Old 04-28-2020, 01:04 PM   #351
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by wparsons View Post
Just an FYI, that's a K24 bottom end with K20 head IIRC. A stock K24 head won't make as much power.
Plus, that was on e85 and a massive TB that had terrible driveability. E85 and the better sized TB was 260whp, on pump gas it would probably be in the 245-250 whp range. Still great power on all original honda OEM internla parts though.
Not to mention the extra drivetain loss of RWD vs FWD ~4-5% so around 250whp on E85 and 235whp on 93oct. Still great for mostly OEM components.
PulsarBeeerz is offline   Reply With Quote
Old 04-30-2020, 09:29 AM   #352
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It was clarifying for anyone thinking that a bone stock K24 on pump gas magically made 70whp more than what Pure Auto is at right now with theirs.
Have not watched the series, and just by looking at the image from the second video it's obvious there are several parts added to make the power.
If someone needed that clarification that a bone stock K24 can magically make 70 more WHP, they have bigger issues.. lol
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Irace86.2.0 (04-30-2020)
Old 04-30-2020, 11:59 AM   #353
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
E85 will probably not make a huge difference. The guy in the video should have done a higher compression build, unless E85 wasn't going to be always available or unless he plans to boost the motor.
Old 05-09-2020, 10:37 PM   #354
Irace86.2.0
I was getting into some K20C1 videos, dynos and webpages today. It is really a shame that Honda doesn't sell this motor. Ford and Chevy will sell someone a myriad of crate motors because why not take my money? But Honda will not sell a K20C1 crate motor to just anyone. Someone has to be a part of sanctioned racing. This is lame. Getting into this motor, it would be a good deal for anyone wanting a turbo K motor out of the box, and for $6500, that is a good deal. If I was considering a swap, such a motor would be high on my list. What is crazy is that used K20C1 motors from wrecked cars are 50-100% (+) more expensive.
Old 05-10-2020, 12:42 AM   #355
Irace86.2.0
Originally Posted by solidsnake11 View Post
k20c1 has the exhaust on drivers side compared to the k20 24 passenger side exhaust. There is a lot of crap on the back but It looks to be coolant pipes.
Kinda like the 3SGE swaps. I think the exhaust is fine. Those water pipes, on the other hand, would push the motor forward. Could be a problem for packaging.
I like the engine and the innovations over the k20a. I like the K20c over the K24a because 86x86 for gt86.
Old 05-10-2020, 12:28 PM   #356
Irace86.2.0
http://www.superstreetonline.com/fea...la-86-mtsema19
K20c1 swapped 86
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Zer0 (05-11-2020)
Old 05-13-2020, 05:50 PM   #357
najaray
Drives: GT86
I like the swap its fantastic accept the ecu its too expensive I pet that the ls swap is much cheaper is there any cheaper solution for the expensive motec 150m ????
najaray is offline   Reply With Quote
The Following User Says Thank You to najaray For This Useful Post:
solidsnake11 (05-23-2020)
Old 05-20-2020, 12:04 PM   #358
PulsarBeeerz
Why would it be cheaper? You start with a more expensive engine and use the same 150m.
Old 05-23-2020, 01:24 PM   #359
Irace86.2.0
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
venenon (05-26-2020), Zer0 (05-24-2020)
Old 05-26-2020, 08:41 AM   #360
Sportsguy83
Drives: Limited BRZ
It's an M130, not M150. For an LS swap the ECU solution can be had cheaper, which I believe is what najaray is referring to. You can get, for example, a Haltech Elite 2500, or an Emotion or even now there's an AGT Engineering Canbus translator and all of those will save you some money when compared with this K24 swap (obviously talking only about the ECU).
There are other major savings going K24 vs LS though, like no need to modify the tunnel which is one of the biggest deals when doing an LS swap.
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
