07-24-2017, 08:46 PM | #4061 | |
07-25-2017, 09:47 AM | #4062 | |
Drives: '14 WRB BRZ | '17 CB STi
Probably kind of an odd question, but I figure this is the most likely time you've experienced cars around at WOT (rather than a drag strip or anything like that).
PR138
IG: @pr.138 2008 LBP Honda S2000 2013 UM Scion FR-S |
07-25-2017, 03:08 PM | #4063 | |
You should be approximately on par with an automatic M4. |
07-25-2017, 03:14 PM | #4064 |
Well then... GT4s and M4s trap in the upper 110s to 120mph in the 1/4 mile. That's pretty damn fast and would have to mean that anyone that says it's underwhelming hasn't actually ridden in one at that power level. Thanks!
PR138
07-31-2017, 08:21 PM | #4065 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
So update on the compressor surge sound, it was actually a normal sound to hear i was just being too general by saying it was compressor surge sounding when it was more of a slightly pulsing whoosh sound that is normal...
Just out of curiosity if i switched from a catless UEL to a catless EL would a retune right away be necessary? I was planning on installing the EL in the winter when new engine was going in but just today my UEL header cracked and so Im putting my EL on to at least run car, I know i won't be making peak power but just want to make sure I'm not hurting anything else by doing so!
07-31-2017, 09:03 PM | #4066 | |
08-01-2017, 01:40 AM | #4067 |
Drives: 2013 WRB BRZ 6MT
Mathing it out, 370whp on a brz is going to be around 425 crank. At 2800lbs, such a car has a lbs per hp ratio of 6.6. This power to weight ratio is on par with a Charger SRT Hellcat and is faster than the C7 Corvette Z51, AMG C63 and Lotus Evora 400 which are all extremely fast cars in a straight line.
The Following User Says Thank You to Lynxis For This Useful Post: | PR138 (08-01-2017) |
08-01-2017, 07:52 AM | #4068 |
Drives: 2013 FRS / 2013 427 Vert
My car which weighs under 2700lbs has the C30 high boost with upgraded pump and injectors. Car made about 315 on a Mustang dyno on E75. I've had opportunity to run alongside several of the cars mentioned and I can say that on the straights it will keep pace with most V8 Camaros and Mustangs but still gets walked by Vette's, GTR's GT3's etc.
On the street is another story as my wife's APR tuned TTS will absolutely obliterate my FRS in any low speed roll or dig. It simply runs off and hides but I have done a 3.9 Vbox 0-60 with it.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | PR138 (08-01-2017) |
08-01-2017, 09:23 AM | #4069 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Great that our cars are so light though cos every add HP makes a bigger difference than the heavier competition :-)
I like driving!
The Following User Says Thank You to 86 South Africa For This Useful Post: | Lynxis (08-01-2017) |
08-01-2017, 10:13 AM | #4070 |
Yes, it is very simplistic but I pray someone with this power level isn't trying to put it down with the OEM 215 Michelins lol.
The Following User Says Thank You to Lynxis For This Useful Post: | 86 South Africa (08-03-2017) |
08-01-2017, 05:49 PM | #4071 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | Lynxis (08-01-2017) |
08-01-2017, 07:50 PM | #4072 | |
Drives: 2017 BRZ
08-02-2017, 12:41 AM | #4073 |
Drives: FRS
Science.
08-02-2017, 06:24 AM | #4074 | |
Drives: 2013 FR-S Argento
Sent from my SM-N920V using Tapatalk |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
