Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-19-2017, 09:21 PM | #1 |
Drives: SC BRZ
No-start after clutch install
Hey guys, just got my car back together after installing my stage 2 clutch and I've been trying to get it to start to no avail ever since. Initially, i was getting zero power to the car and saw that I blew my main fuse on the battery terminal. Replaced that and now I'm only getting starter click, with no turn over at all. Batt has good voltage, tried several different batteries. Grounds are all connected correctly, starter is getting power and was removed and tested at a local auto parts store (3 times) and they said it was good. Fuses I checked were good too (inhibitor, c/open, starter, alt. starter), so cannot figure out what is going on. it is throwing a p2102 code which leads me to believe I'm not getting enough power to the intake manifold sensor, which would seem to be a ground fault but they've all been triple checked. Anyone have any input?
edit: buddy just came by and we tested power to the starter. it's getting full power until we try to start the car, then the power goes to zero. |
03-19-2017, 10:09 PM | #2 |
Drives: 2014 GT86
My guess: you may have adjusted clutch pedal travel to your new clutch .. but have your also adjusted clutch press sensor? Don't know how it should work with normal-key cars, but on ones with smart start with button one needs to have clutch disengaged, and that sensor should do that. Maybe w/o adjusting car still thinks that clutch is not fully disengaged?
03-19-2017, 10:12 PM | #3 | |
Drives: SC BRZ
03-19-2017, 11:34 PM | #4 |
Drives: 2005 Toyota Camry
03-20-2017, 01:35 AM | #5 | |
Drives: Q5 + BRZ + M796
@chargedup ...you said you tried different batteries. Did you clean your terminals on your wires? Have you tried clearing the code then trying to start the car? |
03-20-2017, 04:35 AM | #6 |
Huge E85 fan!
Drives: 2016 Scion FRS
You're only getting a click- one hard click or many clicks? If it's one hard click, this sounds like a starter issue. Did the auto parts store also test your starter solenoid?
03-20-2017, 08:50 PM | #7 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I will bet $1000 you missed the pin alignment on the flywheel. Same thing happened with my bud, checked eveything and removed clutch and the flywheel didnt line up to the pin, got that fixed and it started up. Done 3 clutches changes on these cars already.
03-21-2017, 12:31 AM | #8 |
Drives: 2013 Asphalt FRS
or installed the crank sensor wheel on backwards??/
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
03-24-2017, 04:42 AM | #9 |
I Love custom Turbo kits
Drives: Limited BRZ
This was my first thought when I read the thread title but if it were this, the car would turn over but not start. His car is not turning over.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | FRS Justin (04-01-2017), steve99 (03-24-2017) |
03-24-2017, 08:16 AM | #10 |
Drives: FT86
as the other guy said check the clutch switch operates when clutch fully depressed.
their are two one that detects clutch released the other operates when fully depressed for startup. if you have techstream you can check via obd port |
03-24-2017, 08:39 AM | #11 |
I had this issue. I bet your crank sensor isn't aligned. Very easy to turn it just a hair, making it not work
03-27-2017, 05:22 PM | #12 |
The Following User Says Thank You to mav1178 For This Useful Post: | Irace86.2.0 (03-27-2017) |
Similar Threads | ||||
Clutch whine during cold start | take the cannoli | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 17 | 09-30-2023 02:09 PM |
car won't start after clutch installed | aquaman | Issues | Warranty | Recalls / TSB | 4 | 07-19-2016 01:29 AM |
Clutch Rattle at cold start | shellslinger | Issues | Warranty | Recalls / TSB | 16 | 10-11-2015 01:45 PM |
Push-button start clutch switch | mike the snake | Engine, Exhaust, Transmission | 8 | 04-14-2014 11:31 PM |
RPM varies, cold start, clutch in and out | 00NissanNinja | Issues | Warranty | Recalls / TSB | 8 | 03-04-2014 11:40 PM |
