Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-03-2018, 08:55 AM | #29 |
I spun a bearing on my 2013 (11/2012) at 86K miles. Oil level was to the top dot and was changed 4000 miles prior with 5w30. When it blew I was doing a pull to redline in 4th on the interstate. Leading up to that I had been driving it like a normal person so the oil temps weren't high at all. On tear down I was actually impressed with how little carbon buildup there was. Looks like the dual injection really does work. A little blast with some carb cleaner and it was like a mirror. Didn't have to use a brush or anything. I don't needlessly redline just for the hell of it but I do drive it hard and it sees redline at least 10 times a day. When I am cruising I keep the revs low though.
I've never bought into the whole drive it like you stole it or else it will not like to be driven like it's stolen concept. The DI seal issue was related to detonation on high transients. That was fixed with software a long time ago. If you don't have the the fix then redlining is actually not a good idea. That is exactly the scenario that was causing the detonation and blowing seals. My DI seals looked fine but I'm changing them anyways while I have it all apart. |
The Following 5 Users Say Thank You to ermax For This Useful Post: | Capt Spaulding (07-08-2018), humfrz (07-03-2018), Teseo (07-03-2018), Tristor (07-03-2018), VoltsFRS2013 (07-06-2018) |
07-03-2018, 09:26 AM | #30 |
Drives: Frs
I like to redline it pretty often just to make sure the shift light is still working.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
The Following 7 Users Say Thank You to Submarinesonce For This Useful Post: | ermax (07-03-2018), humfrz (07-03-2018), Lantanafrs2 (07-04-2018), NoHaveMSG (07-03-2018), Overdrive (07-06-2018), Silviacrazed (05-08-2020), Ultramaroon (07-03-2018) |
07-03-2018, 06:29 PM | #31 |
Drives: ADM Toyota 86 GT
Get it up to operating temperature then flog the sh*t out of it. Worked for me on my last two cars, never had a problem with them. Both high revving naturally aspirated 4 cylinders that see a lot of the track. Neither have used a drop of oil or given me why trouble.
Sent from my RNE-L02 using Tapatalk |
07-03-2018, 06:50 PM | #32 |
Maybe they're similar in the sense of "zoom zoom boom!"
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post: | Ultramaroon (07-03-2018), weederr33 (07-03-2018) |
07-03-2018, 06:58 PM | #33 |
義理チョコ
Can never be too sure.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tristor (07-03-2018) |
07-03-2018, 07:34 PM | #34 |
I do burnouts in the garage before I set off. it helps to get engine and tire temps up quickly and I get to check my carbon monoxide sensor multiple times a day. you can't be too safe
The Following User Says Thank You to NRXRaptor For This Useful Post: | humfrz (07-03-2018) |
07-03-2018, 07:35 PM | #35 | |
Drives: White Out FR-S
that being said, redlining either has greater wear and tear thanks in-part by the heat generated. Granny driving a car and lugging it isn't the best thing you can do for a car either. My pet peev are granny drivers who think their granny driving is saving the car and planet when they don't maintain their car and are actually making the car worse and the planet worse by polluting it with poor maintenance. I drive my car within the specifications and that's good enough. I don't lug the car, i don't redline the car. I just drive it to get the most out of the RPM range. |
The Following User Says Thank You to ST185RC For This Useful Post: | Tristor (07-03-2018) |
07-03-2018, 08:15 PM | #36 |
07-03-2018, 08:31 PM | #37 |
Drives: 2013 frs red
I redline it to pass minivans. Uh oh
07-03-2018, 08:51 PM | #38 | |
Drives: frs
07-03-2018, 09:21 PM | #39 |
義理チョコ
Italian tune up
[ame]https://www.youtube.com/watch?v=N44icPfGi1M#t=37[/ame]
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Lantanafrs2 (07-03-2018), strat61caster (07-04-2018) |
07-03-2018, 09:32 PM | #40 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Do not pass GO! Do not collect $200!
Get new friends immediately. Apex and side seals don't get more efficient on over rev.
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (07-03-2018) |
07-04-2018, 01:36 AM | #41 |
Drives: 2017 Toyota 86
Break the car in properly. Drive the car properly and enjoy!!
Personally I redline it, I also rev match and have fun in the corners when possible. As for the air bags knowing if they work humfrz <insert sexy girl here>. Squeeze them and rub face in them they sould work just fine. |
07-05-2018, 08:06 AM | #42 |
billswebspace.com
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Italian tuneup has been around longer than our FT86
Bill
BillsWebSpace.com |
The Following User Says Thank You to wrh3 For This Useful Post: | Ultramaroon (07-05-2018) |
Similar Threads | ||||
20B Rotary | Staf00 | Engine Swaps | 77 | 12-03-2020 09:33 AM |
Old Rotary Love | MAPerformance | Other Vehicles & General Automotive Discussions | 6 | 03-17-2016 07:27 PM |
TOMEI POWERED Dissects the FA20 Flat Four | I<3myFRS | Engine, Exhaust, Transmission | 11 | 02-24-2016 11:15 PM |
RX8 out Ran My FRS (Rotary Vs Flat 4) | GT-ROKIN | FR-S / BRZ vs.... | 113 | 05-17-2014 01:40 AM |
Rotary Extinction??? | Rotarydisciple | Other Vehicles & General Automotive Discussions | 53 | 01-23-2010 09:58 PM |
