Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Forced Induction
Old 05-25-2019, 01:44 AM   #3123
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by Cerbrian View Post
Trying to replace the 3" pulley with the stock 3.25 but the Allen bolts are stripped. Anyone know how I can get these off?
Sent from my SM-N960U using Tapatalk
Pliers and grab tight from the outside or drill them out, possibly ruining the pulley.
Old 05-25-2019, 02:38 AM   #3124
Cerbrian
Cerbrian's Avatar
Drives: 13' white out frs
Good thing I dont mind ruining the pulley. I'll have to give it a try tomorrow, thanks
Cerbrian is offline   Reply With Quote
Old 05-25-2019, 07:31 AM   #3125
BertoFT
Drives: 13 FRS Firestorm
You could try using an extractor like this: https://www.lowes.com/pd/Kobalt-5-Pi...-Set/999957791
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 05-25-2019, 09:27 PM   #3126
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Use a Dremel tool with a cutoff wheel and make a slot for a large flat head screw driver. If that doesn't work, you're left with the screw extractor method.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Carlos_M (06-04-2019), subielife (05-28-2019)
Old 05-29-2019, 11:54 AM   #3127
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
Its been 10 days since I sent in my first log to Delicious, 5 days ago I got my lastest revision from DT for a WOT test and ever since then I'm getting a strange stumble/hesitation at 2-2500rpms. I'm thinking it might be something to do with the last revision but could it be that vacuum actuator you guys have been having problems with?
Just wondering while I wait to hear what DT says. Thanks guys.
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 05-29-2019, 01:11 PM   #3128
toast
Drives: 14 BSP Edelbrock BRZ
Pull the line off the back of the supercharger that goes to the bypass valve. If you have a handheld vacuum pump draw a vacuum and see if it holds. If you don't, blow into the line. There should be no air motion in either case.
A leak at the bypass valve will usually show up at idle first. When the car is warmed up what are your Short Term Fuel Trims at idle?
Since you are in the process of getting tuned I don't think it is usual for everything to not be perfect. That is why it is a process.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
CallmeDave (05-29-2019)
Old 05-29-2019, 02:19 PM   #3129
Cerbrian
Cerbrian's Avatar
So finally got the pulley off, it took 2 big dudes. Thanks for the suggestions
Old 05-29-2019, 02:57 PM   #3130
CallmeDave
CallmeDave's Avatar
I'll test it but I think its just a tune hiccup, looks like its dumping a lot of gas with almost no load (worried it was something dangerous).
Your right its a process and I'll have wait.
Thanks for the tip on how to easily test the valve though.
Old 05-29-2019, 03:01 PM   #3131
jflogerzi
jflogerzi's Avatar
Log your fuel trims. I am going through the tuning on my sprintex 210 and seeing the same thing at times and notice fuel trims go wonky
2013 Series 10 FRS #553
JDL 4-2-1 EL, Stock FP with Vibrant LN RES, MXP SP CB
Koing Hypergram 17x8 ET40 SX2 GTs 245/40/17
Sprintek 210+69mm+FF+Tuned by Mike@Xero Limit
Old 07-03-2019, 01:17 PM   #3132
diluzio91
Drives: '13 with go fast bits attached
Is this the thread where I get my failed bypass actuator valve badge?
diluzio91 is offline   Reply With Quote
Old 07-03-2019, 01:19 PM   #3133
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Bypass valve failure brother here. Mine should arrive tomorrow from Edelbrock. Didn't even have time to get basemap tuned properly yet.
Sent from my Pixel 2 using Tapatalk
Mad1723 is offline   Reply With Quote
Old 07-03-2019, 01:33 PM   #3134
diluzio91
Yup, one of my friends literally installed his 5th one about a week ago, they stop sending replacements after the first one and you get to pay out of pocket for their inability to do QC. If you ask them then it's "not a widespread issue" and "the part is considered a wear item" Honestly wish I hadn't bought one with how poorly they're handling this issue.
Old 07-03-2019, 02:08 PM   #3135
CallmeDave
CallmeDave's Avatar
The Following User Says Thank You to CallmeDave For This Useful Post:
diluzio91 (07-03-2019)
Old 07-06-2019, 08:37 PM   #3136
Mad1723
Mad1723's Avatar
Bypass valve installed, idle now stable even when pinching the hose. Now to get a proper checkup on my tune from the guys at Delicious Hopefully that's the only leak I had. I clamped every hose and also used more where there wasn't any in the instructions.
Fingers crossed!
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 323 01-22-2020 10:10 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 936 09-27-2016 03:51 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen Subaru BRZ General Forum 0 05-24-2012 10:09 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
