplied with... The kit comes with an O2 extension, so there is an O2 sensor before AND after the catalytic converter on the front pipe. A secondary wideband O2 bung is welded on the header and a plug is supplied. Obviously this does not apply to US market nor do most people that want to be unrestricted by header options, but it is definitely different. As for what is different about this vs Ace: this header is certified 100% for street use in Japan, bolt-on as-is without any need for ECU tune. The Ace header is not, primarily because there is no before/after catalytic placement for the O2 sensor and that will trigger an ECU fault code. To each their own. -alex |
The Following 2 Users Say Thank You to mav1178 For This Useful Post: | Kestrel (03-19-2016), Mr.Impreza (03-18-2016) |
03-18-2016, 04:45 PM | #25 |
Drives: 2014 GT86
So there is chance for this header to be one that should never trigger CEL?
edit Hmm, from googled up pics and specs i somewhat doubt that single HF cat in frontpipe will be sufficient and won't confuse stock tune for CELs to never happen. So wondering what is included in that certification. Last edited by churchx; 03-18-2016 at 04:55 PM. |
03-18-2016, 05:05 PM | #26 | |
03-18-2016, 05:12 PM | #27 | |
The second O2 sensor is placed downstream after the cat, so it can still verify before/after. I should note that the second O2 sensor placement has a much smaller opening, similar to those O2 extension inserts that cheat ECU detection. I am assuming that this cat is less efficient than factory and there is still a possibility of ECU code being triggered. According to the copy of testing included with the header, the setup is about 2x as much emissions as factory at cold startup, and about 50% of factory emissions when warmed up. -alex |
Similar Threads | ||||
Offical Gruppe-S UEL Header Install & Review Thread | continuecrushing | Engine, Exhaust, Transmission | 313 | 06-11-2023 03:54 PM |
Header & Overpipe compilation thread | ichitaka05 | Engine, Exhaust, Transmission | 88 | 01-26-2021 09:33 AM |
ACE 4-2-1 Header open source tuning thread | Wayno | Software Tuning | 15 | 03-07-2016 04:57 PM |
Yes, another Borla header thread. | m.wood0213 | Engine, Exhaust, Transmission | 36 | 10-03-2013 12:11 AM |
