09-10-2014, 01:14 PM | #57 | |
Are camber plates assessed anything? I understand the LCA is a +4 modification I think. |
09-10-2014, 01:20 PM | #58 | |
Drives: 2004 Toyota RAV-4 5M
I probably will leave the stock cat back on my car as I'm already underweight and the muffler acts as a bit of a diffuser. Removing it would create a nice parachute area and I don't have the points to spend on a proper diffuser. That and I don't think the stock muffler will hold me back on power much, if at all. |
09-10-2014, 01:23 PM | #59 | |
09-10-2014, 01:26 PM | #60 | |
Drives: 2013 Raven Scion FR-S
Camber plates and bolts, and most bushings are free, thank God.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T |
09-10-2014, 01:28 PM | #61 | |
As for the camber plates, you don't need to take any points for those. You are correct about the rear lower control arms being 4 points. I'm not sure why they are worth so many points. Hard to believe that a little extra camber in the rear is worth as much as say a wing on the track. |
The Following User Says Thank You to ja1217 For This Useful Post: | CSG David (09-10-2014) |
09-10-2014, 01:37 PM | #62 |
09-10-2014, 01:37 PM | #63 | |
09-10-2014, 07:01 PM | #64 |
Drives: Raven 6MT
I currently run a 225/45 size street tire with 17x8 for wheels. Since you get back 4 points for running that size, would there be a benefit to running a 215 wide tire? That would give you 7 points back and pretty much completely negate running semi-slicks/full slicks?
This would be at marginally higher than stock power levels (full exhaust, intake, tune for 93). Or at this point, are you wanting to keep the width to maximize cornering? And would running an 8" wide wheel work with the 215's?
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
09-10-2014, 07:10 PM | #65 |
Run a wide 225. I put the 225-45-17 Contis against my 225-45-17 RE070s and they were significantly wider, like 1" on each side maybe. Next time they are off the car I'll take a pic. So find the widest tires you can because the rule goes by what's printed on the tire
-Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
The Following User Says Thank You to AZP Installs For This Useful Post: | CSG David (09-10-2014) |
09-10-2014, 07:59 PM | #66 |
Drives: 86
Offtopic: do you think the 2016 Miata will be classed as a TTD car? My FR-S is overbuilt for the class.. :P
09-10-2014, 10:04 PM | #67 |
Drives: Raven 6MT
What types of coilover systems would only take the 3 point hit instead of 5 i.e. less than 40mm shaft and don't have an external reservoir? I k ow you still have to take the 2 points for springs...
09-10-2014, 11:11 PM | #68 | |||
But the points system allows varying configuration. I say try it and let's see. What rcomps are you getting in 215s? R888?
09-11-2014, 12:30 PM | #69 | |
Drives: Raven 6MT
Also if I were to go with a 215 size tire, I would run something similar to the R888 or just go full slick because I would get those points back. If 8" wide wheels are too big would 7" work then? I could pick up some different wheels to do that. Also, since you could pick up those points you might be able to run aero or other beneficial parts to make up for the skinnier tires....this is only valid if those things help more than the wider tires would.
09-11-2014, 12:47 PM | #70 | |
*** Full slicks are worth +30pts *** I don't think you'll find any other DOT R-compound in 215/17 other than R888. The approved wheel width is 7.0" - 8.0", so 17x8" should work just fine. Just keep in mind you are seriously giving up on some lateral grip by running the narrow tire. That could be a huge performance hit and corner speed disadvantage, but I'm interested in the results...
Similar Threads | ||||
Lets talk lug nuts | Ibanezboy21 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-23-2014 03:42 PM |
Lets talk tires... | frs10 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 10-04-2013 05:21 AM |
Lets talk about clutches | charged86 | Engine, Exhaust, Transmission | 26 | 08-30-2013 04:13 PM |
Lets talk exclusivity | whitejdm | BRZ First-Gen (2012+) -- General Topics | 33 | 02-15-2012 01:17 PM |
Lets talk weight | KaliKev | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 09-12-2011 12:05 AM |
