Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-09-2014, 08:58 PM | #57 | |
Drives: Subaru BRZ, Toyota MR2 Turbo
We will be listing the new oil pans on our website this week. For those that are interested we are still offering a 25% discount for aftermarket exhaust headers and turbo kits to confirm fitment. |
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | Captain Snooze (03-10-2014) |
03-09-2014, 09:46 PM | #58 |
Drives: 4 wheels
Why no baffles?
03-10-2014, 12:09 AM | #59 |
03-12-2014, 08:56 PM | #60 |
Drives: '92 GS-R, '02 RSX-S, '14 BRZ
Interested in this w/ a baffle. Installing on a brz w/fa20club uel header with turbo. Pm please.
PTE 5758, Turbosmart, JDL, Perrin, Tein, Rays Gramlights, Sumitomo, Raceseng, Beatrush, Buddy Club, Valenti, DSS, Act, Cartboy, Mtec, APR, Beatsonic, FA20CLUB, Radium, JPM Coachworks, VIS, Recaro, IAG, Cleib, Nameless, Zele
Coming soon: Garage Vary, Cleib, Cravenspeed, VEI |
03-13-2014, 06:34 AM | #61 |
03-14-2014, 02:15 AM | #62 |
Because compromise ®
Drives: Red Herring
If you send me a PM does that mean I will get it in the afternoon?
03-14-2014, 04:03 AM | #63 |
Turning is for Nerds
Drives: 35 characters is not enough
I'll be putting on the nameless header in a few weeks, I could probably test fitment.
03-16-2014, 01:50 PM | #64 |
Drives: -
Curious to know if this will work with the Greddy turbo kit...
03-19-2014, 08:29 AM | #65 |
Drives: UK GT86 in White with alcantara
Email sent
Hi Jeff, email sent to see if you want me to test fit this against the new JDL turbo kit on my car.
05-14-2014, 11:10 AM | #66 |
Living the dream
Drives: Fensport AVO Turbo GT86
05-14-2014, 11:38 AM | #67 |
Just a question, what's the size of the oil return plug? My JDL turbo kit came with a weld-in return with a push-on fitting which I think is -8AN, so I need to buy a male to barbed fitting to put in the oil pan.
05-14-2014, 12:06 PM | #68 |
^^ This
Thanks for the tracking number Jeff. Mine will be fitted by the weekend all being good! |
05-14-2014, 12:08 PM | #69 |
Drives: Nevermorange FRS
Just some considerations.
A) baffles work really well as trap doors as opposed to static (unmoving) plates. The baffling in this design looks like might only stave off the slosh temporarily but not remedy starvation in high-G-load, long-duration sweepers. Will be curious how testing goes. B) Just adding oil capacity will not improve oil cooling it just "delays" temperature stabilization. This is a common misconception. Oil will still reach it's stabilized temperature but just take longer to do so. To get oil to 'cool better' it needs something to facilitate that like a heat-shielded pan, cooling fins on the pan or a remote oil cooler. C) Cooling fins on the pan may not work well on this car. They probably would but just as a thought exercise... Cooling fins work by increasing surface area as air flows over it, we all get that but on this car 2 things exist that don't on most other cars 1) our header which gets very hot surrounds our oil pan on both sides and 2) the undertrays on this car may restrict air passing over the bottom of the pan. I say "may" because I cannot confirm this and am assuming so to say this: With a hot header surrounding the pan on 2 sides and a possible reduction of airflow over the pan due to underbody panels, then adding fins (increased surface area) could have the opposite effect of cooling fins if the surrounding radiant temps are greater than the pan itself. D) I'd like to see swing-door or trap-door type baffles that are more restrictive to slosh. They would both swing inwards toward the pump but not outward away from the pump and be closer (almost flush) with the sidewalls so oil don't flow around the doors during cornering and is held at the pickup. As for keeping the heat out of the pan I'd like see some type of heat shield for the areas closest to the headers. It's not too important though, one could always wrap their headers or put heat reflective material on the pan. Good work, good thread. Thanks for posting.
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post: | Captain Snooze (05-14-2014), Jeff@Racer X Fab (05-15-2014) |
05-14-2014, 12:30 PM | #70 | |
I plan on applying gold reflective tape to the pan. People are having issues with melting motor mounts with FI... Going to try to do all I can to protect the components around the header and down pipe. |
Similar Threads | ||||
Racer X Fabrication air intake design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 45 | 08-01-2019 12:29 PM |
Racer X Fabrication suspension parts, and development | Jeff@Racer X Fab | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 134 | 09-01-2016 05:02 AM |
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! | Jeff@Racer X Fab | Groupbuys | 74 | 06-23-2014 09:08 AM |
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
