10-16-2019, 03:49 PM | #295 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
James,
Definitely would have been better start a new thread. No one's going to go into this thread to look for tt5 optimization information. That said, ducting and careful brake management is probably going to be your best strategy. You're braking g's are limited by traction not anything in the brake system itself.
The Following User Says Thank You to 949 Racing For This Useful Post: | Jamestl (10-16-2019) |
10-16-2019, 03:54 PM | #296 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
But from a physics standpoint, increasing rotor/pad size with all else being equal doesn't necessarily increase total braking torque.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | Jamestl (10-16-2019) |
10-16-2019, 06:11 PM | #297 |
Drives: '13 FRS - STX
If you can lock up the tires (engage ABS) with your current brakes then the limit of your braking ability is not the brakes it is the tires.
10-16-2019, 09:26 PM | #298 | |
10-16-2019, 10:05 PM | #299 |
We have been running about 140mm front pinch weld height with 5mm positive rake on 255/40/17. Pinch weld height changes a bit with taller than OEM tires.
The Following User Says Thank You to 949 Racing For This Useful Post: | R2 (10-16-2019) |
11-26-2019, 02:55 AM | #300 |
Drives: 2013 Scion FR-S (949 Racing)
New Chuckwalla CCW 86 N/A Record
Here's the 86 N/A record 1:59.311 Chuckwalla CCW lap set on Sunday morning. Hard to believe a 1:58.9 is possible, but I'm still happy with my driving and confidence the 949 Racing XIDA coilovers gave me on Blub.
Just the way the rear end is so stable that I can throttle steer to change the car's attitude at will on every long double apex corner. Also, the entry speed is just almost too fast, but front end stability under trail braking allows. [ame]https://www.youtube.com/watch?v=8CzvKfpyS0s[/ame] |
The Following 7 Users Say Thank You to SonnyMod For This Useful Post: | Icecreamtruk (11-26-2019), Lincoln Logs (11-26-2019), PulsarBeeerz (11-26-2019), solidONE (12-03-2019), turbofan (11-27-2019), wparsons (01-07-2020), Zer0 (11-27-2019) |
12-03-2019, 07:01 PM | #301 |
A few pics from the last event
12-04-2019, 12:36 AM | #302 |
Any updates on when these might be ready for order/delivery? Thanks.
12-04-2019, 01:45 PM | #303 |
No updates at this time. Working on some minor tweaks to strut flange geometry and end link mounts. Everything else is sorted and ready for production.
The Following User Says Thank You to 949 Racing For This Useful Post: | solidONE (12-04-2019) |
12-04-2019, 02:42 PM | #304 |
Drives: FR-S Whiteout
The end link mount on the strut could be moved a tiny bit outward to clear the frame rail on cars with high - camber (adjusted using camber plates) and lower ride height settings. Most just deal with it and try to find the lowest profile end link they can find. If that is one of the things you are addressing, you'll probably be the first and only company to do this.
Intent > Content
cowardice is the mother of cruelty. |
12-04-2019, 03:59 PM | #305 |
We are often the first.
The Following User Says Thank You to 949 Racing For This Useful Post: | AngelGT86Racer (12-06-2019) |
12-24-2019, 01:50 PM | #306 |
New front aero. In attempt to reduce weight on the nose and increase aerodynamic surface area, we put the OEM front bumper skin back on and grafted an Ikon Motorsport (ebay) urethane lip for a BRZ. It sorta fits but is close enough to be secure. We noticed how flexy it was so we road tested it before we took it to the track. Hung out the window of our minivan at 85mph while we took pics of the lip ob Blub. Sure enough, it was oscillating heavily. So we added a 1/8" sheet of alumalite underneath the lip itself to stiffen it. Only took about an 8" strip to make it solid.
At Buttonwillow 86 Cup event last weekend, Sonny reports that it definitely made a bit more downforce in front than the APR bumper. We were able to crank the ducktail to max angle and achieve excellent aero balance. Combine with a slight change in rake by raising the rear ride height two turns, we got that much sought after neutral balance at both low speed (no aero) and high speed, (aero). Cotton Corners (55-60mph) and Riverside (103mph). Good enough for a new N/A and Mod class record of 1:56.33 on 13CW Even with the bit of alumalite, this spoiler set up weighs less than the APR bumper. Unfortunately, Sonny had an off and tore the thing off in the next session. $80 on ebay and about $20 worth of alumalite. Gotta love cheap speed. We decided to work with Renderos Racing to make a more refined version in FRP that he can sell. Look for that in the coming months. [ame]https://www.youtube.com/watch?v=u79BiXr6_Bk[/ame]
The Following 4 Users Say Thank You to 949 Racing For This Useful Post: |
12-24-2019, 02:50 PM | #307 |
Short summary of Blub's handling from Buttonwillow on Saturday:
I can use all 200whp and and have the full throttle commitment almost everywhere where it matters, specifically from exit of Cotton Corners to Bus Stop, then Bus Stop to Phil Hill. That is where slow speed and high speed grip/balance is confidence inspiring. And in the rain on Sunday: The front suspension/tires are eager to turn in on entry and transitions (Cotton Corners), and rewards you for using slow, smooth brake and steering inputs. I played around with more aggressive (quicker) inputs, and the tires/suspension will let you know when they are sliding/scrubbing, very communicative in the steering wheel (easy to feel). Rear end of the car rotates nicely on command, but only if the weight transfer under trailbraking was done correctly. Even then, you can correct understeer with on-command oversteer and still not over rotate while compensating. Lastly, if you decided to let the car oversteer (for the fun :P), rotation is slow enough for most to learn on for car control clinics. |
The Following 6 Users Say Thank You to SonnyMod For This Useful Post: | Clutch Dog (12-24-2019), Code Monkey (12-24-2019), ka-titties (01-01-2020), phm14 (05-15-2020), radon55 (12-26-2019), turbofan (12-25-2019) |
05-04-2020, 01:25 PM | #308 |
This is an excellent question for a new thread about your project car. Go ahead and start to that new thread and post a link here.
Tags |
6ul, 949 racing, blub, xida |
Similar Threads | ||||
LED Blub Diffuser? | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-07-2016 12:24 PM |
Project Mu Racing 999 brake pads | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-15-2013 03:55 PM |
Project Kics R40 racing lug nuts | HighbreadEH3 | Wheels and Tires | 0 | 09-03-2013 01:49 PM |
The Enjuku Racing Project FR-S! | Enjuku Racing | Announcements, Contests, Giveaways | 12 | 07-19-2012 11:54 AM |
