Old 01-31-2013, 09:11 PM   #99
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
I have had bad luck with anything over 225 on a 7" rim in the past. R comps you can stuff all the tire you can get on the rim and not worry so much about the bubble. Street tires don't work well when you go too
wide for the wheel for a variety of reasons. The biggest negative side effect I have seen is snoversteer at the limit instead of a pregressive break away that a properly sized street tire should exhibit. If the tires are going on a car that isn't going to be tracked or autocrossed then pop them on there if that's the look you want, but if any sort of high performance driving is in your future, I wouldnt go there.
Jedi1 is offline   Reply With Quote
Old 01-31-2013, 09:56 PM   #100
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
yeah that's what I figured, hoosiers have a stiff enough sidewall to not flex. My question was directy related to SCCA stock street tire class.
Man I wish BFG made a 235...
Aznsky is offline   Reply With Quote
Old 01-31-2013, 09:59 PM   #101
Jedi1
Jedi1's Avatar
I think the 235 is absolutely as big as you would want to go on a 7" wheel. If you want to go with the 45 or 55 I hope I'm running against you at national events, lol.
Old 01-31-2013, 10:00 PM   #102
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
The harsh truth is you have to test both. The new construction of this generation is a huge unknown how much they can be pinched and with even less void area on the shoulders, it's really just a guess. I would try both. I like the gearing of the 245/40 better IMO but its heavier typically and pinched. I'd test both.
TomR
ABQautoxer is offline   Reply With Quote
Old 02-04-2013, 09:15 AM   #103
Aznsky
Ouch.....sounds like a challenge
Unfortunately I don't think I'll be going to Nationals this year (or even be competitive for that matter). But we'll see...
The Following User Says Thank You to Aznsky For This Useful Post:
Jedi1 (02-04-2013)
Old 02-11-2013, 11:36 AM   #104
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i'm torn between these and michelin pss. my big concern is tire life. michelins have a 300 tread wear rating and seem pretty grippy for dd/light track duty/auto x. the price point is about the same.
so, what would be the reason to get these over the PSS?
size will be 255/35/18
Jive Turkey is offline   Reply With Quote
Old 02-11-2013, 11:38 AM   #105
ABQautoxer
ABQautoxer's Avatar
The PSS lasted less long here versus the Z1 because you can not flip the tire. 100 runs vs 160 runs FWIW.
TomR
Old 02-11-2013, 11:50 AM   #106
Mitch
form follows function
Drives: RIP '13 BRZ
Thanks, that reminds me my Z1s are due for a flip.
Mitch is offline   Reply With Quote
Old 02-11-2013, 12:44 PM   #107
Aznsky
I would think you're choosing the star spec mainly to have a very competitive street tire and tire life being second priority. If tire life is your first priority then I'd think you can go with any other "high performance tire" since you can practically autox anything, it just won't give you that edge in competition.
Old 02-15-2013, 07:46 AM   #108
GregV
Drives: Kia Stinger GT2
Ordered 235/40/18s from tire rack Wednesday afternoon and they arrived yesterday! Quite the turnaround time. Now if only the weather would get warmer
GregV is offline   Reply With Quote
Old 02-15-2013, 08:26 AM   #109
scottynoshotty
scottynoshotty's Avatar
Drives: Hot Lava 2013 Scion Frs
Anyone have experience autoxing/dding rs3s? I live in ohio and am looking at getting a set mounted on stock rims for this season. I plan on autoxing around 2 to 3 times a month. I'm pretty worried that they would be useless after like 3 months. Would the evos be a better way to go?
scottynoshotty is offline   Reply With Quote
Old 02-15-2013, 08:54 AM   #110
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
They will last fine for that, assuming you aren't doing 3k miles a month. But the Z2 may still be the better choice, assuming it's within your budget.
I wish I could have waited but I needed tires one week to early to get Z2s so I got another set of RS3s.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-15-2013, 09:11 AM   #111
Aznsky
Just be careful in the cold/wet cuz RS3's cold practically have no grip. Competitiveness-wise they are still grippy as hell when hot.
Old 02-15-2013, 09:41 AM   #112
Kido1986
Dodging cones
Kido1986's Avatar
That's true. 60F and wet last night, slip-sliding fun with no effort. I put the Prius tires back on and they had more grip hahah
Then I took said Prius tires drifting
Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium Mitch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-08-2014 10:50 PM
Dunlop Star Spec anyone do yet ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 03-15-2013 07:29 AM
Reno, NV Volk RE30 18x8.5 +47 with brand new Dunlop Star Specs sillyboybmxer Wheels and Tires 2 11-09-2012 09:17 PM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
