04-15-2015, 12:04 PM | #239 |
Drives: 2013 BRZ 6MT
The dealer replaced my driver's side seal due to this issue. It's been about a year now and it still works ok but I notice the window itself is very slightly canted inward more than it should be - could be due to tolerances or even loose window track hardware. If the problem returns I'll take the door apart and inspect. Not a big fan of window indexing..
05-24-2015, 12:55 PM | #240 |
Power Ranger
Drives: 86
just purchased the autoglym vinyl and rubber care, hopefully that'll take care of it
Autofashion | FIVEaxis | Enkei
06-02-2015, 02:26 PM | #241 |
Hail Magnet
Just had this pop up on my car not too long ago--does anyone have the part # for the upper strip that we are all seeing get pinched or rolled? I can't seem to find it, although the answer is probably staring me in the face (that and I am lazy and don't want to read back through half the thread just to find it).
07-30-2015, 05:27 PM | #242 |
Drives: DAT Rally Blue BRZ
i've had this issue for a while, didn't know it could be replaced under warranty. i am getting wind noise and leaking on both sides. took it to the dealer yesterday, they didn't seem to want to replace it.
07-31-2015, 08:49 AM | #243 | |
Hail Magnet
A pointer: Make sure they realize that there is a upper (window) and lower (door) portion to the seal. I didn't realize this at first and they ended up replacing the lower seal (which I didn't need). If you can, show the service rep what happens as the window closes--it should slide over the seal, not catch and pinch it, which what was happening with mine. |
The Following User Says Thank You to HunterGreene For This Useful Post: | SuperDave (08-03-2015) |
08-03-2015, 04:53 AM | #244 | |
07-03-2016, 04:54 PM | #245 |
Drives: 2013 WRB Subaru BRZ Limited 2.0
Has anyone replaced the door seals themselves? I'd rather not pay the dealership $350 for something that's probably pretty easy to install... I just don't know how to properly do it haha
07-06-2016, 03:39 PM | #246 |
Drives: 2013 frs
You dont think the seals are just prone to doing this? Its seems inevitable. The way the windows suck into the car.
Has a lubricant/protector worked for anyone? I have this on both sides.
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
07-11-2016, 12:14 PM | #247 |
Drives: car
Dealerships don't have a TSB for this yet? Just checked an I've got the rust now.
08-23-2016, 04:19 PM | #248 |
So in my warranty it specifically states that weather strips are not covered under warranty and for that reason they refused to service it. Technically I still have a couple months left on my CPO but I feel like if they turned me away once, they'll turn me away again.
Any suggestions? |
08-23-2016, 04:23 PM | #249 | |
Hail Magnet
08-23-2016, 04:27 PM | #250 | |
The Scion CPO does state: "Covers any repair or replacement of components which fail under normal use due to a defect in materials or workmanship" So maybe bringing that up might change it? |
08-24-2016, 10:05 AM | #251 | |
Hail Magnet
08-24-2016, 10:09 AM | #252 | |
Yup there's damage, it's visibly warped, and it leaks. Both my extended protective warranty and Scion CPO warranty so conveniently exclude all weather strips from their coverage so it looks like I'm SOL. After an hour on the phone with Scion they said they would have a regional manager take a look at it, but I'm guessing they're coming up with their apology as to why they can't fix it right now... Sent from my iPhone using Tapatalk |
Similar Threads | ||||
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 128 | 02-27-2019 07:25 PM |
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | BRZ Photos, Videos, Wallpapers, Gallery Forum | 109 | 08-19-2014 10:56 PM |
Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 01:30 AM |
Studying for Learner's Permit driver's knowledge test | PACMAN | Other Vehicles & General Automotive Discussions | 2 | 01-02-2012 11:17 PM |
Little request: FR-S vs GT86 vs BRZ side by side photos! | EJ20 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 12-02-2011 12:53 AM |
