Old 03-12-2013, 09:25 AM   #15
Racecomp Engineering
Originally Posted by Calum View Post
Does the car in the video have the whiteline bushings? It looks like it to me.
NO and its also on a dyno which seems to be moving also and the clutch is let our VERYYYY smooooth.
mw
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Calum (03-12-2013)
Old 03-12-2013, 12:25 PM   #16
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Originally Posted by Racecomp Engineering View Post
Thanks Rick, I try to give the drivers view on some parts. I realize some only want to see "data" but MANY things on these cars is about "feel" and how that "feeling" effects your driving and or confidence.
I will be calling you guys to get the CF driveshaft very soon. I like it because its the same size as stock and doesn't hit the tunnel or require any modifications.
Myles
Thanks Myles, and yes I agree, some of these parts make it hard to show any real data, and really just comes down to how you want the car to feel or be setup.
We did take a video of the stock diff bushings, not the best angle, but it gives you an idea of how much flex there is with the stock bushings. This was on cold but dry pavement.
[ame="http://www.youtube.com/watch?v=10rspcW8uek&list=UUHNPxTbGXNDDxsNjjSSwg5A& index=1"]http://www.youtube.com/watch?v=10rspcW8uek&list=UUHNPxTbGXNDDxsNjjSSwg5A& index=1[/ame]
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
stevo_12v (07-22-2013)
Old 03-12-2013, 12:34 PM   #17
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Does the cusco diff bush kit also come with the outrigger bushes you can see in Myle's pic? I get an insane amount of movement all around back here since adding sticky tires
Huehuecoyotl is offline   Reply With Quote
Old 03-14-2013, 08:58 AM   #18
Thanks,
Rick
VERY NICE ! And I agree. BTW my post and using your video was meant at showing the movement. But this new one is better. And I agree some will want this and some wont. I think once a person sees the amount of movement they might want the modification.
Mw
Old 03-14-2013, 10:54 AM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what about engine and transmission moutns (or inserts?) is the car in question still running stock pieces?
i want a caged-style engine mount but no one seems(?) to be making one yet?
Old 03-14-2013, 01:31 PM   #20
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Everytime Rick and Myles put a review of a part, that part usually becomes top on my list.... my wallet doesn't like like you guys lol
Bu-Tang is offline   Reply With Quote
Old 03-14-2013, 02:19 PM   #21
wparsons
wparsons's Avatar
Anyone have these available yet? I can't seem to find anyone with them listed online.
flickr
Old 03-14-2013, 09:59 PM   #22
I have a single set in stock. Let me know asap.
we open in the AM , 10am eastern time.
Mw
johnb831 (06-09-2013)
Old 04-13-2013, 10:38 PM   #23
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Are these scca legal?
enjoyminutemaid is offline   Reply With Quote
Old 05-29-2013, 02:14 AM   #24
Hawk77FT
Drives: GTS 86
So Cusco or Whiteline? Which one is better?
Also what is the difference between KTD924 and KTD925?
Hawk77FT is offline   Reply With Quote
Old 05-31-2013, 01:05 AM   #25
Justkiz
Drives: WRB BRZ
That is exactly the issue I got here too!
I only can guess that KTD925 or KTD924 are only a bushing and eventually will wear out to the ineffective level but Cusco or Beatrush one will last forever.
However still wondering whether that extra $100 on Cusco is worth or not.
Justkiz is offline   Reply With Quote
Old 05-31-2013, 01:36 AM   #26
Hawk77FT
Drives: GTS 86
I have asked the guys from @RallySport Direct. They have kindly came back to me with this:
"Thanks for the PM. As you know we run the Cusco mount on our BRZ, and while I love it, it does add quite a bit of NHV and you would notice it for sure and I would generally not recommend it for a street car due to the rawness of it. Now between the Whiteline 925 and 924, the 924 will give a more solid feel and should be more comfortable than the Cusco mounts, but you do have to press out the old bushings and press in the new ones. On my personal BRZ I will eventually go with the 925's as I think that is the best compromise between the 3, and they are much easier to install as well as you are not pressing out bushings. They will still reduce the rear diff movement substantially and without adding much NHV to the car, but enough that you know they are there. "
I will go with 925 and see how it goes. Hope this helps.
The Following User Says Thank You to Hawk77FT For This Useful Post:
DriftEightSix (06-09-2013)
Old 05-31-2013, 03:46 AM   #27
Panman
Panman's Avatar
Drives: 86 GTS
I have the 925s in my car and NVH is not a major issue. I've got the Perrin gearbox mount and cusco stiffener, they added way more NVH than the 925. That said, you can definitely feel the difference in the driveline in a good way.
Panman is offline   Reply With Quote
Old 05-31-2013, 04:00 AM   #28
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Originally Posted by stockysnail View Post
Cool. I should have these coming in the next week or two so it's nice to see they do a good job. Well worth $50!
Dibs on going for a ride when u install them. Theyre on my list...
ilpad is offline   Reply With Quote
Search this Thread:
Advanced Search
JDM Fog Light ON and installed! 86design BRZ Photos, Videos, Wallpapers, Gallery Forum 111 09-20-2013 12:23 AM
Just Installed RS-3 Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-27-2012 09:41 AM
Does anyone have APPRADIO2 installed? Allankh Electronics | Audio | NAV | Infotainment 6 10-24-2012 08:22 PM
New ECUs being installed jpit Engine, Exhaust, Transmission 13 10-08-2012 03:00 AM
TRD Spoiler Installed JDMSushi AUSTRALIA 9 08-07-2012 12:49 PM
