Old 04-02-2021, 03:50 PM   #99
gpvecchi
gpvecchi's Avatar
I'd need to remove the knee airbag from the EU version, do you know what is the correct value of the resistance? Can I measure it with a multimeter?
And, more important, what if the ECU should send the ignition current because of an accident? The wires are almost in short circuit....
Old 04-02-2021, 08:12 PM   #100
ls1ac
ls1ac's Avatar
Be very carful putting a multimeter across the terminals. Some have an inrush current.
Put a fuse inline with the resistor.
You are in an accident that will deploy the air bag and are worried about burning out a resistor?
Old 04-03-2021, 03:28 AM   #101
gpvecchi
gpvecchi's Avatar
Thanks, not worried for burning out the resistor, but the whole airbag cable...
Old 12-05-2022, 12:58 PM   #102
LateOnTheBrakes
Drives: 2023 BRZ
Has anyone tried the Recaro universal resistor instead of the Bride or just putting a resistor into the connector? It looks much cleaner if it works.
https://www.vividracing.com/recaro-u...152867045.html
LateOnTheBrakes is offline   Reply With Quote
Old 12-05-2022, 02:09 PM   #103
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I see you on other threads chasing this down. I'm tired of my cluster lighting up like a Christmas tree once I start driving.
Very curious to see what you find.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 12-07-2022, 12:38 PM   #104
LateOnTheBrakes
Drives: 2023 BRZ
Yeah, I still have no idea where the 2.2 or 3.3 Ohm value came from. I measured the driver's side plug resistance to be like 0.4 Ohms.
Old 12-07-2022, 12:38 PM   #105
LateOnTheBrakes
Drives: 2023 BRZ
Originally Posted by TCR View Post
I'm considering purchasing a race seat to install for track days only, as I need to have a seat with functioning air bags for street legality here. If I set the race seat up correctly with mounts fixed to suit my seating position, it should be a pretty straight forward swap, but I don't want to have to keep inserting and removing a resistor from the plug each time I swap.
Does anyone know if you could buy a spare plug to wire a permanent resistor to, so that all I'd have to do was switch plugs so to speak?
Something like this maybe?
http://www.sportseats4u.co.uk/recaro...prod_3950.html
Did you buy that recaro universal resistor? Any luck?
Old 12-14-2022, 04:40 AM   #106
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Resistor worked, tho.
tigermack is offline   Reply With Quote
Old 12-22-2022, 09:43 PM   #107
LateOnTheBrakes
Drives: 2023 BRZ
No. I reached out to recaro and the connector isn't the same. I bought the NRG resistor and it worked fine.
https://getnrg.com/products/srk-res
Old 12-23-2022, 04:15 PM   #108
RedReplicant
Drives: None
The SRS light can be turned off on the dash via CAN... I don't know what would happen if the SRS module was still in the car when this was done though
The CAN ID is 372, for anyone looking to sniff quick.
EPAS light can also be turned off via CAN.
RedReplicant is offline   Reply With Quote
Old 12-24-2022, 01:15 AM   #109
geraldjust
Drives: MR2, Sliver BRZ
having two can ID can interfere and multiple devices can throw a error. if you have the airbag module disconnected then it should work. but doesn't fix if you want the rest of the SRS system to keep working properly. wont also fix the issue of the passenger occupancy sensor either though.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
The Following User Says Thank You to geraldjust For This Useful Post:
RedReplicant (12-24-2022)
Old 12-26-2022, 11:39 AM   #110
Nmstec
Drives: Frankenstein of parts
If you look carefully inside, you'll notice theres a shorting bar. When the connector is unplugged that bar shorts the two pins as a precaution from people trying to explode airbags. 3.3 Ohms is also wrong, as someone who did do that had bad probes. However, that being said, any 1/4w resistor between 1.8 and 3.3ohm will do the trick.
Nmstec is offline   Reply With Quote
The Following User Says Thank You to Nmstec For This Useful Post:
RedReplicant (12-26-2022)
Old 12-26-2022, 11:45 AM   #111
Nmstec
Yes, but, you can always MITM attack the cluster.
Every vehicles SRS logic will still attempt to fire the airbags, even if they are disconnected. If the Occupancy sensor fails, it resorts to looking at the passenger side buckle. If Buckled, explode.
Address and data for turning SRS light off (gerald is right, don't just flood the message, either MITM it, or disable SRS module all together.)
0x372 {0x00, 0xYY, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
Where YY is a counter, 00 - F0. Rolls over, starts at 00.
Old 03-18-2024, 08:05 AM   #112
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Opening up this thread.. Anyone have updated pictures or a write up for this? I have my stock limited brz seats, what gets transferred over, all the wiring inside?
Marcoscrdo is offline   Reply With Quote
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
FR-S / BR-Z Racing Seats!!! vividracing Interior Parts (Incl. Lighting) 8 06-19-2012 08:07 PM
