07-23-2014, 12:29 PM | #29 |
Drives: 2014 WRB BRZ Limited
If your "buddy" can't do his own research, he really shouldn't be doing any kind of swap...
07-23-2014, 12:38 PM | #31 |
Off Topic
Why do you need to swap anything? People are already pushing 400+ hp with turbos or superchargers, for a lot cheaper than a swap would cost. Sure, you could drop in a 2JZ and do a custom turbo setup with 1000 hp, but why?
07-23-2014, 12:43 PM | #32 | |
Drives: 2014 SWP BRZ
This might be the best thing I read all week |
07-23-2014, 12:48 PM | #33 |
The Following User Says Thank You to Herndon For This Useful Post: | Sportsguy83 (07-23-2014) |
07-23-2014, 04:59 PM | #34 |
Drives: 2013 Subaru BRZ
also 1jz, lel.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
07-23-2014, 05:06 PM | #35 |
All my friends think I'm a bit crazy and redundant to want to swap in a 13B-MSP Renesis. It's highly unlikely that it will happen, but I can dream.
07-23-2014, 05:14 PM | #36 |
Because compromise ®
Drives: Red Herring
Fixed that for you. Do the math. Four rotor is twice as good as two rotor.
07-23-2014, 05:38 PM | #37 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
If you need us to give you ideas on a "unique" engine swap, you're already failing. The farthest you will get is pulling the stock motor, then you'll realize how much sh*t is involved with doing a motor swap and give up. Quit wasting yours and more importantly our time, do some research on your own, and when YOU come up with a good idea and make it work, feel free to share or don't. But if you can't even figure out a motor to use, I have very little faith you'll actually accomplish anything.
07-23-2014, 05:42 PM | #38 |
Drives: Subaru
07-23-2014, 05:58 PM | #39 |
Drives: 2014 Subaru SS BRZ LMTD
Dude a ford 5.0 motor swap would be crazy. But theres nothing wrong with LS or 2Jz. It all depends on how deep is your buddy pockets. no homo. I'm still waiting on an ej25 swap, than again I'm good with my fa20 hopefully I can add a little boost to hit the 300 mark. Goal is 350 - 380 whp, but I'm dreaming [:
07-23-2014, 06:01 PM | #40 |
Custom User Title
Drives: Asphalt FR-S MT
It's a reality check...so it did accomplish something. Now what about yours?
I also wasn't trolling. The type of swap wasn't specified when I posted.
The Following User Says Thank You to boredom.is.me For This Useful Post: | Dustin (07-23-2014) |
07-23-2014, 06:05 PM | #41 |
Drives: 13 SWP BRZ
07-23-2014, 06:15 PM | #42 |
B16a or do a ls/vtec!
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
LED swap | Skorov | AUSTRALIA | 28 | 09-23-2014 09:46 PM |
AT swap to MT | CodyFRS | Engine, Exhaust, Transmission | 25 | 10-30-2013 10:39 PM |
2UR-GSE Swap | czar07 | Engine Swaps | 9 | 08-29-2012 01:43 PM |
