Tracking / Autocross / HPDE / Drifting What these cars were built for! |
03-18-2019, 12:02 PM | #15 |
You don't need to use an impact, but this is the quickest and easiest way. Many shock manufacturers specifically tell you not to do it, but then again, it's also pretty much the only way without a collection of tools most people do not have. If you have the right tools, you'd be using a crows-foot on a short bar to hold the shock shaft where it's keyed, and then torquing the top nut with a torque wrench. On some shocks you can use an allen key through the center to hold the shock shaft while using a pass-through socket set to tighten and torque the top nut, but on some shocks this damages the internals.
The impact, if not misused, is actually the most effective and safe way to do it. You need to "pulse" it on, not just wail on it. I don't have MCS shocks, so YMMV. |
03-18-2019, 12:37 PM | #16 | |
Drives: '14 FRS TT5
[ame]https://www.youtube.com/watch?v=IvbLCFpWCog[/ame] Using the stock top mounts crossed my mind, but I don't have the spring perch adapters to work with the 60mm coilover springs. I'm guessing that I'll be fine without adapters though if it's just for troubleshooting purposes. I might have to try that tonight.
Follow my NASA TT5 build here: JHill Motorsports
03-18-2019, 12:40 PM | #17 | |
Drives: Subaru BRZ
I know and I ignore this recommendation and so does Vorshlag. You can use an impact just need to be careful with it. [ame]https://www.youtube.com/watch?v=2bab6x47CSs[/ame] |
03-18-2019, 12:43 PM | #18 |
I have MCS 2wnr that make a clunking from the rear since purchased new. I went through all the same rounds of troubleshooting you are: torque on all bolts, rear sway bar, top nut torque, upper mounts... nothing solved it. I attached a camera under the car to see if the spring was lifting off the perch during rebound but it did not look like there was any movement. I ended up sending them them back to MCS so they could have a look. They found nothing wrong or unusual during the rebuild. After the rebuild they are still making clunking noise. It seems to just be the way they are....
I do notice that set at max stiffness the clunking noise happens less frequently/loudly. I have Vorshlag rear upper mounts by the way. |
03-18-2019, 12:45 PM | #19 |
Drives: Subaru BRZ Limited M/T
Another thing to try is to jack up the rear, one wheel or both or just the suspect wheel. Take off the wheel and grab a second jack and jack it up to your ride height. Look at everything closely, see if any thing is hitting.
Try a GoPro see if yo can catch the issue that way. Sent from my iPhone using Tapatalk |
03-18-2019, 02:01 PM | #20 |
Drives: 2016 Scion FRS
A buddy of mine had this issue with the 2 way non remotes and it was the shocks themselves making the noise internally.
The Following User Says Thank You to steverife For This Useful Post: | TMF (03-18-2019) |
03-18-2019, 02:02 PM | #21 |
Installed coilovers, now I have clunks. Help!
I’ve heard that before. I do have an older set that I had rebuilt to 2WNR. MCS informed me that they had resolved this issue in the newer models.
The Following User Says Thank You to FastWhite For This Useful Post: | TMF (03-18-2019) |
03-18-2019, 02:12 PM | #22 | |
Drives: '14 FRS TT5
03-18-2019, 02:19 PM | #23 |
Site Moderator
Drives: Stuff
Yeah because most people just run the damn gun for way too long. I've never had a strut issue with a quick tightening zap over many dozens of dampers.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
03-18-2019, 02:41 PM | #24 | |
Yup, I use pass-through sockets. Cheap at the Harbor Freight. |
The Following User Says Thank You to ka-t_240 For This Useful Post: | TMF (03-18-2019) |
03-18-2019, 03:06 PM | #25 |
Drives: '14 FRS TT5
Yep, that's what I normally use too. However the MCS hex shock adjuster is on the top and you're not supposed to use the hex to hold the shaft from spinning. They typically recommend tightening with a wrench, and then whacking the wrench with a mallet or hand.
But like @Dave-ROR said, you apparently can use an impact as long as you're careful.
03-18-2019, 04:19 PM | #26 |
Drives: 4 wheels
I always hear noise with spherical rear mounts on all cars. Noise just transfer in the cabin easily.
03-18-2019, 04:23 PM | #27 | |
We had issues with a civic that we did full spherical on, it clunked like it had a wheel bearing out when you pushed on the wheels. Needless to say the company was using crap parts in their kits. Replaced with good stuff and noises went away. |
03-18-2019, 07:42 PM | #28 |
Drives: '14 FRS TT5
Alright, I did some more troubleshooting with the stock rear top mounts...the same noise is still there, albeit a hair quieter. I'm guessing that the OEM rear mounts (which have some rubber) isolate the noise a bit vs the all metal Raceseng's, but the same noise is definitely still there. I did inspect the lower mounting bearing on the shock itself, and it didn't seem to have any play. I also tried lowering the ride height...same noise. I tried removing the rear sway bar...same noise. It seems like the common denominator here is the rear shocks, so I might as well send them in. I'll also note that I did check the shocks without the springs on them, and they compress and retract smoothly and as expected.
To complicate things more, I also noticed some oil seepage on the front shocks. There is not a lot, but just enough to see it on the shock shaft, and my finger will pick up some oil residue at the collar where the shaft enters the housing. I'm double checking with MCS, but I'm guessing those will warrant further inspection and rebuild as well. At this point, I'm about ready to just send in all 4 for a proper inspection, rebuild and revalve to my new spring rates. This whole process reminds me why I left my FRS mostly stock for the first 3 years
Similar Threads | ||||
ABS and SAS came on after Coilovers installed | dattran86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-22-2018 12:08 PM |
ST coilovers installed | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 10-08-2014 01:22 PM |
ST coilovers installed | ThatManAnt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 07-23-2014 08:55 PM |
clutch/transmission noise and clunks... | slyphen | Issues | Warranty | Recalls / TSB | 7 | 06-26-2014 05:18 PM |
RS*R Sport-i Clunks | likebutter | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-13-2014 09:33 PM |
