01-12-2013, 03:47 AM | #57 | |
Drives: 2013 Scion FR-S Toyota 86
01-13-2013, 06:22 PM | #58 |
Drives: Raven FR-S
I'm pretty sure that's ok. Try and get a rag/towel in there to soak up the oil & see if you get any more again. If not, I'm sure the filter install is fine.
The oil level, you can have it up to the top dot, or anywhere inbetween. When it gets to the low dot then you should add some. Generally the dots mean lower than the lower dot and you run risk of oil level being too low for oil pump pickup to reach, above the high dot and you run the risk of the crank hitting the oil & foaming it. I'm sure there's a certain amount of safety leeway in either direction. It's good that you're concerned about this, but I think you're fine so rest easy and just keep an eye on things. Drain a little of the oil at next convenient time, wipe up the oil around the filter and watch to see if you get more oil later. |
01-15-2013, 12:38 AM | #59 | |
Drives: 2014 Widebody Cosworth FR-S
Good post, and I agree, it is always good to be concerned about this and many people are not, then wonder why their engine seized when they do not check their oil lever for 4K miles. I do think you are okay though, but always best to keep an eye on it just to be safe. And most track guys will overfill their oil a bit above the top line assuming they will burn oil through the day anyway, so I think you would be okay. Let us know if you have any questions! Thanks, Rick |
The Following User Says Thank You to RallySport Direct For This Useful Post: | amram (03-25-2014) |
01-27-2013, 08:48 PM | #60 |
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Thanks for this DIY! Loved the pics! Changed today!!
Eric G |
01-29-2013, 01:06 AM | #61 |
01-29-2013, 01:14 AM | #62 | |
Drives: Attitude
01-29-2013, 01:25 AM | #63 | |
Perhaps I should make a habit of checking it at the gas station hoping that other people see me and think "Gee, maybe I should check my oil too!" Or if they asked, I would be happy to check it for them of course. Thanks, Rick |
01-29-2013, 07:16 AM | #64 |
VTEC just kicked in, yo!
Drives: World Rally Blue BRZ - 6MT
My BRZ came with 20k miles of free oil changes. Why are so many people doing their own oil changes? Do you guys not trust the dealerships or is there another reason? I'm really curious.
The Following User Says Thank You to Calin For This Useful Post: | RallySport Direct (01-29-2013) |
01-29-2013, 11:39 PM | #65 | |
Also I think many of the guys here, myself included get a great sense of accomplishment of doing things ourselves. Sometimes I genuinely enjoy working on my cars, and sometimes I want to burn it to the ground in frustration haha I would be curious to hear people's answers though, as your question brings up some great points. Thanks, Rick |
The Following User Says Thank You to RallySport Direct For This Useful Post: | Calin (01-29-2013) |
01-29-2013, 11:59 PM | #66 | |
01-30-2013, 12:16 AM | #67 |
Pepe Le Pew Wannabe
I am told by the service dept that only the 7.5k and the 15k miles oil changes are inculded in the maintenance agreement. You can ask to performed the 7.5k sooner than 7.5k, as well as the 15k miles. However only two oil changes are all you get. If you want to change oil at 1k miles or more frequently than the oem service agreement, then you are on your own.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent! |
The Following User Says Thank You to Kamran For This Useful Post: | RallySport Direct (01-30-2013) |
01-30-2013, 01:13 AM | #68 | |
Thanks again! Rick |
01-30-2013, 01:30 AM | #69 | |
Rick |
01-30-2013, 01:55 AM | #70 | |
The Following User Says Thank You to Calin For This Useful Post: | RallySport Direct (01-31-2013) |
Similar Threads | ||||
Oil Change Questions | #87 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 06-28-2012 11:06 PM |
Color Change | Dark_Angle | Mid-Atlantic | 10 | 05-30-2012 02:00 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
I was able to change my pre-order. | nkrein22 | BRZ First-Gen (2012+) -- General Topics | 23 | 04-10-2012 04:16 PM |
Can SOA change my preorder? | Zaneman | BRZ First-Gen (2012+) -- General Topics | 8 | 04-08-2012 02:06 PM |
