05-13-2013, 04:11 PM | #15 |
Drives: Attitude
It could be pistons/rings for the low compression, but that doesn't make any sense if you add coolant to the equation.
NOTE: I'm only an e-expert, not a real expert. |
05-13-2013, 04:13 PM | #16 |
Drives: 2018 Golf R
I check my oil about once a week, I'm not burning any. I'd think oil consumption would be an issue if it were pistons/rings.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post: | Shenks (05-18-2013) |
05-13-2013, 09:21 PM | #17 |
Drives: 2018 Golf R
After letting the car sit in the garage since ~2am Sunday morning:
- Overflow tank is past the max line now - Radiator is 1.5-2" low on coolant The car will be going back to the dealer in the morning.
Parting out HERE
05-14-2013, 09:23 AM | #18 |
This seems to be a rare occurence so far. Hopefully they will get it taken care of for you.
The Following User Says Thank You to Mac1235 For This Useful Post: | civicdrivr (05-16-2013) |
05-16-2013, 12:36 PM | #19 |
Drives: 2018 Golf R
Finally got clarification from the dealer regarding the compression test.
According to them all four cylinders were down 4psi over 15 minutes when hot. That sounds odd to me, and I plan to bring it to a different dealer for another compression test. Sent from my Nexus 4
Parting out HERE
05-16-2013, 12:43 PM | #20 | |
Re-member
Drives: Toyota camry
Wonder if the air in the cylinder/pressure gauge cooled off a bit resulting in less psi? Is your oil cloudy or water fouled? How bout the underside of your oil cap?
Nothing decays like progress, and nothing preserves like neglect.
05-16-2013, 02:29 PM | #21 | |
Drives: 2018 Golf R
The coolant has a weird oily film in the rad filler. Not sure what that is as I'm not losing oil, and I check the oil level often. I'm almost tempted to put the car back to 100% stock (engine wise) and toss is on the dyno. I wonder if my exhaust has anything to do with the low numbers. Im also curious if the AOS has a small amount of condensation in it, which is what the white smoke from the exhaust was. I need to get another compression test done though to rule out an engine issue though, but it still wouldn't explain the disappearing coolant. I'm a bit perplexed by this and just want to toss the damn supercharger on already, but I don't want to exacerbate a potential manufacturing defect and cause them to deny warranty coverage. Sent from my Nexus 4
Parting out HERE
05-16-2013, 03:06 PM | #22 |
Drives: SWP BRZ
I would put 100% back to stock then resolve this issue. GL and keep us updated
The Following User Says Thank You to zc06_kisstherain For This Useful Post: | civicdrivr (05-16-2013) |
05-19-2013, 08:50 PM | #23 |
Drives: 2013 Scion Frs(Scarlet)
Having the same issue..2 months ago i noticed my coolant was low and i topped it off. Went to a meet on may 5th and someone pointed out my coolant was at the low mark and i was curious as to how when i just topped off a month before..its only may 19th and coolant is halfway down again. I do get white smoke coming out of the tail. I have tune/intake/frontpipe. I guess ill have to take my car to the dealership soon.
05-19-2013, 09:06 PM | #24 |
Re-member
Out of personal curiosity, as I am watching this coolant issue very closely, how does the oil/stuff in your catch cans look if you using one?
05-19-2013, 10:44 PM | #25 | |
Drives: Moped
05-20-2013, 12:59 AM | #26 | |
Drives: 2018 Golf R
I drove up to NY this weekend and just got back into town tonight. Tomorrow morning/afternoon I will check the coolant levels again (once cold). I put about 900 miles on the car since the last dealer visit - which was 5/15. Sent from my Nexus 4
Parting out HERE
05-20-2013, 01:10 AM | #27 |
Drives: Scion FR-S
Yeah it does. If oil and radiator fluid are going that quick I would expect something leaking out the head gasket. Check the tail pipe with the AC off and see if you get anything out of it. If you see any fluid I would have it back to stock and to the dealership as soon as possible.
Sent from my SGH-T989 using Tapatalk 2 |
05-20-2013, 05:59 AM | #28 |
Custom User Title
Drives: Asphalt FR-S MT
I saw something posted where the piston sleeves fall about 2mm or so closer to the crank. I'm honestly not sure if it was a post here on this forum about this car though. I know, not too helpful, but worth a look.
Similar Threads | ||||
FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 07:50 PM |
Engine Coolant? | L3P47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-13-2013 11:33 PM |
Alright to use 5-6 old coolant? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-11-2013 08:47 PM |
Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
