Old 12-26-2019, 11:21 AM   #183
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Did this on my car over the weekend, and doing it with a friend on his FR-S this evening.
It's way easier to do after releasing the engine/transmission mounts and jacking up each side of the engine. It takes <20 minutes to do and will make the rest of the job a breeze.
edit: followup - we did the entire job in just under 2 hours, from pulling into the garage to pulling out and including test starts for every plug. One little question I had, however. On both of our cars ('13 and '15), after doing the third spark plug (closest to the passenger), the car would start and then immediately stall out (over a few trials). We would re-do it, lower that side of the engine, and...it would work! My theory is that either I wasn't getting the coil pack on correctly for that particular plug, or that the engine doesn't like to be lifted up on the RH side (relative to the engine bay) on start. Has anyone else experienced this?
gkubed is offline   Reply With Quote
The Following User Says Thank You to gkubed For This Useful Post:
BRZ_88 (06-06-2020)
Old 05-19-2020, 04:48 PM   #184
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I'm at 35K, 5 years, according to the intervals, I am due..... well my plugs are due. Does the charge capacity in the plugs wear out over time?
Should I wait another 1-2 years till 50k-60k, or do it right meow?
Instagram: 86_Maul
ShadowReaper is offline   Reply With Quote
Old 05-19-2020, 08:25 PM   #185
soundman98
ProCrastinationConsultant
soundman98's Avatar
spark plugs are not like pizza. they don't go bad sitting.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Busybee (05-23-2020), Dadhawk (05-19-2020)
Old 05-19-2020, 09:07 PM   #186
1st86 Driver!
I didn't change my plugs until 120K miles when I had the spring recall done, and the one I saw basically looked new. Your wear may vary.
Dadhawk is online now   Reply With Quote
Old 05-20-2020, 05:03 PM   #187
ShadowReaper
Indulgent Tormenter
thats what I thought
Instagram: 86_Maul
Old 05-22-2020, 01:58 PM   #188
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Did mine at 50k and they looked perfect. So you can wait for sure. I would only change early if getting a protune, but even that is overkill.
Ernest72 is offline   Reply With Quote
The Following User Says Thank You to Ernest72 For This Useful Post:
ShadowReaper (06-12-2020)
Old 05-31-2020, 04:21 AM   #189
airrick
Drives: TRD R.S. 1.0 FRS
i would wait. Only times you should consider it unless youre at the interval would be if your car isn't starting up right away, misfiring, running weird, bad fuel economy, etc..
theres alot that problems that should be apparent when you got bad spark plugs.
i did mine at 62k and when i took off the old ones, they looked worn sure but still usable for probably at least 20k more miles so yea you should be fine.
airrick is offline   Reply With Quote
The Following User Says Thank You to airrick For This Useful Post:
Old 05-31-2020, 11:31 AM   #190
solidsnake11
Drives: brz
Good write up, there Scenic Driver ......thanks for posting ......
I think when my FR-S gets up to that point ..... I'll just trade it in .....
Oh, the "good old days", ...... just open the hood, climb in the engine compartment and change the plugs; a 5 minute job.....
humfrz
10 min for me!
hours to change. Before pic
solidsnake11 is offline   Reply With Quote
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post:
humfrz (05-31-2020), venenon (06-10-2020)
Old 05-31-2020, 11:42 AM   #191
soundman98
soundman98's Avatar
Originally Posted by solidsnake11 View Post
10 min for me!
Attachment 188823
i'd call you a cheater, but that's much more setup work than a set of plugs!
Old 06-06-2020, 09:13 PM   #192
Halo_2
Drives: 2014 MY15 86 GTS
anyone with a auto box done this method of changing plugs, does it have the same transmission mount/bracket.
Halo_2 is offline   Reply With Quote
Old 06-07-2020, 09:49 PM   #193
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
tackling this job slowly... got the strut braces out, fuel injector cover on driver side, ECU thingy on passenger side, have as much space as possible ready to go.
I got the coil packs loosened. Question, do I unplug them before pulling them out? or pull them out first then unplug them? the cables seem really firmly in place
second... ive been using a 1/4 slim profile ratchet... seeing some videos of dudes saying you need a 3/8... any particular reason? I don't mind going out to buy a set but is there a need for it? my 1/2 wont fit in there obviously
thanks
RickyRacer is offline   Reply With Quote
Old 06-09-2020, 09:11 AM   #194
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
you know what guys, passenger side plugs and driver front plug are actually not that bad at all (once you take out all the crap to let your arms get down there)
using a 14mm 3/8 deep socket, 3 inch extension, and a 3/8 ratchet i was able to do all 3 of them in under about an hour and a half... a vaccum hose also helps to screw the plug in by hand and then finish off with the tools above
But the drive back one (closest to the steering wheel) is the mother of all spark plug nightmares. I cant use the same 3/8 configuration of socket/extension.... my ratchet wont fit and its a slim profile.
my hands and forearms are CUT UP like crazy (even wearing gloves) trying to access that area and fiddle around with it. I actually had to give up yesterday and save this last plug for another day....
Theres a 1/4 socket + extension stuck in my coil tunnel currently Will report back once (IF) i manage to get this last plug changed and hopefully fire her up without a CEL
Old 06-09-2020, 05:35 PM   #195
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
ok boys, 4th plug is finally in today after about another hour and a half of struggling with it.
Reinstalled the intake and battery and will start her in a few mins.... lets see if this worked
Old 06-09-2020, 05:47 PM   #196
86TOYO2k17
Drives: 2017 toyota 86
Did you not jack the engine up?
Search this Thread:
Advanced Search
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 09:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 03:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
