Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
07-07-2012, 01:23 PM | #57 | |
Drives: 2013 BRZ Limited
07-10-2012, 09:40 AM | #58 |
OM NOM NOM NOM
Drives: 2013 Infiniti G37xS Sedan
Any updates on this?
07-10-2012, 10:37 PM | #59 |
Drives: 2013 Subaru BRZ
havent done it yet, too hot last week, may try on thursday but im also doing speakers so we will see if I have time.
07-13-2012, 12:01 PM | #60 |
Drives: 2013 DGM BRZ
Any one have any new updates with this little project?
I have two kids that are eager to watch "We bought A Zoo" on my Nav. screen as I drive them jiu-jitsu class... I plan on finishing adding a subwoofer this weekend, hopefully I will have time to play around some more with this issue. I will try disconnecting the VSS, then I will try grounding the VSS from the HU end and see what the results are. I do have a busy weekend, so please no one hold me to finishing this.. lol I will remember to take pictures for future reference. |
07-13-2012, 03:05 PM | #61 |
been very busy lately, but hopefully I will get to this today or tomorrow after work
07-19-2012, 12:54 AM | #62 |
Drives: ZC6, Junk of ALL sorts
Rudely,
bumping for results. |
07-19-2012, 04:25 PM | #63 |
been too hot out and I spend all day at work with little-no ac, Ill try it eventually.....
07-20-2012, 03:32 PM | #64 |
Never on Time Always Late
Drives: #silenced crickets
Non Brz owner chiming in here..
I do recall some manufacturers using timed switches that trigger a switch for say 30 seconds to a minute to allow input on older Infiniti models and whatnot.. This may make the switch mod noted above a little easier as you dont need to toggle the switch the second time as it automatically reverts to the default "off" connection.
Good luck guys. |
07-22-2012, 11:54 PM | #65 |
Drives: SWP BRZ
Does anyone know how the SWC pins of the 28-pin connector work?
Is SWC common a logic level high, and you pull the other 2 SWC pins to either common or ground? Do the connectors have dummy pins in the SWC locations, or does anyone have a source for connectors or crimpable pins? Was thinking of making a small switch panel with the volume controls and a toggle switch to disable parking brake switch. |
08-11-2012, 05:25 PM | #66 |
# 1. Always know where your towel is.
ZC6-CBS, is home |
08-21-2012, 06:37 PM | #67 |
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
The Following User Says Thank You to Flat Black VW For This Useful Post: | Floggin Tires (08-21-2012) |
09-30-2012, 06:45 PM | #68 |
Drives: Satin White Pearl BRZ Limited
Could anyone make a DIY for the Nav bypass? I'm still pretty new to these kinds of things and I don't want to mess everything up. ): Thanks in advance.
09-30-2012, 09:18 PM | #69 |
Drives: TIE interceptor; BRZ13
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
10-02-2012, 10:47 PM | #70 | ||
Build Thread:
