Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
go_a_way1, MisterSheep
Old 06-17-2019, 12:36 PM   #20889
eastendraceshop
FT86Club Official Vendor
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
I kinda feel like the fumoto cold only get damaged like this if you didn't have a skid plate. Am I wrong?
Originally Posted by ermax View Post
Skid plate is only aluminum. No match for a 2600lbs car impacting the ground. I would have thought the bump stops would prevent going that low though.
@Ashikabi my skid plate was pretty beat up too haha. It's pretty much touching the oil pan at this point. I need a new plate and oil pan.
@ermax It was a weird bump that I hit, and the coilovers that are on my car are a prototype set from a company that asked us to test them out, not sure if that has anything to do with it, but they ride pretty horribly, lol.
The valve has been installed for four years prior to this and has been on the car for 80k miles with no issues. It didn't leak at all after the impact.
Order 24/7 at WWW.EASTENDRACESHOP.COM
For inquiries and customer service: sales@eastendraceshop.com
eastendraceshop is offline   Reply With Quote
Old 06-17-2019, 03:56 PM   #20890
Ultramaroon
fun police
Ultramaroon's Avatar
eastendraceshop (06-18-2019)
Old 06-20-2019, 05:53 PM   #20891
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Anyone felt zenki 86/BRZ steering is lil too heavy? Or while drifting or counter steering, steering get unknown heavy feel to it? Kouki 86/BRZ have resolved the issue by updating the EPS. Good news is, zenki 86/BRZ owner can do the same thing by replacing the EPS w kouki EPS.
Zenki model should have big “G” on it. Kouki model should have “1”... then why is other one have “3” on it? When I google search that part number it said it’s for ‘18 BRZ STI model. Which I’m assuming it’s for tS model (in US, BRZ tS came as ‘18 model). tS or kouki model EPS price was almost same on eBay (+-$5 difference). So thought to test it out if tS model EPS works on zenki model. Answer that question is, yes, it does work.
Work itself took about 30mins. Only 3 bolts, 2 screws & 1 nut to get it off, so why took 30mins? EPS is in very awkward area (behind trunk release & light adjusting buttons), so had to go through several wires with twisting my arm & hand to get those bolts off. If you careful and take your time, it’s not that hard. No, I’m not planning to make DIY, cuz it’s easy mod.
Test drove after installation and yes, there’s a difference in the steering feel. It’s a lot lighter. I prefer zenki power steering weight, but kouki power steering isn’t bad either.
Here’s a vid (if you understand Japanese)
https://youtu.be/MTJB5pfhgsE
Old 06-20-2019, 07:05 PM   #20892
StraightOuttaCanadaEh
Wes
Drives: 2017 Toyota 86
so if I want heavier steering, i can switch back to the older model?
Instagram: @gt86wes
Old 06-20-2019, 08:30 PM   #20893
ichitaka05
Site Moderator
ichitaka05's Avatar
I donít see why not... but donít quote me on that, cuz I havenít tried it
StraightOuttaCanadaEh (06-20-2019)
Old 06-20-2019, 08:55 PM   #20894
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Installed a 3.73 LSD rear end. Went pretty smooth, only took about 40-45 minutes.
Makes the car much more enjoyable on the street with the t56.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
RToyo86 (06-22-2019)
Old 06-20-2019, 09:12 PM   #20895
Ashikabi
Ashikabi's Avatar
Is that the Lexus rear end?
Old 06-21-2019, 08:41 AM   #20896
spitsnaugle
It is. Super easy swap and makes my setup much more Street friendly.
I might swap my original rear endís gears to 3.55 while I drive on this 3.73.
Old 06-21-2019, 09:17 AM   #20897
Ashikabi
Ashikabi's Avatar
What did you end up paying for it
Old 06-21-2019, 02:45 PM   #20898
spitsnaugle
$700
I can find other Lexus IS300 diffs for half that, but the M85 3.73 LSD, 700 was the going rate from what I found.
Old 06-21-2019, 03:06 PM   #20899
Ashikabi
Ashikabi's Avatar
$700
Good to know. I was just looking into this as someone nearby has the M98(?) diff. I kinda feel for 700$ I'd almost try to get a Ford 8.8 though... I feel like I could probably get one with LSD and installed for about 1000$. Gonna take some fabrication tho
Old 06-21-2019, 03:35 PM   #20900
spitsnaugle
I dont think m98's 3.90 gear ratio is a significant enough difference. At least for increased HP applications.
I considered the ford 8.8, previously I had one in my 240z. It was
$500 for the diff
$75 front yoke
$575 for stubs
$950 axles
$1000 mount kit
Two companies make mounts for the ford 8.8 into a FRS/BRZ:
Grannasracing $2,685.00
Full Blown Motorsports: $3,995.00
Though I like it better, I'm probably going to pull this 3.73 rear end in about a month or so and go to 3.55. Expect to see a FS thread at some point.
Ashikabi (06-21-2019)
Old 06-21-2019, 03:43 PM   #20901
Ashikabi
Ashikabi's Avatar
$500 for the diff
$75 front yoke
$575 for stubs
$950 axles
$1000 mount kit
Ahh forgot axles. The mount kit itself I think I can make, at least cheaper than buying it from Grannas. It would obviously cost more than the Lexus Diff but I imagined it would be much stronger
Old 06-22-2019, 04:06 PM   #20902
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Weekly bath, squeaky clean.
Plus a carsmo armrest off somebody local parting out
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
MJones_RB (06-24-2019), Myriad (06-23-2019)
Search this Thread:
Advanced Search
Got my VIN today... Enemies Subaru BRZ General Forum 63 04-12-2012 10:19 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
